- for sale: 85' 4Rnr SR5, top, tailgate, interior bits
- 89 injection into an 84??
- Book time to replace timing chain?
- 85 4Runner Corner Lights
- Suspension Suggestions For 84
- Light bar or roof rack wiring
- Pics of Old Man Emu Lift
- Charcoal Canister For My Gas Tank
- Lift kits for solid axle trucks
- engine block heater...
- FYI STC sold to another company
- How do i find out my tranny code?
- Slow or no crank in the morning battery issue?
- Help me find this truck...last spotted in CO
- How to install a clock
- axle price
- '85 electrical question
- stock 85 runner suspension
- '84 22-R fuel starvation/Carb issues
- New motor options
- spring opinions.
- Hysteer crossover conversion quite a bit of work
- Adjusting drag link
- Ruff Country lift?
- A340F 3rd to OD shift problem
- 85 Xcab exhaust...what fits!!????
- Exhuast Leak driving me nuts and i cant find it.
- Best place for hubs
- 84 4runner sr5 question
- Making a snorkel for a 22r
- Front signal light on bull bar?
- approx weight of my truck.
- Best riding AAL?
- torque spec help
- Power steering conversion
- 85 Front caliper rebuild
- 22r only running of 2 minutes
- 1985 truck won't start
- heater core replacement?
- Need SAS frame jigs
- Just picked up an 85 extra cab???
- Will these factory alloys fit my yoter
- Semi-Dumb question on brakes?
- Rear bumper ideas
- 0-60 times?
- 84 2wd Toyota EFI
- Lights in holes in front bumper?
- TIres vs. 22re
- 1985 4 runner with 22RE - Mystery plug
- 84 4runner front bumper?
- Center/Carrier bearing question on alignment
- Trying to lift my buddies truck...
- Hubs ?
- xtra cab bed box/ long bed possible?
- conversion kit to go from auto to manual hubs
- 4WD indicator light
- Transfer Case Question
- Wheels for 84
- 85 - rear windshield washer
- 1985 4runner towing?
- Coolant or water in the vacuum lines(metal tubes) for '85 22RE EGR
- help getting a 22R to pass I/m
- Wiring
- cant get starter out
- diesel 22r or 22re
- 85 3rd member
- Found a 4runner, is it a good deal?
- Problems after 3.0 rebuild (HELP PLEASE!)
- 85 22re auto idle drops when hot
- 84 vin question
- Toyota Recalls
- rims
- trail gear lift
- Condition Red?! - Multiple Dash Warning Lights
- Interesting electrical problem.
- 84 4Runner Charging Problems
- Remote Start for rig
- Problem with headlights
- 85 4Runner Auto Tranny
- what is this? on a 84 22r carb
- Seat questions
- making extended front driveshafts with marlins extended yoke
- 85 - what to look for
- 22RE oil capacity
- v8 in to an 85
- 36x13.50 iroks on a 15x7 wheel
- Cylinder head gone bad, I would say so, wouldnt you?!
- Interior door panels
- power steering question
- Lets talk about the hilux surf.
- My renovation for malls AND trails.
- Bad headgasket, Maybe?
- rear end fluid type? (middle of locker install look inside for type)
- 1984 Toyota Problems
- need drum brake parts for 84
- Where do u find a 22r exhuast manifold for CA??
- 85 xcab rear springs sagging
- 1985 4 runner - 22RE engine - timing mark
- '84 Heater Control Assy
- calling all gear guru's hows this look?
- Blower Motor Problems, Replaced parts, Nothing...
- pro comp springs
- Water Entering Through Rusty Fenderwells
- body lift problems
- 84 truck w/22r motor -> 3.0L v-6 swap info needed...
- front axle leaking!
- Need help with alternator
- Tranny Swap - Wiring Question
- f/r third members interchangeable?
- '88 Rearend gear ratio question
- my new truck
- My first 85 Pickup
- HEad question (22re)
- "Help" with 1985 axle
- seats
- brake upgrade on 84 sfa to ifs calipers and land cruiser rotor
- landcruiser discbrakes
- Charcoal Canister
- ebay parts
- 22ret exhaust/DP
- smog pump? emission stuff
- vacumm lines 84 22r
- 5.71 gears in a stock housing
- Snorkal intake?
- My 85 backup light problem
- bilstein shocks
- What Lift For My '85 4Runner?
- Spring removal???
- Wheel Studs - Aftermarket part #s are WRONG
- My first 4x4 toyo (for wheeling)
- rentedmule's 84 xtracab - pics
- 85 pick up 22r to 22re?
- '84 is getting tired
- '84 4runner catalytic converter
- bare bones requirements
- pros and cons of a 84 4X4 Pu?
- going 4wd to 2
- foriegn tapping sound
- 33 X 12.50 X 15's Clearance ?
- The old coolant into the exhaust manifold trick
- Oil Pan Removal On an 85 4Runner
- 22RE to 2JZGE swap
- 22r cam timing question
- motor swap?
- 1985 Toyota p/u 22RE
- starter burnout
- Sterring wheel shakes and rear end popping??
- longbed v. shortbed (wheelbase and off-roading)
- Help with 84 Toyota P/U
- intake tube and speaker questions
- weber 38 on 22r dieseling
- where can i get a replacement floor pan for an 84?
- Identify this ECU connector...
- Wheel Spacers
- flooding
- add-a-leaf or blocks?
- wtb 22re
- 1985 4 runner / cross memeber options
- need wiring help
- e-choke problems
- how to rebuild a 22re
- Look what I found behind a gas station...
- offenhauser intake water plates
- tachometer check
- Rear Springs
- Steering Box Rebuild
- Seeking a 1985 4Runner receiver hitch!
- bed swap
- looking for a lift kit...
- Hard starting
- Project update
- auto trans question
- replacement springs
- A/C compressor & Bracket
- 84 22R 4 Runner Purchase
- Remote Radiator
- my pick up is not runing right
- in search of one 10" subwoofer enclosure
- 1984 xtra cab toyota p/u tires
- What engine is this?
- 84 Carbed issues
- Accelerator Cable?
- All sorts of electrical issues on my 88 Toy
- 1984 truck ready to bomb, need advice in NC
- 1985 4 runner rear window spoiler
- 35" tires, stock gearing, and a 22re??
- Mystery bracket--where does it go?
- Changing Engine
- another noise bites the dust (85 runner)
- what to do with my 22re?
- squeaky steering wheel resolution
- 85 grill
- Pics of the 84......Finally
- Where to tap power for aftermarket RPM gauge
- sleeve on oil pump spline
- 2wd to 4wd trans question
- Center Support Bearing Removal
- phoenix people jump on this, 85 4x4 on craigslist. $500!
- 85 injector/something?
- any quiet stainless mufflers?
- Please Help Me Diagnose my engine problem...
- alternate fuel power source
- Rebuilt 3.0 source
- Need help with piston ring install
- my new toy/rig/project (#2 rig LOL)
- 30 spline Longfield install with pics.
- 22re exhaust leak question
- 1985 4 runner
- All Pro front springs...
- 22-R Timing chain links? Need help ASAP
- nonrunner now 4runner
- v6, v8 conversions
- Slip yoke problems need help!
- fuel cuttoff switch
- Removing transmission from 22r???
- shell remove 4runner
- my 85 with bumpsteer
- Dynomax Super Turbo muffler opinions
- body lift for 84 forunner
- 22re, EFI fuse does not clear TPS code 7 - Help
- Nearing the end on '85 4Runner build
- 84 pickup shipping cost $1,200, and basic info on model
- Solid fan and remove fan clutch??
- Replacing Brocken Fuel Injector connectors
- frame difference?
- 2-3" Spring Lift without HiSteer?
- The taming of the shrew...
- 85 toyota
- 84 toy p/u vibration
- Can-Backs coming back
- 84 4runner air pump problem
- Can I put E-locker into '84 front housing?
- power loss in 4th and 5th gear
- Timing Chain Cover
- more pics, flatbed progress
- my new 85 4runner
- My 1984 4x4 truck....
- Western Washington head gasket help
- is the 22R any good for towing??
- whats the best way to clean your heads
- in search of a flywheel
- ugent help with 92 v6
- Chassis Lubrication
- First Gen Cab on Second Gen Frame
- i've got 90 days to pass an emissions test! HELP!!
- please help ID clunk
- Most Bada$$ Toy Pickup Ever!!
- A/C low/high side
- need help
