Toyota 4Runner 1984-1995: Why Won't My Interior Light Turn On/Off?
Your interior lights are supposed to come on whenever you enter or exit your 4Runner, but when they stop working, it could be caused by a number of things. This diagnostic will help you narrow it down.
This article applies to the Toyota 4Runner (1984-1995).
If you're wondering "hey, who turned off my interior lights?," then this is the right article for you. We'll be looking at why the dome lights won't come on when one of the doors is opened. It's almost always an electrical problem, so you'll want a multimeter on hand to do some tests. Diagnosing the issue is generally pretty straightforward, so if your lights are out let's solve it now.
Material Needed
- Multimeter
Step 1 – Check the bulb
While this seems obvious, it can be easy to overlook. You can't tell a bad or defective bulb by looks alone. If you really want to be certain, take the bulb out and test it for continuity. If it doesn't carry a current, then it needs to be replaced.
Step 2 – Is it a blown fuse?
This is probably the most common causes for dome lights not working. The fuse you'll want to look for is in the internal fuse box behind the driver's side kick panel. The dome light is connected to a 7.5 amp fuse. Check it with your multimeter. If it fails to carry any current, then it needs to be replaced.
Step 3 – Is it the contact switch?
There's a switch that the car door makes contact with to trigger the dome lights. It has a little black cover and is located near the door latch. If the contacts on this switch are dirty or corroded, then it can cause the light to not work when the door is opened. You'll need to pry the switch out from the SUV and unplug it. Then, you'll need to clean the electrical contacts with some contact cleaner.
Step 4 – Is your buzzer box installed?
The wiring for the dome light in '84 to '89 4Runners is connected through a black box that causes a buzzer alarm whenever the door is opened and the key is in the ignition. Naturally, many 4Runner owners dislike having the buzzer and sometimes disconnect as well as remove the buzzer box. It'll be located behind your driver's side kick panel on the front. Without the buzzer box, the dome lights won't work.
Pro Tip
It's possible to bypass the buzzer box and wire the dome lights directly, if you don't want to deal with the buzzer sound and keep your lights.
Step 5 – Check the wiring
The most difficult of electrical gremlins to track down are those that are hidden in the wiring. You should start with the ground connection. If there is a loose ground connection in your dome light's circuit, then it could cause the light to not work. There are ground connections at the door contact switch and near the interior fuse box that you should check. It's also possible for there to be a bad connection between the fuse box and the dome light. Use your multimeter to see where the power is failing and trace it back down to its source.
Related Discussions
- '87 4Runner Interior Lights Not Working - YotaTech.com
- Dome Light/Door Sensors Don't Work - YotaTech.com
- Clock and Dome Light Question - YotaTech.com
- Interior and Dome Lights Not Working - YotaTech.com
