- should i??
- No headlights, help
- gas in reed valve
- Want to show off my new 4Runner
- Newb here, just bought an 85 Runner. (question)
- Looking for 1st Gen 4Runner on Taco frame
- SR5 Decals
- * Metamorphisis *
- I got some cool stuff
- A340H auto tranny.
- problematic 22re, need advice
- 84 pickup
- Help with spring hangars.....
- timing? pics included no 56k
- Factory Power steering on '85 4runner??
- V6 Diff help
- 7 inch lift question.
- Question
- Unplugged TPS on 22re
- Transmission mount??
- vacum lines
- Just Curious...........
- 1985 4runner hard cold start
- yay new toy - ota :-) 1985 EFI
- Not Holding RPM
- 22-re head gasket
- Skid PLate
- runnin rich
- looking for suggestions on a lift..
- No rear heat.
- name that engine noise (mp3)
- New guy with exhaust question
- BJ spacers pros/cons
- New project toy. (picture heavy)
- HID on first gen 4runner. Will D2S bulbs fit?
- To sell or to part out '85 SFA\EFI 4R?
- Front Turn signal Flashes Fast
- Lower Balljoint Won't seperate from knuckle!
- The many uses of 4Hi and 4Lo?
- Ordered my Aussie Locker
- swing bearing squeal?
- Questions about '85 SFA
- Pro Comps?
- Help with Lift/Tire sizes for a wheeler
- Very well built 84 Runner on the Bay'
- Questions about gears!!!
- Been a busy week...
- Just curious....
- Rear Axle
- 85 runner with broken leaf springs...
- noisy 22-RE
- Will these tires fit?
- is this a good deal?
- Need New Front Springs
- Idle issue when pressing brakes
- Want to know: rear diff options: lsd, detroit,...
- My First Runner......
- Surging issue when starting in 1st gear
- cost of 22re timing service
- dose any one know if this will work?
- I thought I broke a birfield but didn't?
- What gear is in these rearends?
- Advice please.... should I be concerned.
- oil leak
- calling all you body lift guru's
- Power steering pump Info
- just got some new paint
- Did I get a bad water pump or is this the Timing Chain
- timing chain marks on toyota 1985 truck
- Major Engine Oil in 85 4runner
- 1985 toyota 4wd truck cylinder head change has led to more problems
- 1985 toyota 4wd truck problem
- 4.7 T-case gears?
- lifting the front.
- Is it worth it?? Rear drum swap......
- service Manual for 85 4runner online?
- Driver door dome light switch, wiring issue
- Headlight issue
- 84runner leaking?
- My 1985 pick-up rebuild
- 86 Toyota Van for sale- its way cool!
- 87 Turbo 4Runner: Rebuild Tips/ Parts/ Turbo
- sputtering
- no rear brakes
- water pump noisy?
- Missing Dashpot and VTV
- 3.0 Yamaha V6 In a Runner?
- Air Pump
- cracked downpipes?
- quick dumb question.....
- Strange starter issue
- tow hitches that fit a 86 2wd reg cab?
- um.. my muffler exploded...
- Break light switch?
- 22r hesistation
- Best lookin' truck on eBay...
- Broken Wheel Lug
- here she is
- gearing question
- front leaf spring hardware
- 22R engin lift points
- 22re Swap?
- wheel spacers and shackles on an 85?
- 85 runner for sale
- Hard Starting
- Crazy idle in Hi but not in Low
- 89 thru 95 60 / 40 split in 85 xtracab
- Third Member Help
- Rear Springs in Front
- carb. 22r trouble
- Stock Steel Wheels
- a340h problems: no 3rd gear
- Front track bar 79-85 toy 4x4
- Hard Starting??
- Bumper help......
- Can I run 32" tires?
- Carbed 84 Runner Engine choking out
- 85 truck.. something leaking on front tires
- level height susp.
- '85 4Runner rear brake upgrade?
- '84 Diesel pickup 4WD
- New owner overhaul...need advice!
- Idiot lights won't go off! (85 4runner, 22re, 5spd.)
- single or double timing chain?
- whats more likely to fail first?
- Priming Oil Pump
- How to identify a 5-spd
- no welder and 63"s
- heater system Question
- Mudding season = seller's market?
- too many changes
- 1986 Toyota 4 runner with 4.10's
- Quick question about injectors..
- gonna do an oil change today, have 10w30 now, want to go 20w50. 22re
- solid axle flexing
- 85 4runner leaking water into the cab, i'm puzzled
- '84 4Runner - No Dash Lights
- no spark??
- work in progress, custom convertible pics
- Timing chain, halfway there!
- Does anyone have their stock tie rod in the garage or basement
- 22re valve adjustment
- RTV or Gaskets?
- 1st gen runner (1984) Shifting Questions.
- 22re hesitation
- 85 4runner sr5 5 speed problem
- 88 22re/a340 drivetrain into a 84 pickup?
- I got a 1st Gen!! woo hoo
- Buy another '85 SFA\EFI SR5 4Runner?
- 16" wheel on 85 4Runner
- Redline weber missing part
- newb Q: 85 4Runner to Pickup conversion?
- Chevy springs in the rear?
- lift height
- Should I buy - be quick
- emissions deletion????????
- 85 4Runner t-case gears
- Vacuum Line
- building own leaf pack
- '84 Runner Skid Plates?!
- 1985 4runner trailer wiring
- New BUDBUILT shock relocation (bolt on kit) worth it?
- trade?
- Progress on the '84
- tall tires
- 84 tacoma doors on 84 hilux
- Little help with the drum brake removal 84 4runner
- Fuel Pressure Gauge (22re)
- 4Runner top vs. Tree root
- Who has installed a Safari Snorkel on a pickup?
- Parts wanted 4 a 86 4runner
- oil pressure
- Im desperate need info!!!
- Few general ? about an 84 2WD
- SR5 cluster swap
- lift blocks for my yota???
- 20r/22r hybrid running issue
- 12 flashes from my check engine light
- rear spring options?
- 84 quadcab diesel on craigslist los angeles
- 22RE Eating Oil
- NEWBIE ALERT! 84Runner Lift Help
- Help me figure out my 4x4 situation
- 85 yota with 302
- how much could i get for my yota
- Best shocks for '84 Flatbed
- Mystery grinding sound right front wheel
- Power Up Lubricants
- oil sending unit
- bed Question
- clear corner lights 1985 4runner
- GREEN spark plug wires
- limited slip
- 20r head on early (1984) 22r block
- oil leak out of dipstick?
- 1985 SR5 parts
- 85 stock suspension questions
- Weber 34 Setup ?'s
- Heater/AC vent cables
- Which engine?
- 1984 pick up electical problems
- I need some help from an 84 owner please
- overheating, fan clutch, normal temperature
- 1985 4runner clutch
- rear leaf spring replacement
- Would you buy this as a project truck? 85' 4runner
- Ebay lift kit for light trail use. Opinions
- Build up 84 pick up
- New '84 4 Runner... steering?
- New '84 4 Runner... idle?
- Exhaust System...
- Need some help
- carb problem( help.)
- Truck is shuddering at 30km/h?????
- Strange Click noise
- 92 3.0 4runner wont turn over
- Coolant squirting out the radiator on start up
- Interior help.
- head unit install questions
- 84 22R + MSD = high idle?
- 84 Runner build up
- leaking clutch?
- Overheating after timing chain job
- Crazy '84
- 85 pickup cab (craigslist.com)
- 88 4Runner found on craigslist
- Rebuilt front axle- LEAKING
- Looking for Toyota Specific Mechanic (or shadetree mech.) in NJ/PA/DE
- thickness of floor pan sheet metal
- Atypical disc brake conversion
- Rears up Front
- 85 yota 4wd locking front hub?
- Speaker mounting, pod or other, PICS
- 84 Toy, rough idle cold engine only
- I have 2 charcoal canisters?!
- whats the top speed on my truck?
- Timing Question
- my 85
- Overheating ... yet another case
- 4" susp lift drive shaft spacer?
- Weber or OEM?
- 4x4 vs 2x4 Axle housing tube diameter?
- 1984 4Runner Trans Question?
- Need a little more help.
- 4Runner Alloy Rim Lug Nut Type? Conical v. Flanged
- Need some help.
- surging at very light throttle
