Old 02-09-2016, 10:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
SR5 Gauge Cluster Swap - How-to, with pics!
Old 10-03-2016 | 11:49 AM
  #341
AveCat's Avatar
Just did the swap, but it seems none of the gauges work. All the lights seem to be working fine, but no gauges. I swapped the oil sender before I did the swap.
Old 10-04-2016 | 09:06 AM
  #342
AveCat's Avatar
Looks like there was a short in the cluster, got it fixed and working.
Old 11-21-2016 | 05:42 AM
  #343
Carlos Medrano's Avatar
Hello! this is a A+ "how to", does anyone know if this cluster gauge could be use in a Toyota Pickup 1988 22r 2wd, base model with 2.4L?
Old 11-21-2016 | 05:33 PM
  #344
Birdman1890's Avatar
Yes, it will>
Old 04-04-2018 | 04:12 PM
  #345
Wavy stick's Avatar
Originally Posted by 86toyota
Thanks for the great writeup. I'd thought I would add some photos of a electronic odometer swap. I changed my miles this way without removing the speedometer needle.
Picture of a electronic piece:
Attachment 183215
Remove this black finger looking piece first. Just pops right out.
Attachment 183216
I used a ice pick to push out the rod(no. 1)
Remove the white gears(No. 2)
You should be able to set the miles to the correct reading by just turning them freely. You'll need some patient putting it back together. Slide the rod back in while placing the white gears on one at a time. Keep checking to make sure the miles are still reading correctly. Put the black finger thing in.
Attachment 183217
Attachment 183218
Attachment 183219
I know this is an old post but I'm doing this swap and can't get the rod out to correct the new odometer. Was there any trick to it? No matter how hard I push on it, it won't give, so much so that I'm afraid that I might break the plastic haha. Any tips?
Old 04-15-2018 | 07:53 PM
  #346
defrag4's Avatar
great writeup, how in the sam hell do u get a screwdriver onto that pot???
Old 05-21-2018 | 09:43 AM
  #347
DMilla's Avatar
Thanks for the write-up. Do you have a Part Number for the correct "SR5 Oil Pressure Sending Unit" to fit to the 22RE to make the new gauge cluster work? For an electronic cluster, does the tachometer need to be calibrated or does the cluster automatically recognize either a V6 or 4 cylinder applications? My switch is for an electric cluster, so I'm having the speedometer shop correct the odometer and need to tell him if her needs to calibrate the tachometer to 68.3 ohms or not.
Old 05-21-2018 | 11:42 AM
  #348
se7enine's Avatar
The tach will need adjustment if it is from a V6 going into a 4cyl or vise versa.
Old 08-08-2018 | 05:52 PM
  #349
darth_bronchioles's Avatar
Great write up, my install went pretty smooth. I have a problem with my speedometer though, it seems to be registering about 10-15 mph faster than I'm actually going while at highway speeds. I almost crapped myself this morning when I looked down to see the gauge reading 90, so I checked GPS which said 75. Any Idea how to fix this? '91 4x4 4Runner V6 cable cluster -> '91 2-wheel PU x-cab.
Old 08-10-2018 | 04:28 PM
  #350
Co_94_PU's Avatar
Taller tires, or change the gear the speedometer runs on. There is a gearset on the transmission side of the cable, iirc there are two or three ratios
Old 08-10-2018 | 05:40 PM
  #351
scope103's Avatar
Depends on the transmission. What I don't know is if you can replace just the driven gear, of if the driving gear has to be replaced as well.
https://parts.lakelandtoyota.com/sho...3911544#33403G
Old 01-05-2019 | 05:48 PM
  #352
mrgtstr's Avatar
Don't recall seeing this stated....Is a SR5 cluster out of a 2wd compatible with 4wd's as well due to the obvious reasons?
Old 05-07-2019 | 07:54 PM
  #353
Amethyst_Spark's Avatar
So I followed the instructions and got my new sr5 cluster in my 91 bad model. But I have no tach at all anyone have any suggestions as to what I can do to get that part working
Old 05-07-2019 | 08:13 PM
  #354
Originally Posted by HeroEnVec
Hey guys, I just swapped my cluster out. If anyone with a stock 22re and W55 (stock rear end) could give some speeds and RPM ranges at those speeds that would be awesome. Say, 5th gear at 60mph =?rpm? This would help people make sure their set up is working properly.
Also, I changed out the oil pressure sending unit, and the gauge is not reading. I think I have a bad gauge in the cluster. Because the sending unit cost me $50, I took it back and got my money. I am just going to install a autometer electronic gauge, which should be better anyway, and only about $60-70. Right now I have a check engine light, likely because I do not have the idiot light sensor plugged in. I'm just going to leave it plugged in so the light goes off... anyone see a problem with that if the cluster is already screwed up?
Jon
EDIT: my truck is a 95 base pickup. My tach was not working so I had to run the wire from the P marked screw on the cluster to the yellow wire on the ignition near the coil. I just opened up the connector, put a skinny wire in, and plugged it back up. No splice needed.
Can you by chance show me how you did this. I want my tach to work
Old 05-08-2019 | 02:48 PM
  #355
Originally Posted by ebye90
I just did this swap today, thanks to superbleeder and twistedsymphony! I dont know if this question has been answered or not yet, but i figured it out, and borrowed one of 'bleeders pics to illustrate the how to for anyone who is having this problem. I already had a sunpro tach in my truck before i started, so i had already run a wire from my ignition coil into the cab. If you havent gotten that far, you need to splice a wire into the ground side of the ignition coil. (on my '93 there is a tan and a black wire, the ground is the black wire). then run the other end of the wire either into the 6th position from the left on the blue connector, or attach the wire directly to the screw labeled "P" on the back of the cluster. I had problems with the wire trying to short across other pins so I attached it directly to the screw. Here is the pic I borrowed and circled the pin/screw:
Is there anyway you can show me what you did because obviously I can’t see the pictures. I’m trying to wire my tach into the harness but I don’t want to mess anything up
Old 05-08-2019 | 03:13 PM
  #356
Co_94_PU's Avatar
Gwt out your service manual (FSM) flip thru to the cluster pages and locate the tach/RPM pin (from what I remember it's some where on the C connector), you need to connect this to the RPM on the diagnostics port under the hood.. I don't think I took any pictures, but I spend "all day" at the junkyard getting the factory wire out of a dash harness..
Old 05-08-2019 | 06:50 PM
  #357
all I have is my chiltons book I don’t have the original owner manual. I guess I can do some more digging around. I just remember someone saying the connected a wire to the ignition coil and the P screw.
Old 09-03-2019 | 12:43 AM
  #358
Dkeith's Avatar
Help with gauges.
This seems like a popular thread so I have two questions.
1) how do I remove the lens of the cluster so I can fix my tach needle? My fuse popped one day and my needle went screwy and ended up INDER the nipple at Zero, so now when the truck is running, it raises to there and stops
2) can anyone give me the part number for the bulbs that go in behind the gauges. NONE of mine work lol
I've searched all over this site and can’t seem to find the answer anywhere.
Many help is greatly appreciated.
Picture for clarification.
Also this is the original cluster with (from what I can tell) the original drive train. I’m not sure if it’s common or not, but the mileage impressed me
Old 09-03-2019 | 07:17 AM
  #359
DMilla's Avatar
If I remember correctly, there are six plastic tabs holding the clear face lense to the gage cluster. Gently pry (lift) each away from their cluster housing bases and the lense will pull free from the cluster housing. The following pic shows the location of the tach adjusting screw. It only takes very slight adjustments to dial-in the correct tach setting to reflect 2,900 RPM at 70 MPH for a 22RE.
[img]blob:https://www.yotatech.com/d1268e1b-cb90-4731-b8c7-d8af2ec45bfd[/img]
Old 09-03-2019 | 12:22 PM
  #360
Dkeith's Avatar
Perfect. Thank you for the help
Quick Reply: SR5 Gauge Cluster Swap - How-to, with pics!
