Old 02-10-2016, 09:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
CV, Ball joint, TRE, replacement write up with PICTURES!!
Old 10-31-2008 | 09:40 PM
toyospearo's Avatar
I started in on this IFS repair this morning. This is the first time I have done one and I thought I would do a complete write up from start to finish for anyone who has not done one. Although I was very careful to follow the FSM manual and help from a few other Yotatecher's, I may have missed a few little tricks to make things easier as well as not getting some of the terminology correct. For that I apologize. I HOPE I didn't miss anything else.
I ordered the TRE's and ball joints from ebay. The seller is arm_can.
The CV's I ordered from Kragen. I live in a remote area where there is no Pep Boy's, Autozone, Parts Plus etc. I bought new CV's. The remans were $89.00 with a limited lifetime warranty and the new CV's (Cardone) were $99.00 with a lifetime warranty. I can live with the $20 difference. (I am doing both sides)
I did not do the Idler arm and pitman arm. I did those a month ago. They are pretty new and didn't need to be replaced. The FSM and a few mechanics I know recommend doing the Idler arm and Pitman arm while doing the CV's, TRE's. BJ's etc.
Comments and criticism are greatly appreciated!
The goods - New CV's, tie rod ends, upper and lower ball joints and adjuster sleeves. Total cost- $406.00.
I sprayed everything down with PB blaster as well as a mixture of Acetone and ATF-
I sprayed all the bolts 3 days prior to starting in and then sprayed them down a couple of hours before I started. Next, redneck jackstand on my un level driveway and the tires coming off..
After the tires are off here is a good look at the damaged CV-
Now I start in on the Hub-
With the hub off I heat up EACH of the cone shaped washers with a propane torch. The FSM recommended using a tapered punch. I didn't have one so I used a torch and a 15 mm deep socket. I put the 15mm socket over the washer and hit it with a hammer about 30 times until it came loose. The only real trouble I had with this job was these washers. I finally managed to get them off using this method.
Off!! damn!
Next the bolts from the CV to the differential. The 17mm open ended wrench on the outside of the differential I used to stop the CV from turning. I had to do it this way because the only helper I had was my cat and his paw wouldn't reach the break pedal. I did this to freeze the differential from turning so I could break free the bolt.
after using this method on all 6 bolts the CV was free from the differential.
Back to work-
at this point I removed the CV nut washer and then I remove the snap ring and washer allowin for the CV to slide out
With these off the CV is ready to come out. I had to take off shock to get it to squeeze by the shock lower mount and the stabilizer bar. I also cut the metal band and peeled back the rubber boot to make it slide by.
after this I put my drivers side tire back on to stabilize the truck so it wouldn't fall on me then I put my 2 ton jack under the Lower Control Arm and jacked it up to get the CV to line up enough so it would come out-
This method worked perfectly and the old CV is out!
Next I removed the bolts and nuts from the upper ball joint and aftermarket ball joint spacer
At this point I had to take off the brake caliper and knuckle arm
and secure the caliper up and out of the way (with fencewire). I had to do this because the break line will not allow enough room for the ball joint puller to do its thing. Once everything was out of the way I put the ball joint puller on the upper ball joint and set it free. I rented the "front end kit" ball joint puller, idler arm puller etc. from Kragen- $85.00 deposit, $6 a day.
using the same method with the ball joint puller I set the lower ball joint free.
Now I tapped on the lower ball joint to separate the axel hub and disc from the lower ball joint. This takes a chisel in the little slot with a few light taps-
Now that the axel hub and disk is separate I clean everything and prepare for the NEW upper and lower ball joints to go on (notice I cover the axel CV hub so I don't get any dirt or grit in there)
Lower ball joint locktited as well as the upper ball joint. Both are ready to go on.
The upper ball joint and aftermarket spacer were kinda tricky. I used a pipe and my floor jack to raise the upper suspension arm enough to get the upper ball joint and aftermarket spacer to slide by and fit. THIS WAS VERY SKETCHY! I would not recommend this technique! If the pipe slipped off the jack or the upper suspension arm while my hand was adjusting the ball joint spacer it would totally crush my hand. I didn't know how else to do this. It worked but it was dangerous.
After both the upper and lower ball joints are on and torqued to spec. I put the CV on. The CV went in without any problem. Once the CV was in I put back on the snap ring and washer-
Next I put the shock back on- Then the Hub!
Time for the tie rod ends!!! I used the TRE puller and pulled the two tie rod ends ( I had to remove the front rock guard in order to get enough clearance for the wrench)
I then assembled the new tie rod end and used the old tie rod end as a reference for how much thread should be showing. Once this was done I installed the new tie rod end-
Almost done!!
I greased all the joints and inspected everything to make sure I didn't miss anything.
Everything in and tire back on-
Total time involved for one side- 6 hrs. Most could do it in far less time. I am kinda slow
The only thing at this point is to do the exact same thing to the other side and take the rig into town to get an alignment.
File Type: jpg
File Type: jpg
Old 11-01-2008 | 12:10 AM
EvaMonky's Avatar
I'm impressed! Bravo!
Old 11-01-2008 | 01:03 AM
space-junk's Avatar
You are my hero... i am saving up right now to do just what you did, and now this saves me hours of searching...
good writeup btw...
Old 11-01-2008 | 05:31 AM
swaycleveland's Avatar
great job! one thing.. oops two things. first turn the bolts around on the cv to diff there is a right up about it ! makes the next time sooo much nicer
2) do the alignment yourself. i just did mine trust me on this if you can do what you just did you can do the alignment! sdori has an awsome write up on it i did mine and ive never had a car drive so well !
Old 11-01-2008 | 09:55 AM
iamsuperbleeder's Avatar
good writeup btw...
You're not the only one, lol. My self, I'm getting prepared to tackle all tie-rods, pitman and idler arm, all 4 ball joints (and install some spacers at the dame time), replace both CVs, and remove the swaybar; gunna do it ALL at once so I only have to have one alignment
Very good write up! I as well am going to reffer back to this; book-marked!
Nice work man!
The following users liked this post:
babyblacklightnin95 (09-10-2023)
Old 11-01-2008 | 12:53 PM
SR5's Avatar
SR5
Great Write Up
should submit it into the yotatech knowledge base repairs section
Old 11-01-2008 | 02:18 PM
coolthew's Avatar
dang it! you beat me to making this thread.
no really, awesome write up. very informative and thorough.
Old 11-01-2008 | 09:30 PM
coolthew's Avatar
hey toyo,
on the hubs, did you try tapping the outer edge with a small hammer to get the cone washers out?
OH! and i just found something out. if you have BJ spacers and you're having a hard time getting the upper ball joint on or off the seat, try undoing the anti-sway bar. I just spent 20 frigging minutes figuring that one out.
Old 11-01-2008 | 09:52 PM
toyospearo's Avatar
Originally Posted by coolthew
hey toyo,
Thanks for the info!!
If I have to take them off again for whatever reason I will do that. Those little washer are a PITA! Also, that pipe method I used on the spacers I don't think I would do that again. That was kinda stupid.
D
Old 11-01-2008 | 10:09 PM
Matt16's Avatar
Good writeup. I'm going to link your writeup to my CV axle removal writeup.
Old 11-01-2008 | 11:04 PM
toyospearo's Avatar
Thanks!!
Your write up https://www.yotatech.com/forums/f116...v-boot-156096/ helped me quite a bit!
thanks for that
D
Old 11-02-2008 | 11:02 AM
Matt16's Avatar
I'm impressed you were able to take pictures. I always end up working on my truck in the dark, in the rain, and getting too greasy to touch my camera.
Old 11-02-2008 | 02:46 PM
toyospearo's Avatar
I figure Yotatech has helped my quite a bit and I thought it might be nice to give back. Besides, my little digital has been to hell and back. If it died on me because of grease I would be ok with that.
Oh, and I did end up doing the other side in the rain. I built a make shift redneck tent out of a tarp that worked for a while until the wind blew it over the hillside.
Old 01-09-2009 | 02:56 PM
small town BIG TOYS's Avatar
Nice write up.
Old 01-09-2009 | 04:21 PM
Matt16's Avatar
toyospearo: I did a driveway alignment writeup (https://www.yotatech.com/forums/f116...ite-up-163432/). It would be a good idea to give adjust the toe-in precisely as even driving to an alignment shop with too much toe will result in a substantial amount of tire wear. Luckily this isn't too hard to do (especially with new parts!). Perhaps you could include this link in your write up.
Old 01-09-2009 | 05:27 PM
phildelfino's Avatar
WOW. GREAT WRITE UP...It's bookmarked.
Thanks to you. Thanks for the other links in there too, Matt.
Old 03-17-2009 | 11:12 AM
scuba's Avatar
Oh, toyo..What I noticed, And refrence for anyone else, To get that upper arm in a good spot and have the ability to put the spacer in, This is the best method, Courtesy SDORI.
Thats the droop stop on the upper a arm, when you first jack the truck up that should go in...
Just sayin..
Old 03-17-2009 | 12:19 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Great write up! This will be my guide if/when I do this, this summer. Thank you for taking the time for the write up.
Old 03-17-2009 | 02:21 PM
haha, look at my old post and me saying how I was going to be doing this soon too
ah memories...
although on a side note, I didn't have to remove my caliper brackets to get my upper ball-joints out
Old 03-17-2009 | 03:11 PM
toyospearo's Avatar
That is funny!
I am a month out from tearing out all that new crap and putting in a solid axle.
Quick Reply: CV, Ball joint, TRE, replacement write up with PICTURES!!
