- 85 4x4 P/U 22r engine mods/ups
- alum. radiator?
- Miss in motor
- so im buying my buddies 85 pickup
- Pics of my new TOY
- how do i take out....
- 85 automatic problem
- 22RE Vacuum Hose
- Tail light, flasher, blinkers (w/e you call them) are not working.
- funny running engine, help!!
- Where can I find an OEM 1984 Stereo
- Couple engine questions
- New Project: 85 SR5
- Need longer wheel studs
- Tail Light problems
- Xtra Cab VS. Normal Cab
- Where to buy parts?
- Shot bearings?
- possible to make crossover steering??
- 22re using oil
- No Brakes
- I'm an idiot, help me out.
- 85 P/U with a whine...
- Downey 3" Lift
- Brake Line?
- auto to stick change
- Marlin T-case Question, Help me decide
- Shaky Ride
- New Wiring?
- seat covers for 85 buckets?
- Newbie "ram-air" intake/cold air--Home made
- Got a weber 32/36...
- Reaer shoulder seat belts in 1st gen runner?
- Pinion angle woes. (pic included)
- rough ride
- Engine stalling/ hard to re-start problem
- talk about gears
- 22re electric fan
- 85 SR5 22R Restore Questions
- too much stress on 22re with 38s
- fuel injectors
- Fuel Pump Failure
- Gas in oil?
- Broken Valve Springs
- pickup to runner?
- saggy spring syndrome
- crazy high revs at idle, and while driving
- 4runner soft tops
- Looking for truck bed
- 85 TOYOTA possible purchase
- which tranny/transfercase is this?
- Big Block 4Runner pics wanted.
- Width between bumper brackets.
- Play in steering... Steering BOx?
- removing leaves from OME spring packs, bed back from paint
- bed swap question...
- My boy's '85
- what do you think its worth
- seats and harness?
- Tranny question R151F
- 4 Low, gear change question
- 85 4Runner tranny Q
- more Steering 101 questions
- SFA OME Kit Installation - write up
- A/C Question
- fuses blowing
- One reason to love a toyota..
- T.d.c.?
- Upper Tellico Rally Going On Now - Show Support
- Hubs???
- pics of my progress on my 85 4runner
- Just got a '84 Pickup, thought I'd share.
- Need help badly with 84 cab and bed on 90 frame
- Crossover steering, Why Not?
- new guy here, got an '85 4runner, going Xcountry, got an issue, help if you can..
- rancho 3" lift kit?
- What frame can i use on 84 ext cab 4x4
- Starting my 85 build up
- 1985 4Runner Wheel Bearing Change
- allpro crossover steering w/ double front shocks?
- weber carb question
- Anyone looking for a 1985 single cab?
- What to look out for on 85 PU
- What is this?
- Marking arrow on 22R oil pump driven gear
- air fuel mixture screw
- tryin to keep one cool
- My 85 4runner new pictures, bling, bling
- 85 leaf spring swap
- Power Window Question
- Flat bed pic!
- I don't want a lift, just better springs
- help with 22r
- 3.0 Header question
- Wiring fog lights
- 85 4runner good or bad buy?
- Rear quarterpanel trim on 4Runner
- The good and the bad about 85 toy pickups?
- Best looking front bumpers? (Pics Please)
- shifter thread?
- Vibration and Supra Brake Conversion
- 84 altimiter gauge ?
- Need tool to set up shims on solid axle
- New Engine (blow-by)
- Fuel Problem
- got a shortblock
- Weber 32/36 issues...
- 85 auto Trans probem need help
- Vacum leak--Help Please
- Smog pump and A/C missing
- So i passed inspection
- 84 Toyota Diesel
- Frame repair help.
- Water coming out of exaust... Bad?
- Att. all 22R (carbed) owners w/ SR5 gauges!
- White smoke at startup
- 1985 Toyota Truck 22RE Intake Leak
- 1000 dollar lift
- 22R valve train noise
- electronic exhaust cut-out question.
- Help with trans issue
- Question about removable tops
- Trail Link Suspension
- Help, Spun Exhaust Manifold Nut
- T100 Rear Axle in 88 Runner
- 85 PU straight front axle
- Newly acquired '85 4Runner
- Extended brake lines
- 22RE running rich
- lookin for more clearance and maybe some flex
- lengthened wheel base 85 yota
- What is this?
- 22ER Power up grade
- rear heat delete?
- scored some good parts!
- When wheel is turned knocking noise from front right of axle
- other tail light options?
- Suspension and Steering 101
- Bent front axle housing repair?
- HELP! Truck wont idle.
- brake lights always on
- SA to IFS Brake Conversion
- 85 22re Auto tranny Repair manual
- Shock Question
- Shaky steering 85 PU
- 22re falls on its face at 3300rpm (gutless)
- Newbi here w/? about an 85 pickup
- 86 22RE radiator to 22RET radiator swap
- 85 4x4 22re can it be brought back?
- How do I rebuild my G-54 Trans?
- what parts are needed for a rear brake job?
- help, engine blew a sparkplug.
- Where is my diagnostic terminal?
- are 95 4runner and 95 pickup bumpers interchangeable?
- Heres my new Toy!
- SR5 or not? Gauge Clusters also
- Inspecting used head, 22re
- something to make u laugh
- 22R won't idle after cruising on the highway
- Look what I found.
- lower front bumper valance?
- 22RE Tapping Only After Engine Is Warm
- My 85 Runner project.. opinions please.
- 2 unknown vacum fittings on underside of aircleaner
- Weber 38 compared to EFI
- TOYOTA 85' overheating!1
- Clutch type posi up front?
- 85 pickup 22re or 90 pickup 3vze?
- 22r intake mod?
- i cant find the thread
- my dream
- New engine - no oil pressure
- Newbie with Transmission ID ?'s
- 85 yota pickup e brake cable removal?
- so here's the deal...
- 1985 4runner found!!!
- pickup or 4runner
- checking out an '85 4runner, input needed
- in need of new lift kit help me out
- performance cam
- thug
- Sr5 Dash Install Issues
- 85 22r reg cab 5spd or 85 xcab 22re Auto
- New guy: $100 '85 Pick-Up
- 85 4runner FSM
- Putting my knuckles back together (quick question)
- Intro, crossover, OME and sway bars
- 85 4runner suspension
- How to adjust the throttle plate
- 85 yota pickup cage in cab
- Carburetor shaft bushing?
- My Project Truck is Finally Here!!
- What filter is that?
- guaging interest in my truck, detroit area
- How Does yalls look so much higher
- 85 Pickup Body Lift
- rear springs
- why not body lift
- Dash removal (ac controls)
- 1st gen Runner factory front spring length
- Just Bought a 84PU, Got $3k, What Can I Do?
- 39.5 iroks?
- Custom CB and iPod Console, with Shifter boot upgrade.
- what lift for my 85 4runner
- Interchangable seats???
- Problem with rear brake locking up on 84 pickup
- Rear wheel cylinder on 10/85 build date
- Proud owner of an 85" 4runner SR5......
- 84 22re overheating
- so i got a death wobble?
- What would yall pay for these two 84 PU's?
- Most rusted SFA in a daily driver ever?
- a/t or t-case problem.
- NO power whatsoever
- 85 pickup carb or EFI ?
- Tranny model number?
- 22re intake manifold removal
- Big trouble, cracked hub body, can I buy parts anywhere, or just whole replacement?
- jonney or heim???
- conversions
- 3" Rear Lift Springs / 84 4Runner
- 91 PU 2wd axle on 85 4runner swap...
- tire size question
- 85 4runner to Truggy @ ORS
- convertible 4 runner
- Downey Exhaust system
- 84 motorpic request
- electrical problems
- Assisstance Request: 1st gen Runner and Tape measure - inquire within.
- let me know
- Help - need a photo of an engine compartment
- Lift spring question
- my tires go \ / then / \
- Value $ 1985 4runner SR5?
- quick question
- no oil in the oil filter
- MPG for stocker 1st gen runner?
- A304H Tranny Questions
- Sale truck found in Fl.
- Storing 85 4Runner
- 5 spd Tranny?
- Birfield Joint
- Valve cover removal
- clunking noise
- I Have An 85 Efi 4runner How Do I
- Odd Vibe??
- engine rebuild parts?
- Truck hunt!
- Front Tow hook bolt specs?
