- temp gage semi broke
- high steer
- Question About Front Door Panels, Please Help!
- whats a good brand of body lifts?
- abalone shell in my shifter knob
- 4runner forum
- Whats this plug for?
- vented rotor question
- What is this REALLY worth?
- looking for ecu
- NEW half door design
- my 84 Toyota is getin 15 miles to the gallon
- Help coverting my '85 xtra cab to efi!!
- Gas tank lift?
- 85 22rec gutless, fuel dumping
- where can i geet one of these?
- wildest jimmy rigged trucks you have ever seen?
- so i have to pull my T-case
- Removable Windshield
- 33's or 35's ?
- Removing lspv
- 1984 toyota axle questions???
- Spring Shackle Bolt HELP!!!!
- can anyone help me out im looking at an 84 toyota PU. need to know if its trouble.
- 84 pickup charge problem
- '85 4x4 trucks and 16" wheels
- 4.88 3rds in a 85?
- Finally got a wheeler got some questions
- Instrument cluster wedge bulb sockets
- Cluster Swap
- I'm looking for some springs
- steering linkage problems
- Rear brake cylinder question
- In dire need of help
- $10,000 4Runner
- 2.5" pro comp leaf?
- i need all the advice i can get
- Which carb would be best for my 87 PU
- 85 Turbo Gas SR5 PU 2X2
- '85 pickup woes
- rear window
- Toyota Blues
- MAJOR SCORE!!! Free 91 4.3 4x4 truck!!! what to do now?
- 1st Gen 4runner and Pickup In Cab Cage - *NEW PRODUCT*
- Look what i found
- ecu
- 85 frame swap
- Leaf springs snapped!! My truck could have killed me
- j-arm?
- Cab Swap
- 5.71 gears!
- Pickup wont pass smog
- 1st gen 4rnr as a DD?
- 85 cali 22r carb w/ 30k miles on oxy sensor question. HELP!!
- 22r Carb Upgrade
- stock steering?
- add a leafs?
- Gear question. Could this be right?
- *UPDATE* Oil Pressure Problems
- 20R Expend gas as a 6 Cilynders, please help!
- I'm absolutly stumped. (Timing chain related.)
- one tires left other one is straight...
- 84 5speed in 86 pickup
- front & rear shock mounts MAUI ONLY
- My brake upgrade experience
- coil mod in the front
- 84 4x4 Truck could use some help and good advice
- 85 4runner Windshield
- help with 85 pu noise
- Rearend shutter coming out of first gear?
- help...puddle of oil under rear axle
- getting a bunch of yota parts for 84-85 trucks and runners
- 4RUNNER shell on my 85?
- Halp!!!
- Towing Boat with 85 PU?
- Grinding Sound in Tanny
- where to get good rebuild kit for 22r
- Oil Pressure Problems
- 85 pu bed problem
- Lets see what ya got!
- What Year/Model Toyota Pick Up Truck for....
- 22R Oil Pump Removal...
- Knuckle seal replacement...
- I nearly cried...
- Toyota Hauler?
- 22r Carb Tuning?
- repair and resolve 3.0 v6 3vze head gasket
- Some ideas
- Idle Speed?
- driveshaft question?
- drag link HELP!!!
- Timing!
- A few new mods
- Tilt wheel in a 85 runner?
- 4" lift HELP!!!
- 2nd gen needs IFS steering now
- blown tranny NEED HELP
- 85 extracab driveshaft length with crawler case
- Are "MONROE" steering stabilizers and good for our trucks/runners?
- Hello, just bought a rig:)
- broken drive shaft??(camping trip fun!)
- Newbie Here with a new ride
- Brake Question
- 85 helppp
- 85 pu lift problem
- Oil Problems
- 84 P/U Build, 22 r rough idle
- why is my 22re idling so high?
- 1986+ Wheels Dont fit my 1985 4Runner?
- 85 22re blowin black smoke
- 85 4Runner bumper...
- 85 4Runner
- Help! Severe drivetrain noise
- got my weber hooked up
- Rear End Issue! Please Help!
- 22R seems really slow
- Help!!!
- New guy needing opinion!
- 2 Q. Where is the transmission fluid dip stick? can i use low range in 2 wheel drive?
- injector maybe? need a hand
- slider window
- 1985 ShortBed SR5 (EFI) For Sale
- fire, Fire, FIRE!!!
- breaking in new gears
- Frame off resto progress, parts ?'s
- Question on Removing My 87's Top
- 85 pickup pulls hard right when breaking?
- 85 22re gettin hot
- Did some body work to the Runner
- Suspension woes
- turns over.. kinda
- Help!!! No spark!
- Pic of project 85 4runner
- Running 4.11 in the rear and 5.29 in thr front
- My 85 4runner new pictures w/33's
- Rebuilding a rear diff
- Replacement vinyl/carpet flooring
- Gauge Pod Install
- What makes an SR5?
- 32's with auto?
- my "New" soft top is missing parts
- 85 rebuild ran perfect now won't start
- How Hot Does Your 22RE Run?
- 85 4runner Hodag Mudder
- 85 4runner lock set
- Expert Needed!!!
- In NEW JERSEY: friend needs help reviving 85 runner
- 4" ProComp 4 spring system?
- E-85 gas?
- Conversion from 4WD to 2WD
- shock questions
- I want to do a frame off restoration
- help with body parts
- I've been busy! Check it out.
- weird noise
- Post your MPG here. Go!
- 1985 4runner electrical prob
- Pics of Hardtops
- Questions on donor swap.
- engine swap question.
- My new 85 4runner
- Front end sags
- help me diagnose my problem (axle related)
- Help! Guru needed, steering gear seals
- Motor Troubles... Please help me get back in my truck.
- Just thinking about selling my 4runner
- i lost 1st,2nd and 3rd!
- Heater core replacement
- Sending out an SOS
- 85 4x4 22r losing power and bucking
- 22r rough idle after downhill
- 20r head on 22r block?
- replace rear bench seta with buckets?
- My '85 4x4 Custom Cab
- 1985 4Runner Tail Pipe turbo install
- 84 pickup-2wd
- Need help with brakes
- Project: 3 in 1
- BVSV, plug i.d., and thermo sensor. 85. Help
- AZ:Oil Leaking Front Cover?
- 1985 4Runner Project "Boobie"
- Disc brakes
- a/c problems
- does anyone make a camper shell for an 85 longbed singlecab?
- 84 22r runs HOT
- 22r Carb/intake Manifold Upgrade And Emmissions Removal
- light bar
- Quiet muffler, good flow?
- Pics of your 84/85 rig.
- 84-85 black or chrome grille / brush guard
- Heater control trim
- Need help with identifying this
- Replacement fuel cut solenoid
- Body lift on an 85
- Best Body Mounts or Body Mount Review
- Injector plugs
- Need a 22re EGR temp sensor 1995
- 85 Utility Truck VS 85 Pickup
- Seats for '85 Pickup
- Carb Spring
- locker opinions wanted
- Chico's 85 toy
- Exhuast question
- lift?
- 3in Rough Country Install??
- motor help asap
- i need assistance
- What is this truck worth?
- Help!! Truck Needs To Get Sold!!
- frame help PLEASE!!
- auto to stick swap
- Thanks Budbuilt!
- Lift help with NWOR and All Pro
- Electric Window Switches
- axle swap in 85 4runner?
- my NEW FREE toy
- Info about A/C needed!
- Master Clyinder
- Front Leaf Springs?
- Rattle/Clicking from Front End
- 84 Toyota 4 Runner 4 Sale
- Oil leak please help!!!
- 1985 SFA - 2.4L Turbo Diesel
- May be gettin a 4x4
- Manifold stud Size
- Marlin?
- Exhaust help
- Longer Shackles
- Possible exhaust leak
- Help with my upgrades for my new yota
- Lift
- Aux Fuse Block
- quick tire size question
- Will I need powersteering
- 84-85 pickup Wheelbase/Track Width?
- Looking for 1st gen 4runner interior pieces
- 84 clutch not disengaging very well
- 1990 toy lift
- im doing rears up front and i have a question
- 84-85 Import bed
- My situation: Lock right or leave open?
- help increase hp and mpg of 22r
- Some interesting and potentially helpful EFI conversion info
- Taco brake?
- Please help!!!! Automatic transmition
- Auxillary wiring circuits
- '85 Pickup Lift
- Seats for 85 Toyota's
- Pickup VS 4Runner
