Toyota Tacoma: How to Combine Front and Rear Antennas Into One
You old, stock stereo uses front and rear antennas, but newer stereos only use one. This means that installing an aftermarket stereo in your Tacoma can lead to a drop in reception quality. Here's how to combine the two antennas and vastly improve your reception.
This article applies to the Toyota Tacoma (1996-2015).
Your old, crusty, stock Tacoma stereo uses a rather old school setup of two antennas to receive a signal. The front antenna uses a normal sized antenna jack (like modern stereos), but the rear antenna uses a smaller jack that isn't compatible with aftermarket stereos. This means a big drop in reception quality when you install an aftermarket stereo in your Tacoma, which pretty much defeats the purpose of doing so. Thankfully, however, there is a way to combine both the front and rear antennas into one big antenna, which will vastly improve your reception. Keep reading and we'll show you how to complete this fairly easy and very inexpensive mod.
Materials Needed
- Antenna "Y" adapter (such as the Metra 40-UV43)
- Scosche Mda-B micro/delta adapter
Step 1 – Install the Scosche adapter
The Scosche adapter converts the smaller rear antenna jack to a normal sized, larger antenna jack. It's pretty easy to install as well. With your factory radio removed, locate the two stock antenna jacks (as shown in Figure 1). Install the Scosche adapter onto the smaller rear antenna jack.
Related Discussions
- How to Combine Both Antennas Into One Aftermarket Stereo - YotaTech.com
- Rear View Mirror Radio Antenna - YotaTech.com
