- 22r not running on all cylinders
- 4x4 Innovations tube doors review.
- afm adjustment
- 84 22re TPS help
- pitman arm rubs need help!
- need a tad bit more lift
- 85 4runner rebuild questions
- warmed up=dies at idle
- Tuning Holley on Offy
- Longfield 30 spline install questions
- Leaking Window
- IFS steering box mount
- 85 wont run, engine troubles
- i think my steering is out :(
- Looking for a simple lift
- fuel tank pickup screen options
- Should I drop the oil pan (since I'm doing everything else)!!! Pics
- Automatic trans questions...
- blowing back threw the carb
- Soliciting opinions on engine choice....
- Lookin to make a cheap lift
- fiberglass bedsides install
- update#3 pics...
- tire rubbing
- 22R Erratic Idling
- 2nd gen budbuilt skid/crossmember/belly question
- 22re-c turbo setup?
- Frame Issues
- 2.4 swap to a 3.0
- power windows stopped working...
- 1984 22re-c Body kits?
- Help! No Electrical...
- 84 Pickup good deal?
- surges when floored
- rims and tires
- 22RE Crank/no start
- What's it worth?
- Help me price a 85 4runner
- 84 4runner bikini top?
- High Idle/Throttle Body help
- valve cover wont come off
- 1984 Xcab parts?!?
- Emissions help needed on a 84 Runner
- repair panels
- 1st gen or 2nd gen? (opinions are welcome)
- spark plug smoking
- EFI Question
- Parts truck
- no cat + no muffler
- 85 extra cab help
- stock-gearing with 33s in an 85 Turbo. will it have enough power?
- 1984 pickup 2wd to 4wd
- Diesel engine for 85 yota?
- 5vz engine swap
- Help me identify this cluster
- Buggy Leafs
- how much boost can the stock 22RTE handle?
- Alarm systems
- Suspension Comparison
- headers
- '85 2wd cab same as 4wd?
- 22RE intake manifold coolant leak -Please help...
- Timing Problem?
- Marlin has tube doors on sale...got mine
- My first project/rust question...
- tire clearance issues
- my new 85 4runner
- running bad
- Hornblaster's train horn + onboard air
- ticking noise
- Armrest/Cupholder Mod-anybody done this?
- '85 4Runner A/C No Chilly Chilly
- New to me 85 runner, need lift/tire advice
- Help trouble shooting bucking problem
- runner rear window switch
- deisels badley and looses all power when secondary throttle is opened
- Rebuilding Front Axle
- I want to buy 1983-1985 Toyota pickup
- 85 rear window problem
- hi guys
- Rear Window Replacement?!?!?
- up to date pic o the runner
- Do you want a soft top for your 4runner?
- gas tank rebuild
- Introducing myself
- 22R parts on a 20R
- wheel stud help
- 85 fuel pump
- A good blaster?
- project update (pics)
- Front diff breather
- 85 4Runner wont start... newb question
- blown head gasket
- 85 4runner rebuild - Project:Redneck
- 85 Brake Help
- 84 22r will not start
- 84 4runner- no front wheel drive
- :help: 85 4Runner - Need some advise
- 84-85 automatic?
- My new 85 runner
- 85 Carby Problems...
- Oill Filler Cap and Dipsticks...
- ECT button
- missing and bad gas milage
- odo reading
- 85 - carb 22r-#4 cyl low compression
- so slow around here
- pics
- 1985 t-case problem
- Rough Country 3" Lift
- 7mge or keep the 22rte?
- marlin vs. allpro
- 22re head question need help quick
- Where do these go?
- 4Runner Electrical Problem
- have some questions about a '84 4x4 22r i might buy...
- Drop something into your vents?
- Finally figured out how to post pics correctly
- My 85 Toyota
- Vac line question
- clutch wont bleed
- newbies new 85 4runner pic
- v6 caliper swap PROBLEM
- need some opinions on 85 4runner
- 4Runner Rear Wiper
- '85 4Runner Build...
- 1988 headlight problems
- Wire Harness routing...
- getting hard to shift
- seafoam !! great product
- Know where to get a rebuilt Carb in SLC,UT?
- TRD Locker for an 85
- '85 4Runner
- my 84 build up
- 2x4 to 4x4 - 84 22R
- new bed floor ideas
- parking brake mounts??
- IFS Caliper and Landcruiser Brake upgrade
- has anybody heard of this suspension company?
- Pre loading Toyota strait axle knuckle bearings
- Overheating
- 85 22re codes
- 85alive!
- clips for the windhseild trim
- a/c compressor problem in texas. HELP PLEASE!
- push pull steering problems possibly
- my 84 toy...pics!!
- Looking to buy an '85
- '80 22r in an 87?
- Icelandic Hilux
- Tire Size and Gear question with no lift
- 22RE Randomly Dying???
- My new 1985 4Runner
- DEQ for Tags testing, things I learned 22r
- ? on installing trail gears 4" lift springs
- What is this weird knocking sound???
- shift boot difference
- what backspacing for 35's?
- 22r mods for CA SMOG
- newb!!
- Fuel Pump Issue
- Places to regear in GA?
- Add-A-Leaf on aftermarket springs???
- new member
- Weber jetting
- Which Taps/Dies Are Needed For An '87 22R?
- Places to get rebuild kit
- Just bought my first 4runner -85- -pics-
- 22r Manifold Reed Valve Question
- rear downey 3" lifts in front
- 22R knocking when cold
- my 85
- STARTS AND RUNS for 5 seconds
- Looking for a Front Reciever
- should I buy it?
- 22RE Turbo... any good???
- stock rear springs up front and chevys rear
- 22re timing chain slack
- v6 caliper brake upgrade question
- Back Window won't close in my 4runner!
- enigne hesistation 22r
- 22r exaust manifold vs. 22re exaust manifold
- locking hub question?
- New member 84 4runner
- Setting 22R timing
- Check Out My New Yota!!!
- Charging System Problem? ? ? ?
- 22re headgasket i'm lost.
- 84 toyota pickup parts
- Different sized tires-front and rear
- hard shifting
- 3rd members..4cyl, 6 cyl, front and rear
- sr5 dashboard clock
- camshaft and snorkel
- stock steering
- Does this look right?
- Stupid question, where is the rear defrost switch?
- 5.29's breaking
- Lifting Question
- The pics are in!!!!!
- oil question
- My baby hit the road today!!!!!!
- heater problem, hurry its cold!
- Need Help With Engine Fast!!
- What oil?
- 22R+Offy+Weber jet help
- 84 4runner coolant question
- Gearing running 38's
- Just turned 235000 miles
- dont do front digs with 38's aired down on asphalt
- 5.29's too low?
- Just got a soft top, not sure if I have all the peices.
- 22R Engine Pics
- 84 4x4 truck pics
- first rebuild-Checking a few things
- My average man's build-up of a '85 pick-up
- Happy New Year...returning newbie!!!
- Front Calipers
- Happy New Years Eve
- failed emissions
- Engine trouble help
- 22R engine question
- 84 pickup 22R 104k - engine hesitation
- first gen 4runner with no rear bumpers
- 84 Clutch
- Help me out on 1st Gen SR5 on ebay
- Body lift question on a first gen! HELP
- 1st gen and 16" black steel wheels
- 94 4runner runnen 33's too slow!!!
- 85 4runner overheating.. HOW???
- Over Heated
- interchangeable 3rds
- 85' 4x4 gas tank?
- 3rz vs. 22re swap.. into my 84..info? pros? cons?
- Oil Pressure
- De-rusting the 85 **pics**
- 22r wont fire
- clutch for 85 fuel injected
- locking hub wont go back to free
- What Tranny Do I Have?
- 22r carb
- piston rings/carb problems
- knocking rod Questions
- 22RE exhaust 85 x-cab
- Axle rebuild how long to allow?
- 22r Vacuum Lines
- 84 Toyo will not idle on own
- found: SOLID Axle 1st Gen
- 22R mechanical issues?
- Emissions Label?
