- smog problems
- Gearing?!?!
- torque rod ?
- Oil Filter (Not brand, Sizes used)
- 22R / 22RE exhaust manifold
- Rear end clunking problem.
- Question? 85 pickup sr5 efi 4x4
- Wtb 5.29 3rd Member
- Exhaust
- 22RE Questions
- SFA weight?
- What gears...opinions
- Toyota rod bearings or auto part stores brand???
- dash gage swap?
- the runner gots some new shoes
- i was bored today
- Help! Engine lopes after Head Gasket replaced.
- transmission problem?
- 22r power mods?
- Decided to get my '84 4x4 rebuilt!!! help me please...
- Aisin SFA / Aisin IFS Locking hubs
- Weber conv.
- 22R Burning Coolant
- Aaaaah
- 85 Auto Tranny Question
- Another Gas Mileage question
- 84 pickup ignition problem?
- 84 carb same as 83??
- 84 4runner advice
- My rear is sagging. '85 4runner
- Wtb: trail rig(4runner or pickup)
- Maintainance time...
- 85 diff exchange
- What next?
- 85 Pickup with Comp Cam?
- Knocking after headgasket job.
- 1986 vs. 1990 Rear Axles - Which is better to use?
- She died on the highway, she did...
- Brand of Oil to use?
- another gear and locker thread...
- oil pressure fuel cutoff switch wiring??
- 1985 A340f
- Automatuc T-case
- Vacuum lines?
- IFS Steering box on Stright Axle
- Egr Valve
- Need a Rust free AZ 1988 4 Runner?
- Decent Rock Crawling Tires?
- toyota magazines?
- Rear wheel bearing = tranfser case bearing?
- possable valve problem 1984 22R
- New Runner...YIPPEE
- rattle can paint job - 4runner
- Lifting 85 Pick up
- Rear end driveshaft bearing??
- 85 4runner bolt on suspension
- 85 22re 5sp efi poping out of 3rd gear! help
- timing chain replacemnt
- Timing Chain Rattle
- SAS 87 4runner
- what would u pay
- 20R head swap
- Electric fan questions
- Need help replacing front rotos
- Got an Install Date! 5" up, up & away!!! My '85's Buildup
- 3tc into 84 runner
- 1985 4Runner, any hope, or a waste of time?
- please help w/ door question
- Chrome Rims
- Fuel Tank wasted by Drive Shaft?
- Oil Sending Unit Part#
- locked keys
- sr5 cluster?
- engine starts then shuts off?
- Engine Oil Leaks . . .
- 5 bolt chevy rims on a yota???
- o2
- locker up front???
- When going .030" over, what piston to use?
- Squeaky seat is driving me nuts
- 1985 Toyota truck winch option
- 22R Maintenance Question
- Bikini Weather!! (Not the 2 piece kind!)
- Slipping clutch when HOT
- 85 forerunner engine?
- 22R Power Steering help
- re-arcing leafs for lift?
- 2WD or 4WD bed...
- Rear Brakes
- Power Steering
- Problem with rear defrost 1985 4runner
- rear window is laughing at me
- Blown head gasket?
- painting the undercarriage
- Mr Plow style 85 4runner on ebay
- 22re problem
- spring swap
- Help me! My brakes are scary.
- New shocks needed w/ ~2in lift?
- 93 toyota 4runner 3.0 V6 engine replacement
- *MY* first true complaint about a Toyota!!!
- More Power For a 22R
- 33's and a lift
- Repair or replace rotten rear 1/4 panel and tailgate?
- Does an 84 22r have a knock sensor
- Help with mechanical fuel pump
- timing chain questio,please help
- Are my springs toast?
- Let's see some 1st Gen 4 Runners w/ 5" of lift!!
- Just bought an 84 4runner
- Front Bucket Seats 4Runner
- 22re problem
- 22r Carb Problems. Help!
- 22R to 22RE
- How much lift before needing new drive shafts?
- Breaking in a new Lift
- steering pump bracket bolts . . .
- Looking a bit deeper into propane conversions
- 22re
- 85 4runner 22re having problems tuning
- Intermittent charge and brake light
- major oil leaks
- help me spend $3700.00
- Which rims and tires....again.
- Brake backing plate eliminator question...
- Newbie with a 4Runner question
- What is the thread size of the oil pressure sending unit?
- I almost rolled my 4runner on the interstate
- oem replacement fron springs?
- 4runner axle setup.
- 22R freakin' oil LEAK
- Grinding noise from the drivers front.... 85 Pickup
- IFS 58" Rear Axle - rebuild questions
- death wobble pt. 2
- 85 yota with 44's ?
- Why am I loosing oil?
- 22re fuel injectors
- Getting ready to lift it! 1985 Runner
- New engine for a 1st gen.
- will the wheel bearings loosen?
- 22re Engine Build?
- Used tires for sale
- steering arm
- need decent tailgate for 84-88 p/u
- Front rotor service limit?
- '85 4 Runner - Manual Window Regulators
- tightening down wheel bearings??
- gearing question?
- A/C evaporator install problem
- Help!!! Bleeding Brakes
- Need help!swapping motors.
- Rear Axle - When is it 3" wider?
- Retrofitting A/C ? about drilling holes
- Advice before trading 2nd gen 4runner for 85 pickup
- Cheapest place to buy ARB bumper for my '85 truck
- 84 22re questions
- 84 Runner not starting
- 1984 pickup std cab looking for info on fitment
- Clutch slipping like crazy
- rough ride on downey's?
- 16" Tacoma Alloy's on a '85 SFA - Need suggestions
- Ignition Coil ?.
- does my oil pump need replacing?
- Very strange starting issue
- E-brake and rain = no release
- my yota died on me
- 1984 pickup 5sp 4x4 gvwr and gtwr
- pic of remote oil filter
- maybe a pic of me truk
- 4" Front Leaf springs - good deal to pass on
- 1994 toy gotta see it
- 2nd generation clutch chatter (slight)
- GM igniter 16.96 for Toyota igniter 457$ WORKS
- Rebuild in San Jose for 1988 W55 transmission
- Line X the inner wheel wells, or not?
- Diagnoising this mornings coolant mishap
- Questions before I start.
- 22R to 22RE
- 22r to 22ret
- need help with CPU Code reader
- my 85 pickup has body damage on the cab
- 85 toyota 4x4 wont start
- My intro:with pics.
- Rear driveshaft interchangability?
- need layout of fuse panel in 85 4runner
- new fuel pump? someone help me out
- Must be nice to have rich parents
- Pinion bearing goin bad?
- 4runner heat issue
- Can I drive with this unknown part broken
- My 84 Xtra ca and intro
- Where to buy wire harness for 84
- COMPLETE rebuild on front axle
- 84 heater quit working
- Which TO DO? 4.7 gears or 350TBI
- exhaust pulses?
- Crank shaft pully seal install
- 84 Toyota Pick up Fuel Injected
- 84 air box ?
- front brake issues
- Drive Flanges?
- Shock rod adjust?
- need advise on suspension
- motor mounts for a 3.4 swap?
- rim question
- My friend bought an 84 and we need some advice.
- Electrical Problem need help/advise.
- My horn don`t work
- 85 4Runner power to fuel pump?
- Weber Choke Issues
- reversing body lift
- can-back pre-orders
- difficulty of installing a 22re
- v6 3.0 swap
- 84 pickup 4cyl 5 sp needs tach info
- wifesaysimadumbass needs a buildup thread!
- Photoshop...Please paint my '84
- I cant believe its dead.
- dana 44 toyota rear end swap
- clutch question
- Help me save my Rusty truck!
- 1984: Cheap lift
- 84 Runner AC control and Power Window not working
- Auto to Manual?
- chevy 63's?
- 91 22re CEL codes
- tires shake uncontrolably
- timing off
- Stock rim fitment on '84
- Shocks for my truck
- Old 4Runner new owner - long
- 84-85 trucks
- cross over with sway bar?
- 84 wheel spacing and offsetting
- repair for wiper linkage???
- 85 4x4 questions.
- How to Tow?
- chirping sound
- how many pumps of grease?
- bad ignitor?
- 1984 High beams stuck on...no lows
- Marlin diff drain plug question?
- headlights work, but NO tail, licenceplate, dash, or corner lights
- 1984 Transmission grinding, 1st kicks out
- 1984 22R Crank pulley slinging oil
- question about engine swap
- 85 Yota Front end roar
- 85 toyota 4x4 will not start
- Polished Knuckles?
- Clutch pedal popping sound
