- '84 22RE, runs great at WOT, poor idle, stumbling at lower rpm
- Relay rod rubbing oil pan 2wd
- Where can i find rear extended cab interior panels?
- 22re died while driving, won't start
- 85 Pickup A/T ECT Computer Wiring Diagram?
- 1985 4x4 ext cab
- 22r carbeurator issues
- To Gasket Or To Goop That Is My Windshield Question
- 1994 Pickup - 3rd Brake Light Housing
- Twin stick install question
- Hot start issue
- Intermittent Wiper Install Dilemma in 1984 Pickup w/ 22R
- 22r running horribly
- 22r hesitation while accelerating quickly
- 84 gas tank swap question
- Ignition switch failure
- Need help building rear bumper
- Whine coming from steering pump
- to 4.88 or 5.29?
- 1985 p/u aisin clutch cyl part #'s???
- led headlight retrofit on 84 not hid or h4 headache
- Pressure plate questions! Help
- Pickup up a 1985 pickup with seized 22r
- 85 22r air intake melting????
- 85 22R - Not your typical Crank Pulley Bolt Question!
- 84 pickup carb butterfly valve stuck
- 85' 22re went through a big puddle fast, now has a new sound until car warms up.
- 84 toyota pickup dual row timing chain swap
- 1984 vs 1985 Pickup
- 84 hybrid timing cover question
- Inspection Light
- 22R No Spark
- Tire size
- 22RE Running cold? Wont go above 160 degrees.
- Service manual
- Tacoma wheels on an 84 Pickup?
- Transfer case splines
- Timing chain guides (tensioner side)
- 4x4 Will Not Engage
- coolant out exhaust
- quick vacuum line question
- Little bit of rod knock...
- Hubs for my 87 Toyota pick up
- Retaining the chevy ride
- small vault question...
- 85 4runner down for the count, 22re, flagstaffing, AZ
- 84 pick up webber carb missfires at full throttle
- Accelerator / Throttle cables
- Missfire/dead cylinder #1
- 89/3.0 fuel pressure regulator
- WHAT DID I do....
- Leaking Fuel
- Instrument cluster with tach
- 22r coil wiring issues, throttle linkage
- Destroyed the Lock Right auto locker
- 22re short block builders?
- Who wants to build a marty mcfly truck?!
- motor oil in radiator
- have motor oil in radiator
- 85 4Runner 22RE cold
- Running Cold and High Idle
- Bell Housing to Engine bolt size question!
- 22r carb gasket?
- Passenger side dash?
- Discount on Heater Cores
- Failed shackles
- Heater project(s)
- ECU Pinout for 85 22RE??
- Need help identifying this Toyota axle
- Does it make sense to replace just the timing chain guides or not worth it?
- Grinding noise and vibration in 4WD
- Hood Hinges
- '85 Pickup needing new 5-speed manual transmission
- spare tire
- front axle brake upgrades
- 85' Pickup with 22RE hard to start....smell fuel
- Yotalockers.com - Elockers for Pick Ups and 4Runners
- EB stick do I need stiffer valve springs?
- Best way to fill wheel well rust holes?
- 1985 pickup torsion bar adjust
- 85 4runner EFI stock exaust manifold
- 22r water hose under radiator blown
- Aftermarket temp gauge fluctuating
- Replacing knuckle on knuckle ball
- 84 pickup clicks and stalls
- Second row seatbelt attempts...
- Tach signal
- No blinkers, engine not running right.
- Swaped 22re thermostat problems
- 1984 Tail gate install
- No idler arm on '84 4x4?
- 85 4Runner won't start when it's cold
- Replacing 85 t-case output seal. No crush sleeve or bearing preload issues?
- What is this for?
- Newly machined 85 22r bored 60 over having trouble getting up hill
- 22r not starting
- Could someone post pics of steering pressure hose route?
- 1984 Possible Purchase
- My Truck is DEAD Again
- Rare rear bumper?
- 1985 truck window seal help
- Tire size recommendation
- Multiple Keys opening dorrs and starting vehicles
- Power stearing
- 22RE "overheating" HELP ME!
- 85 4x4 messed up
- 89 22re heater core lines block off
- Fuel Line Problems
- Cromoly front upgrade
- click clunk noise from brake anti rattle springs
- 84 4x4 22r knocking from bottom half
- Evaporator Pigtail/Harness Question
- 89-95 springs
- Fuel sender thingy
- help on performance problem
- Re gearing my Xtra-Cab
- Failed Smog test
- AC Questions
- 3 inch rough country lift roughhhh
- Best lift kit for 84' pickup daily driver?
- 1985 Toyota 3.4 Radiator Questions
- painting truck
- Intermittent Turn Sig cancel
- Is it possible to make a 89-95 offroad bumper fit 84-88?
- Grinding noise when I brake hard with the hubs locked
- 1985 4runner Automatic shift troubles
- ARB Bumper and Smittybilt XRC 8 Compatibility.
- cheap rear to match trail gear classic 3" front lift
- Weatherstripping
- 22RE very high idle
- '84 2.4 Diesel compressor bracket
- Dropped a washer in the clutch basket...
- Cooling in California
- Air cleaner to carburetor gasket/seal
- First gen brake upgrade
- Refreshing My 84 Suspension
- Bolt size on heater hose connecting to back of water pump
- Picked up this gem for $800 today
- Alternator issue 84 pickup
- Side by Side
- Re-Thinking
- horn wire 1985 RE 22
- 22re rebuild thread
- 87 to 85 motor and trans swap
- 22re timing / valves adj help Tacoma wa area
- Front brakes rebuild for 85 22re Truck
- Thoughts on Lifting 1985 4runner
- Any ways to get the RPM's down?
- 85 4runner automatic trans question.
- Moon/Sun roof removal
- 80 amp ignition fuse holder broken
- Long bed bed replacement
- 1985 Pickup 1 ton AC dehydrator
- Stumble on start up
- Advice needed for 1985 4x4 pickup!!!
- Missing Alternator Bracket Bolt
- 84 Bed Swap for 86 Bed?
- 85 Toyota Xtra Cab Pickup Rear Window Gasket
- Weird intermittent clutch issue - SR5
- New member
- 50+ coasting noise just seeing if anyone has had the same problem
- 2001 Tacoma bed extender on a 1987 4x4 ifs
- 84 Toyota pickup leaks! And fuel in oil
- My dual transfer case set up
- 85 intake problems
- Thanks to you all!!
- Rod Knock? Valve train noise? Plz help!
- crossover pipe issues
- New engine noise
- 3rd long box fit 4th gen pickup?
- 85 22RE High HC at CA smog.
- Weber problems
- And then she just died....
- 1985 4Runner. No start
- Help Diagnose Drivetrain Noise?
- Metal timing chain guides
- 2wd to 4wd body parts questions.
- 85 pickup 22r timing chain out of alignment.
- tps
- frame plugs
- 85 Extra Cab AC install
- 22r 85 issues
- Parts from other models
- Diesel 2.4 2WD What's That Under the Alternator ?
- Axle ratios
- Heater core hose from Intake Bottom Plate - OK?
- New clutch for 83/84 truck
- Shifting trouble
- 85 Toyota pickup 22r battery not staying charged
- Need some help
- 85 Runner Timing Issue
- New wheels/tires for my 85
- Vibrations and jumpyness
- Door hinge help
- 85 strange oil burning
- 1st Gen 4Runner: Clutch Releasing Super Late
- Set pin on spider cross pin question
- A few question on my 85 4runner
- My 92 2nd Gen
- '84 2wd pickup, hole of some sorts in tranny?
- Wiring harness help
- 1st Gen 4Runner - Rocker Moulding (Plastic Chrome) - How is it attached?
- 22re timing chain metal guides?
- My 85
- Efi to carb.
- Vacuum Lines Incorrectly Routed
- 1990 Pickup 2wd- What is this bolt?
- Knuckle Alignment Help
- Snorkel
- Unknown suspension
- upgraded seats
- Suspension questions.
- 85 Runner
- SR5 gauge problems
- 22RE idle and timing adjustment confusion....
- OME ARB 2.5 HD lift installed
- front u bolt flip size... diminsions plz!!!
- When and how far to rebuild 22R
- What's worse, wheels with less backspacing or wheel spacers?
- `22RE got wet and won't run right now
- Help with signals
- 1987 Toyota 4runner
- in cab winch controls?
- '84 4x4 losing power on inclines
- Hub damage under bearing races OK?
- manual locking hub clutch size?
- Is there a way to ID a year on 8" diff?
- front calipers wont disengage
- Help w/ identifying stock vs. aftermarket suspension part
- axle spline confusion
- It just won't give up!
- Heater Core hoses location
- Cat Removal?
- Sons truck
- 22r seized distributor
- 84 Pickup No dash lights, no headlights, no accessories Help
- Drag link orientation
- Ran compression test, now getting a code 12 (knock sensor)
- Question front floorboard repair?
- Brake issue after sitting for long period
- Soft suspension suggestions
- Torque specs?
- 85 4Runner NEW 22RE break in please help!!!
- chrome grilles
- 1984 Tojo Extra Cab 22r Carb
- Trouble starting after sitting overnight or at least 8 hours.
- tight valves
- Anyone ever dealt with constant power running to taillights and running lights?
