- Building 22R long block, I need advice!
- Getting 3rd Gen wheels to fit SFA AISIN hubs
- 22re efi high idle
- rear shock length for Ford spring swap?
- Where to drill for wiring 85 dlx pickup
- break in period and synthetic oil
- What should I do with my 22R
- 85 22re Speedometer cable not spinning
- 85 pickup eating oil 57k on odom
- 3 core Radiator on 22re coolant won't suck back in
- 85 22ret boost problem
- 1985 toyota turbo efi(boost problem)
- 85 4runner new stalling issue
- 22r Carb issue Video. Comments Welcome
- troubles code question
- spring hanger upgrade
- 1985 truck with 1990 engine and irratic idle??
- 1st gen 4runner frame question
- Transmission Question
- Transfer case leak
- Dual battery tray?
- What is this plug?
- 85 22R Missfire, Backfire, Rough Idle, High idle, Surging, dying at stops or decel
- Throttle position sensor
- interior Question
- new thread old topic: 22re idle ,surge,dies
- New Guy
- Help! She won't start up!
- new 84 extra cab owner questions
- Won't crank help!!
- New part and/or part number for 85 4runner tube
- Protech headache rack fit?
- 22re ran out of oil...
- 85 4Runner solid axle Question
- 22R running very rough - could bad muffler be cause?
- Xtra cab plastics. way to reinforce? they're brittle!
- Tailgate weatherstrip for 1985 4Runner
- Extra repairs while replacing timing chain
- 85 22re tach questions
- Having Trouble...and not the Merchanic I wish I was
- "Charge" light only, runs fine
- pinion seal
- 85 exhaust manifold question
- Lower End Engine Noises- Video
- Looking for the best Radiator option
- ATF in a 1985 5 speed manual transmission.
- solid front axle vs ifs for road use
- Electric
- cant get 22r to start
- OME suspension help
- New to me 85 4runner
- 84 toyota pickup
- 85 4runner lug centric/hub centric and spacers
- Looking for 2L-T Diesel Parts
- Another Royal Purple Motor Oil Thread? What?
- misfire all of a sudden?
- Huge Winch ..12K on an 84
- NEED INPUT ASAP!! Found clean 85re Runner for $1500. Won't start, what to do?
- Fresh rebuild woes...
- 22R Barely idles with 0* BTDC but idles great at ~15*BTDC
- 85 4runner / 3rz
- anyone tell trans by looking at pic
- 85 yota in Austin tx. Need help with motor install
- Pitman arm for '84 truck
- Zuk mod the front?
- Stupid little coolant hoses!
- Front Hub Seals
- Tailight Fuse continuously blowing after blinker conversion
- Returning an 85 to its Former Glory
- Water Bladder in rear quarter panel?
- 85 pickup 22re
- 84 sr5 pickup brake problems
- Can a '85 22rec be converted to carb?
- Hesitation at highway speed
- NO HEAT! Input appreciated.
- Best exhaust?
- 1st gen 4R - how to make dim blinkers brighter
- Suspension parts
- New here
- 84 22rec AAV info
- 85 front axle hub movement
- Frame plating, Truck almost done need help.
- starting new thread here. 22re rebuild
- Taco E locker in 1985
- 85 22R high idle & sticky throttle
- 1985 extra cab 22re
- ECU questions
- What trans is this???
- Alternator charge cable
- Couple 20r hybrid questions
- missing nut from front axle
- New to forum - Hello!
- Steering bind/pop
- Need Help Diagnosing Sketchy Steering on my '85
- 1985 4runner new heater core wrong one
- SR-5 fender edge trim (need to remove)
- So I flipped my truck last night now I have a few questions
- 85 4runner axle rebuild -- need koyo bearing part number
- Extremely tight steering
- First gen 4runner tailgate with tons of problems
- Anyone know what this is?
- no brakes after axle swap and bleeding
- 85 p/u engine problems
- clunking / popping sound when turning 1985 4runner--any help appreciated
- 85 p/u 22re no spark
- knuckle felts and protectors
- Tilt column slips. Doesn't lock
- 4runner tailgate removal?
- musty dusty smell from vents
- Question about swapping diffs
- softopper top reconditioning?
- Dash swap....3rd gen Runner or Tacoma into a 84-88 truc/Runner
- Oem body parts
- muffler leaking at the seam
- another tire/lift question :)
- 85 Front Recovery Shackle Mounts
- Max 22R Power
- '85 Extra cab booster upgrade question
- 22R Hesitates once warmed up
- Help!! 22re miss!
- 85 Truck Clearance for the rear driveshaft
- 85 runner efi
- Ca 22re gurus!
- Upgrading brakes?
- pcv assistance please
- mustang/montero sport rear disc swap
- Lowering a lifted truck
- 7MGE stumbles and bogs down under 2000rpm
- Suggestions on fueling issues with my 84
- Pre-85 22r parts/reliability?
- Stock bumper light bar??.
- 1984 solid axle grease and oil
- New potential engine swap option
- 1985 4Runner surging idle?
- No start for "Chitty"
- Leaf spring reviews
- 22R no spark
- Newby here I have just picked up a 1984 4x4 shortbed with 26k miles
- Engine has been pulled, any Recommendations?
- 4WDFACTORY.COM Disc Brake Upgrade
- Old Newbie with questions about 85 Longbed
- Door Latch Stuck '85 Pickup
- 22RE: What are these Connections??? (Post-Head Gasket Replacement)
- Truck runs and sounds like an old tractor
- Freakin Brakes
- Hub Reassembly Advice
- 1985 XtraCab new DD- lot of pics
- 85 22RE engine code help 2...1...5...2
- 85 4 runner engine conversion
- 95 pickup visor on an 85 4runner??
- 22r dies on decents
- Overdrive not working--which solenoid do I get? (85 Pickup A340)
- hydro assist problems: cooler placement and sluggish steering not returning to center
- pinion seal
- 3rd gen 4runner dash into 2nd gen pickup?
- parking brake compatability
- What size bore and pistons?
- ping or valves help please
- please help. spark plug bent?!?!?
- marlins are out!! what to do??
- 84 22R Stutters on freeway after 10-15 mins
- installing front rotors on 85 one ton pickup
- best clutch kit 84
- front axle seals
- another odd ball gem
- Stalled and now won't start.
- 85 toyota pickup
- 85 22re to 92 22re engine swap problem
- Valve cover baffle?
- Engine steaming after headgasket and timing chain replacement
- Grinding noise while coasting
- 22r to 22re Swap, wiring help.
- Vibration that I cant figure out
- 95 4runner auto skips 3rd gear
- 85 22rec code 12 help
- black plastic cab side trim?
- weird starting issues
- LED light bar
- Timing issue.. What distributor do I need?
- Mystery problem
- cosmetic help locating parts
- 84 toyota pickup question please help!
- Misplaced bolts for plate on rear of cylinder head
- What did I break on the carb?
- 87 4runner 22ret body on a 85 4runner
- Cranking but not starting
- 85 4x4 diesel
- throttle body heater help
- electrical problem?
- OME IFS to SAS
- Weber carb question
- 32/36 re-jet question
- Crank pulley issues. Grooves and leaking
- Mutt truck?
- Best Tool Box for 1985 with Bobbed Bed
- loping idle 1989 3.0 please help
- Rebuilt 22r smoking?
- '85 truck wont turn over?
- thinking about parting out my 85 toyota 4x4 pickup
- 85 22re dies on warm start
- Truck Starts But has No Power
- Lets talk propane
- Leak after timing chain replacement help
- Metal Timing Chain Guide? (photo)
- Has anybody ever converted an sas to an ifs?
- Trans mount and fluids
- 84 pitaman arm
- Soon to have '85 toyota pickup ext cab
- Difficulty shifting into 1st and reverse
- Very Frustrating, no spark.
- Uneven idle +-10 rpm at 750 22re Auto
- throttle cable 21 inch
- SR5 Cluster Swap Speedometer Problem. Video inside.
- cylinder head rear plate..22re
- 3 truck rebuild thread
- stock 84 steering box adjustment
- gear oil capacity??
- DIY Snorkel. Cheap an Easy
- 92 pickup into 85 4runner
- 85 4wd power issues
- Window trim question
- Anyone with a tach?
- Rebuilt engine wont start
- 84xcab recon mission
- Rear U-Joint Replacement
- '84 22R Pickup A/C Cooling Unit Removal
- 84 and 88 toyota pickup
- iac disconnected
- 2'' body lift installed now doesnt stay in reverse or 2nd gear
- Windshield wipers stuck ON
- 22re Won't start until Ether
- Strange shifting issues after valve cover and intake manifold gasket replacement
- TPS Sensor Question
- 17" wheel on 1985 Pickup need tire for DD
- Timing Light on 22re pickup, good for checking miss fire?
- Wandering Steering, caster/front spring related?
- 84-85 Pickup and 4 Runner Headlight upgrade
- Anyone know where I can find a wiring diagram?
- 85 power windows
- Video - Noise = pilot bearing?
- Need some guidance on lifts/ tire size
- Window seals...
- Rear lift spring hanger bolts
- What's this part called?
- 4Runner top on a SR5 Truck?
- Rear axle removal.
- 84 pickup rancho steering stablizer
- No power please help!
- 1985 toy header issuse
- installing stereo head unit
