Toyota 4Runner 1984-1995: Why is My Power Window Going Up Slowly?
Maybe your power windows operate too slowly. Maybe one of the windows only goes half-way up or down. Or, one window works and the other don't. Read on for potential solutions to window issues.
This article applies to the Toyota 4Runner (1984-1995).
When power windows operate correctly, they're great. When they don't, it can be a major source of frustration. There are a number of potential solutions to window problems. We'll go through each one, describe the problem, and recommend possible solutions.
Materials Needed
- Silicone lubricant (spray can)
- Silicone lubricant (paste)
- Multimeter
- Fine-grit sandpaper
- Soft cotton cloth
- Mild soap, non-abrasive
Tools to Replace Window Motor
- Small flat head screwdriver
- Phillips screwdriver
- Putty knife (or door panel clip remover)
- Ratchet
- 10mm socket
- T25 Torx driver socket
- Pliers
Step 1 – Check window lock
If your power windows aren't working, it may be as simple as the window locking switch being ON. Check it first. Note: The rear door must be closed in order for the rear window to operate.
Step 2 – Clean and lubricate window tracks
If your one or more of your windows are operating slowly or get stuck going up or down, this is a relatively easy fix. No need to disassemble the door panel. Just follow these instructions:
- To remove accumulated dirt and grime that may have gotten into the window tracks, insert a soft cloth dampened with some water and mild soap into the window track to clean it.
- Purchase silicone paste. (Brush is attached to inside of cap.)
- With lubricant on the brush, lubricate the entire window track.
- After lubricating, power the window up and down three or four times.
You can also use a silicone in a spray can to lubricate the window tracks.
- Insert the focus tube into the track and lubricate the entire track.
- Wipe off the excess lubricant with a rag and power the window up as well as down three or four times.
Pro Tip
Do not use a petroleum-based lubricant. This type of lubricant dries up after a few weeks and loses its lubricating properties.
Featured Video: Lubing Your Window Tracks
Step 3 – Worn or broken gear in window motor
It may be that the gear in the window motor that pushes the window up and down is worn in one area. This will cause the window to only go up or down and then stop. Pull off the door panels and find the window motor. Inspect the motor and gear. Replace motor if necessary.
Related Video: How to Replace Power Window Motor
Step 4 – Electrical troubleshooting
- Check fuses to power windows to make sure they're good.
- Check the contacts on the power window switch. If they are corroded, clean them with fine-grit sandpaper.
- If one or more switches are inoperative, replace them.
- Look for corroded wires. Replace as necessary.
- With your multimeter, check the voltage at the switches and motors.
Related Discussions
- Power Window Problems - YotaTech.com
- Power Window Electrical Question - YotaTech.com
- Slow Power Windows - YotaTech.com
- Slow Windows - YotaTech.com
