- Something broke but I don't know what
- 94 2wd Bumpstops
- Starts but dies?
- 185,000
- Pinion nut
- Temperature gauge woes
- Stock front leaf pictures?
- T-case Gasket
- Door ?'s
- Lift w/ ball joint spacers and add-a-leaf
- Removing transfer case?
- EFI Erratic Idle, disconnected vacum, Help Needed
- new project??
- 3.75in. backspacing rubbing the frame on my 85'
- Need new vacuum advance unit.
- R12 to R134a AC covnersion
- Clutch goes GRIND and will not go into gear without stalling the engine
- Need To Replace Catalytic Converter,
- Timing Chain replacement..
- 4-runner making noise?!
- 85 transmission problem
- Front seat Y cable help
- prerunner S/A 85...... yeah i know :)
- tell me about 22r
- Fender Flares, where to get?
- 22RE Staring Problem
- 85 pickup Tranny Swap.
- Rattling sound in engine compartment
- 1985 4runner rotor removal
- no power
- 85 Auto Tranny Downshifting and upshifting problems
- Leaking clutch fluid
- Seat Covers Needed
- some feedback please?
- runs poorly at acceleration
- Then and now, evolution
- only one hella 500 comes on! help
- should i??
- Anyone buy back a truck you sold 10 years ago?
- 1" Body lift and new bushings, OK???
- front turn signals/running lights on 1st gen 4runner
- Heat in front hubs???
- 85 4runner with no power after tranny swap?
- Wtb
- Cam shaft decision time.
- 7mgte swap
- Rust in floor pan, need suggestions
- Fixing a troublesome LSPV, now works
- Thermostat Sensor what is it called on top of the tstat housing
- Muddy Motor
- Ignition timing jumps code 12 need help I'm stuck?
- just bought 85 runner but not stock windows..help
- Bobbed Bed Writeup
- My 1984 Toyota X-Cab Buildup
- enginebuilders
- 1/2 in wheel spacers
- 22RE Best Mod For The Money
- Genuine Gears?
- 84 22r Disconnected Vacuum Lines Sensors/Switches
- balance and blueprint?
- Another No Start Question
- 22RE Flex Fan
- Have Questions About 84 4Runner
- diffs and tcase(how much gear oil needed?)
- sun roof
- Hella 500 question, fog vs driveing
- which cam?
- Check engine codes
- Help with replacement brake booster
- 85 pickup 2wd transmission
- Sticky steering?
- Hyraulic Clutch info needed.
- Rear main seal
- tranny stick
- first gen bed on 2nd gen truck?
- Driveshaft Length
- Stick 4runner?
- Adding AC to 85 carbed truck from an 86 efi
- Stock Springs Or Spring Bushings
- '85 4runner brake booster
- Toyota Add-A-Leaf
- 22RE exhaust question?help?
- Ignition starts fine but wont quit.
- thinking about buying old yota - one small question...
- Just bought a 1985 4Runner
- Fuse Identification
- fuel pump drive cam
- '85 Diesel 4Runner
- 84 4Runner Sliding Siding Windows
- Welders in Seattle
- 4runner problem
- Out of the blue, 4runner dies, almost catches FIRE!
- R150F Bolt Pattern
- Brake light wont turn off!??
- Truck won't start.
- new addition to the family has arrived !!!!
- new carburetor
- Getting a fuse box through a tiny, engine bay hole.
- '84 PU low power (secondary not opening?)
- 3vze power loss!!! HELP!!
- Noob 22re Question (belt tension)
- Stock Rear Drum Brake Question.
- 3 inch lift for 85 stright axle pickup
- what is it
- Extended bump stops
- 1984 body swap thread...
- 22re cam wear ?
- Idle Bump for A/C - Need Help Please
- Where can I get a roll bar?
- whats this worth
- distributer problem
- lunchbox locker
- my new to me 1985 4runner
- Steering Noise
- running w/o doors
- 22RE Turbo - Off-road Behaviors.....
- brake master cylinder fitting
- special knuckle rebuild tools?
- webber carb for sale
- online FSM?!?
- radiator ???
- High Output Alternators - Question About wiring
- K & N filter
- Seats In An 88 Pickup Reg Cab!
- 1st Gen LED Brake, reverse and signal lights
- almost finished building
- On Board Air ?
- wtb:interior door panels
- Spark Plug Recomendations.
- Nineteen-Eighty-Five-oh
- 85 ext cab build up with pics
- Need some photos of 4Runner tops
- what backspace for 35/15.5 tires on a 15x10" wheel, on my 85 pickup?
- Where should I get my parts?
- 85 Auto tranny
- 85 pickup brakes
- What should I sell it for?
- efi swap problems
- Missing 22RE
- Interchangeability between 85 & 89 model years?
- bought an '85, need some help, fuel problems
- Yet another 'should I buy this truck' thread!
- Replacement truck cab...
- Small plate on rear leaf springs??
- Front seats for an '85?
- 22r exhaust
- Need Springs? Check this out
- allpro 5" stock length fronts
- Coolant Leak, front of engine
- good thread for a 22r reinstall
- I need some door panels GREY W/POWER WINDOWS
- Fly Wheel - differences between '85 Runner W56 and a '86 4x4 22R PU G52?
- Lift Kit Questions
- SR5 Gauge Cluster Question
- D'oh!!! Time for a new Clutch! Options & Opinions!
- Rear axle blew out oil and now makes noise, what did I wreck
- extended front brake lines
- Pictures of 85 4runner, possibly for sale!
- Thank God for Glock - A story of an almost stollen 4rnr
- window mechinsim
- Prepainting Advice
- 4 Runner Rear Seat Options
- interior questions
- thinkining of a 1-2" lift, allready need new shocks
- HELP!: 22R with engine/fuel loss while shifting...
- what octane gas is the 22re designed for and what do you guys use?
- i need new shocks, what do you think of these?
- Coolant in oil?
- spring question
- Got the old runner dirty last weekend
- Wild Runner
- auto trans shifter
- door panel idea, bumper brackets too
- Temp. difficulties..
- Compression
- i think i'm burning oil....on a rebuilt motor?
- is it possible i've lost L4?
- 22RE Oil Leak
- Running gear fluid changes (quantity, type and labor)
- Looks like I'll be doing a body swap...
- A Dedication Montage To All 1985 Model Toyotas...
- Ignitor or something's broke ...no spark no start
- downeys leaf packs & shock ???s
- Can someone identify this gear ?
- 85 Front Clip
- 22RE TRD Level 1 Camshaft
- 84 cab on an 83 frame?
- 85 Lift Kit Questions
- Rears up Front
- where do i look for?
- webber carb connections?
- auto trans and body lift
- 1st gen 4runner body lift
- rearend main bearing
- no oil pressure
- 84 2wd frame same as 4wd?
- Questions on tire clearance??? And 2 inch rancho springs
- different idle after test fit isr
- 22RE Running Help
- Sky Crossmember Install - Help
- Nut / Bolt question - size/tpi
- repair manuals - Clymer by Lahue and Max Ellery book?
- Lift shock lengths needed....
- I have 2 fuel filters???
- 85 toyota pickup suspension lift question
- 94 Toyota Truck Price
- Converting truck to 4Runner.
- best way to move front axle forward?
- Got The Comp Cam In. Now For Header
- makeshift tool box / bed enclosure?
- Grounding battery
- Scratched Glass - How to repair?
- wiper problems.....
- `84 distributor in an `85?
- Weber carb ?
- Back to the Future III
- Tranmission/ lift problem
- Fuel Injector Help!!!
- rear springs up front?
- Strigth Axle Traction Bar
- Need engine wiring harness
- Engine Wire Help, 1984 22R.
- What is this switch for?? (pic inside)
- California registration issues. Anyone experienced anything like this?
- 95' 4runner problems!!
- transfer case
- Shackle Question
- where to get camden rebuild parts
- R.i.p. 1985 4wd
- help with 22re conversion
- the big brown truck came yesterday.
- Is an oil cooler really neccessary?
- inclineometer
- How long do Detroit's Last? Found a deal...
- mercedes diesel swap?
- hacking the fenders???
- brake and charge light both on
- jUST BOUGHT AN 84 RUNNER suggestions on some new or old products?
- EFI Question: Should this black crap be here? I don't think so.
- Over Heating :::Need help:::
- 22R Stutters
- Confused fuel gauge
- transfer case gear oil
- Aussie locker/ 4:88 gears
- Cross Over Stearing
- Adjusting weber carb?
- bidding on ebay
- Minni Truck Third Member VS. IFS Third Member
- hub fluid
- quiet muffler for 22r?
