- Engine swap options with o body lift
- 81-85ish FJ/LC rotors vs IFS minitruck rotors
- Magiclly unlocking doors
- 22re help low compression and oil burn
- Door panel Question
- Truck shimmy shake
- Toyota tuck? is it a good choice
- 85 4runner lift kit question
- windshield washer pump NOS replacement question
- Wheels Options?
- Weber carb, fuel cut solenoid voltage loss...
- 85 4runner fresh rebuild - no power
- looking for aftermarket seats for my 84 pickup
- frame swap
- Swapping forward shift for top shift
- A/C questions
- Somone good/reliable to set gears in Spokane, WA?
- Lost power to gauge cluster and turn signals
- Hi Steer / Hi pinion Questions
- 1985 Toyota Pickup - any local member in and around San Antonio
- got a couple ruf questions
- 84-88 Shortbox, same box between Xtra cab and Reg cab?
- Front axle rebuild
- 1984 22R Truck Restart Issues When Hot
- 79 20r wont stay running
- Solenoid resistor heat?
- quick tcase question
- pre 10/84 4runner fuel pressure regulator
- Carburetor Differences (round & square plug)
- 85 Tranny Help
- 22R Motor and Tranny
- 84-85 p/ u 4x4 original cassete and radio stereo question
- 1985 SR5 four-wheel-drive shift knob question
- vaccuum pressure
- 88 4runner ac help
- Is it Carb or Timing
- Glass interchange
- Socket Size
- Just picked up a 1985 4runner
- Disintegrated Wheel Bearing help
- Lets see your bumpers!!!
- Aftermarket Headlights
- Shifter boot interior problems
- Shifter boot trouble
- 84-88 shifter boot install
- bleeding power steering?
- looking for built king cab flatbed to get ideas
- Where is everyone finding their 4runners?
- Is this site legit?
- Pic request:stock truck with shackle lift on 31's
- 85 4x4 auto stolen...fixing, help needed!
- 1985 4runner 22re lean condition
- 1984 4WD Toyota Pickup
- How can I STOP the water leaks
- 85 Toyota pickup need springs!!!
- any recommendation's for a rear disc swap
- Carb rebuilders question
- Looking for a new project
- Light/blinker
- Dip Stick
- lowering 7 inch lift
- gas draining out of carb?
- 84 22r part of head gasket ripped with TC cover removal
- Need schematic for 1985 22re truck ECU Part number: 89661-35020
- is it the body mounts or normal?
- 22r will not stay running
- How To Keep Your Toyota Alive 1975-1987 Repair Manual
- High Steer and Tire wear
- Your opinion on where to go from here?
- 88 4runner no power in gear
- 85 Cranking Issue
- weird failures and lost power
- 1985 rebuild w/ 5m-ge swap beginning to end
- solid axle camber
- Fuse locations on a 1985 4runner
- Out of the frying pan... My 1984 project.
- cigarette outlet and phone chargers...
- charging issues
- 84 4runner looking to swap rear window for one with defroster
- Parts from 1985 4wd dlx p/u
- 85 with after market rim and stud question
- weber 38 dual fuel inlet?
- 85 22re With hard time starting after sitting
- 85 22R head gasket FML! Need some advice.
- Stock 85 4x4 suspension specs help please
- Misfiring anywhere other than idle
- 85 Caliper Rebuild help
- blown headgasket with only 93k!
- 1984 transmisson help
- 84 transmisson
- seat belt upper bolt
- Stock exhaust manifold for custom exhaust
- LCE intake?
- ac switch and thermo sensor
- 85 22R refuses to idle
- Ideas for lock box in cab?
- transfer case question
- 85 Bolt set for front bumper
- tires cupping after lift
- 22re converted to 22r wiring help
- Will 88, 89 exhaust fit my 85???
- Info help on installing steering knuckle arm 85 SR%
- 1984 Pickup engine swap
- 1984 Pickup Radiator Fitment
- fuel tank swap ?s
- 85 runner speedo
- Help with 85' 4runner aftermarket a/c bracket and or compressor identification
- cold start injector time switch issues
- 85 issue, need help!!!
- compression test with bad bearings
- Leaf Springs
- OE Replacement Springs
- Head Gasket or Water Pump Cover?
- 1985 1 Ton brake problem
- 1985 1 Ton
- 85' factory 4runner A/C pics and help please
- Starting problems
- 1st gen. weatherstripping
- 84 temp gauge reads half all the time
- My 85
- 1984 Pickup FSM
- Question about swapping diffs
- Please help! metal in oil pan
- Rumble while decelerating?
- Couple Q's for 84 4runner Front Brake Upgrade
- Looking for weatherstripping or seals
- Head Gasket
- Weber carb lean condition? Warning: this is a Cali smog legal swap.
- Aisin Slave Cylinder
- 22RE rebuild/replacement options.
- Good complete 3rd members
- Rich exhaust
- auto to manual swap wiring help
- Post your rust pics
- Regeared Transfer Case, Might Have Extra Parts... Need Advice!
- Occasionally starts / wont stay running.
- What is it, do I need it?
- Front shocks for lifted 85 with stock mounts
- 22r Compression and timing chain questions
- 86-87 auto ex cab swap on 84 reg cab with re swap help
- 1984 Pickup; Part # Help
- Best way to repair my 85 Longbed
- TG knuckle service kit/ China bearings?
- yota noob
- 85 hilux carburettor wiring
- Steel or Fiberglass bed?
- 84 window seals
- timing help i think?!?
- 84 4runner not starting
- Extended shocks question
- camshaft lobe gone
- 22r Timing chain question
- Midland CB into an 84 4runner
- G52 to w56d forward shift...odometer conversion?
- Two Questions About Overheating
- What does this plug do?
- Another California gross polluter
- Timing set comparability
- Extra wiring plug on driver's side dash?
- Carburetor conversion?
- 85 4runner runs great until it gets hot
- 1986 with 84 22r motor
- 87 22r engine harness with a 22r motor 89 to early 90s carb
- 84 22r runs then dies when warm (No Spark once hot)
- 22re Amateur head gasket job, stuck at intake manifold
- Hard start after changing fuel pressure regulator
- 22re injector part #s
- Suspension Lift Kit Question
- hydraulic pinion brake anyone done it
- weber adapter plate which one
- driveshaft conversion
- Throttle sticking.. Gas pedal?
- Truck just died!!
- Center Support Bearing
- Timing jumped?
- Universal center consloe
- Ac comp replace Q's?
- I am now the proud owner of something...
- gas in oil what do I need to check
- 85 SR5 4x4 xtra-cab yota truck, what to do?, motor bad
- Wanting to piece together an '86 and '85
- Going from a G52 to a top shift W56-B
- New leaf springs now steering rod hitting Ubolt?
- 85 missing/rough idle when warm.
- What would cause oil in the Radiator?
- Change to a different alternator
- Auto Tranny Rebuild Kit Help
- 85 22re needs help apply within
- Starting leaf spring swap this weekend, and I've got a couple questions...
- front end diagnostics
- 85 crossover steering
- Heavy oil leak? rear main?
- '85 stock differential gear ratios
- 2wd or 4wd bed
- lc stage four cam
- 8" Differential Gear Mesh
- 85 4Runner grinding noise on turning
- 1985 22re Motorhome where to put jack?
- Thinking about buying a 1985 non turbo diesel
- got a oil leak, got pic's
- 22R knocks when warm ?
- clutch compatablility 4wd and 2wd
- Broken TPS or Broken User?
- Fuelgauge shows 1/4 after 100 mi from full
- 22RE Wont Start warm HELP
- Need some electrical help 85 p/u
- vacuum lines and timing issues, Help
- 2nd Gen Seat Swap: FYI
- Where to put grey sealer on timing cover?
- Understanding fuel consumption?
- Gear oil in locker air line
- bad death wobble
- 82 guts and axles on an 85 4runner
- Starting Issues? Try this...
- Fuel pressure
- Shock Reccomendations
- Coolant Temp Gauge
- 1985 toyota pickup 22re sometimes starting issues
- Wheel Bearing preload
- My first runner 85 efi fsa build up
- Thermo sensor touching catalytic converter element....s'ok?
- How do I know it's I have a sr5 runner
- Looking for suggestions: 22R/Weber carb Snorkel Ideas/Alternatives
- G52 to w56 swap...
- 85 Skyjacker 5" kit with rear leafs
- 85 4runner vin plate RN65 and frame has RN60 ?
- Just so I'm clear on gears...
- Chase rust or swap cab
- 1985 Toyota Pickup FSM
- 84 with no brake lights
- new to toyota. best places for parts?
- 22R temp question...
- axle shims
- Black oil
- Air intake/battery swap
- 85 pup thrown rod. Sell/part out or fix it?
- 35s with no lift?
- Advice needed: fix, sell, part out?
- No crank problem
- Seafoam engine treatment as a diagnostic tool?
- How to Verify Gear ratio without taking your diff apart
- Egr block off procedures
- Does my power steering pump need rebuild?
- can't get into gear
- Head light on but dash and tail lights off
- Considering replacing 85 Toyota 4wd Longbed frame with 85 2wd Longbed,Will this work?
- Reciver for hitch in front of 4runner ???
- 1984 ttoyota sr5, carb issues
- Is my coil bad?
- HELP! automatic tranny stuck in first gear
