- OEM Master/Release Cyls?
- 85 4x4 EFI pickup intermittent stalling
- Bushwacker Fender Flares- '85 Pickup vs 4Runner
- Zuk mod ?
- 85 EFI 4x4 clutch conundrum
- 85PU 22r Smoking Incident
- 84 2WD 22R: Preventative Maintenance at 200K
- hard start 85 4runner 22re
- Zuk mod?
- 85 pu question
- 22RE pistons installed in 22R block by bad mechanic, will it work?
- Fenders
- Goofy compression test
- Quick question.
- 85 22RE rebuild
- 85 hilux 2LT
- Could low rpm hestitation/bogging be AFM? Please Help!
- idle/stall issue
- 85 4runner rear drum brake FSM correct for Left vs right sides??
- Rear bumper built around trimmed bed (85 pu)
- rear brake drums
- Tacoma wheels
- 84 truck 22r engine,,alternator new, still not charging??
- 85 XtraCab Build w/Flatbed, Cab Swap & Raptor Liner
- Installing new front leaf springs on my 1984 4x4 I need help!
- Stuck odometer
- Setting idle with internal tach?
- 1985 Pickup 2 wheel 22R Dies when brakes engage
- Re-using Spring Clamps
- Vent window inner weatherstripping
- Dropping oil pan 3VZE, what else should I replace?
- Lubricating Throttle Speed Cable- 3vze
- Timing Chain Guides - If it ain’t broke?
- Accuracy of Oil Pressure Gauge?
- White Smoke Comes out of tail pipe while acceleration ???
- What fits?
- 1985 Toyota Hilux/Truck 2.4 Turbo Diesel Dual-Cab
- Looking at a 1990 Toyota 4x4
- What motor is in this truck?
- Problems with removing pilot bushing and rear main seal plate
- Measurement Request:
- 84 to 86 rear brake question
- 2nd Gen Grille Swap to different Gen/Truck?
- Helpl! 84 DLX pickup Speedo reading about 30mph slow after swap
- Tps and tps dovetail dont match
- 84'4X4 Longbed
- Leaf spring identification needed!!! 1984 4RUNNER
- Rear Drum Brakes, 84 SR5, 4WD
- Model Code?
- 1989 pickup payload
- Another Toyota again
- Bushing for clutch pedal?
- Converting G52 Transmission to W56
- Where is this wire supposed to go to
- Back floor replacement
- 85 22re Drove fine for 1500 miles and today it want to miss and lose power
- Steering help
- Parts Catalog?
- At a crossroad with the suspension of my 85
- Identifying 84 vs 85 22RE
- After spring relocation, bump stops no longer align
- New guy, 90 2 door Runner
- Rough starting (video) and engine codes
- 3 person wide rear seat
- Radiator Options
- swapping an 84 22R to an 85 22RE
- 85 4x4 Pickup loud banging noise
- Help! YN60 circuits out, some come n go
- Running bad, then no spark
- Idle
- 1985 4x4 Manuel steering
- Mitsubishi 4D31
- 22R Temp Gauge Reads High No Overheat
- 4Runner Build, Mod, and Tuning
- Full Restore
- Full Restore
- 2.4 L deisel 1984
- 1985 4×4 efi auto trans
- Cruise control connections in 85 5 speed
- Newb here! I need help with starting issues
- Ok guys so I messed up pretty bad.
- Vibration....
- 85 fusible link replacement
- I'm kicking myself now...
- 85 pickup drum backing plate
- Brake problems2
- Coolant system high pressure.
- Vacuum Lines
- 884 Xtra Cab Resto/Build
- Oem factory winch
- head lights low will not turn on
- Price for bed??
- Just picked up this Sweet one owner straight 84 extra cab deluxe =)
- C 188 and 12SI alternator swaps in 85 PU
- 85 4runner fuel pump bracket
- Throttle Linkage Bushing
- 85 sr5
- Picking it up today
- Terrible gas mileage, smells like gas.
- Installing A/C in a 94
- Sway Bar End Links
- Axle housing question
- Got a hair puller her
- Aux fan thoughts
- What are Smitty Built bumpers worth?
- Twin Stick 2L to 2H Shifting while Moving
- 1985 GREEN 4runner
- Steering wheel
- The best 4 link suspension kit/info?
- 1985 AC issues
- Possible New Bumper for the '84-85 Trucks
- 1984 22r that is a puzzle for not firing up
- 22R Aisin Carb Repair Advice
- Factory diesel owners
- Can you put an 81 front clip on 85 4runner?
- 85 electronic fsm
- Outer Hub Gear Getting Stuck in Lock Position
- My 1985 Toyota truck build thread
- Wiring backups etc after trans swap to 5 speed from auto
- SR5 Gauge Cluster and Inclinometer Parts
- Air not blowing from outside vents?
- aftermarket gauges on 85 PU
- 1985 4Runner - Crank But No Start
- Other forums?
- Swapping Factory AC From 86 to Non-AC 85
- Steel wheel options?
- Body wobble
- Trans tunnel notched back w/ a 2" square ?
- First Post: First Pickup
- What Year is My Drivetrain?
- Will this mint ‘84 4Runner break $20k?
- 85 Pickup Dlx - Wont Click, Wont Turn over
- Head gasket question
- Source for new a/c hoses?
- Interior LED installation question
- Advice needed: 22r high temp troubleshooting
- OEM rear leaf springs poly bushing replacement on 86 4WD questions.
- 2nd Gens - Parking brake cables after lift
- Bump Stop advice
- Toyota Diesel conversion
- 22re p/s vaccum line
- 84 xtra cab best bolt on lift
- 22R Connecting Rod Thrust Clearance
- TDC question
- Newbie with a new used 1st Gen 1985 4Runner
- Bilstein C478/C476 fitment in 84 4Runner?
- Plz help me save my beloved 95' pickup!
- drivetrain and/or transmission noise
- Help. Low oil pressure and rough idle
- 22R broken valve guide #4 cyl intake valve
- 1985 22re rough idle slight missing smelly rich exhaust.
- Wasted head light wires undewr dash..MELTED
- '85 pickup build/problems
- Help. Fuel pressure loss on 85 22re
- Cylinder Re-hone
- What is this part? Power Steering Pump - Pressure Hose Seat?
- Heater Core issue
- 1985 toyota 2wd 22r stumbles after restart
- Are these 15x6 wheels correct for a 1985 4Runner?
- 2TR Swap with Automatic Transmission
- 85 Xtra Cab Build/ Restoration 25k
- 22re bolt hole question!!!!!!
- Coolant hose from timing chain on passenger side????
- No ignition power - headlights and heater still work
- Seeking Help with Temp Gauge Wiring
- Need ideas for my 84 pickup crawler build
- LED 4 wire tail light bar conversion issues???
- Trying to find belt molding (window sweeper) for 84 yota
- Is this the Rear Defogger Relay Plug?
- Rear Window Key Switch - Up But Not Down...
- Help - Lift reduction with hy-steer
- It seems my 88 4x4 V6 needs rebuilt
- 1986+ Rear Brakes Fit on 1985?
- 22re ecu
- 22re Knock Sensor
- Any Experience with extended shackles??
- Need some help finding where this hose goea
- Oil pressure sensor wire
- Moving front axle forward
- Aisin 1985 22r carb question
- Tail light lenses. 84 SR5, Exr
- Oil pump didn’t prime
- Anyone know what this six relay harness was for?
- 84 Pickup lost all power beyond the under hood fuse box
- Will they fit? 88 Truck body parts fit 84 Truck
- Seat Belts
- 1985 4runner oil leaks /timing chain advice?
- 1985 Toyota Pickup Electrical Issues - Seeking Advice Symptoms Listed In Thread
- Interior Panels
- Holley Sniper fuel injection
- 85 sr5 22re keeps studder/ stalls out
- 1985 4Runner Front Driveshaft Options
- 85 Ext Cab 2wd, 22re issues
- 84 extra cab rear cabin plastic replacement
- 2wd parts vs 4wd parts
- 85 4runner 22re to 3.4 swap
- Transmission ?? what is compatible??
- Rear Brakes Locking up HELP!
- Break peddle goes to floor
- Odd misfire at WOT
- Tailgate hinge pin
- Drive Shaft Orientation
- Where does this hose go and what is it for?
- Project daily driver 85 4runner
- Wont Idle
- Cluster swap question
- Bucket seats
- Rough Country 3 inch lift for 1984 4runner
- OE Grille Emblem for 85 4Runner Anyone?
- 85 4runner 22re issues low power
- Sway Bars
- 84-85 vent window
- IFS Hub Swap Question
- 22re swap
- Lce pro distributor install
- 1986 4 runner Speedo and blower fan stopped same day.
- Where Does This Guard/Bracket Go????
- 1985 1 ton A4D transmission issues
- What hoses are these, leaking fuel
- battery deaded
- Ham Radio
- bent fuel line off pump hanger
- Front drive shaft 4x4
- 22RE wont turn over when ~32 degrees or below and idle surges when warm
- Hard Brake Line Replacement
- parking lights come on by themselves
- 22r has no power
- Aluminum chunks in oil pan! :soap:
- Hood bolts
- 1984 toyota pickup build
- Throw out bearing issue
- Intermittent wiper question
- 1984 22R distributor cap question
- No crank no start
- Urgent Help Removing Spare Tire
- Replacing right steering knuckle arm on 84 RWD pickup, other possible issues?
- Camshaft
- 85 4 runner running bad
- Center console heater advice and parts (willing to buy parts)
- Axle identification
- (?) Noob question: High beams on 1984 Toyota Truck?
- 85 4runner noises and shaking
- Ok stupid newbie tech question.
- New exhaust system
- Replacing ALL belts
- 85 toyota pickup efi 4x4 has no power
- What's it worth
- third auxiliary accelerator pump diaphragm this year.
