- I need some body dimensions
- 85 4rnr 4.3 swap pics
- new motor, new gears?
- dimensions of coolant hose above alternator
- What is a clean 85 sr5 worth?
- Adding Intermitent Wipers to an '85 Pick up
- cherry red catalytic on 84 carb
- sm465 trans?
- Fix It Up Or Part It Out? Thoughts?
- 84 toyota heating and carb problems
- Buying a 22RE in an 84 chasis with 7" lift
- what did i do now?
- Help I'm stupid
- engine temp switch.
- 22r, how to set the timing
- girgling sound when I press accelerator
- power steering pump noise? extreme frustration
- check for oil pressure w/o gauge?
- power steering pump, what's this?
- Show off your suspension lift
- elbow on valve cover?
- permatex for valve cover seal?
- bed question?
- 84 toy starts but dies
- craigslist post
- broken bolt, opinions
- Myth/theory of the 22re Cracked Block
- 22R engine swap (the easyest)
- wont idle
- Run-out '85 worth anything?
- Carb not working properly, any advice/help
- Timing chain cover wear through coolent in oil help!
- 20r header fitting on a 22r?
- Clutch problem
- pulling dash apart?
- Slowly failing clutch, is it the master or slave?
- Craigslist Find, If You Don't Buy, I Probably Will
- Craigslist 1985 4Runner Heads Up
- new engine help
- head gasket breakdown, now what. Take a look
- Leaf spring advice
- oil cooler?
- wheel ?'s
- Just Got In My First Wreck...And Won *Pics Soon*
- Tps problems
- new head gasket/replacement?
- help need a picture on a 854runner
- help im new to toyotas
- Let the project begin!
- 84 22R carb runs horrible!
- Anyone real good with MegaSquirt and DIY Autotune?
- Another lincoln locker question
- 3rd gen seat in a 2nd gen
- Someone here will need this.
- hysteer Q's
- What to do beat up 84
- 22r rebuild Q?
- Where to buy a 22re cylinder head
- chevy 350 swap
- Cylinder Head Rear Plate
- Building it Low
- 3.8 swap
- Front solid axle rebuild...help
- rears up front
- 2 Plugs behind cluster?
- 22r dies on ilde, misses
- Allpro or marlin
- getting a 84 soon
- 22R Mysterious oil leak
- how many degrees to run timing at
- Starter trouble
- Header advice?
- How much do Toyota parts weight?
- How to Rebuild Your Carburetor - Write Up
- Photoshop help
- retro coverage
- 85 Manual Trans Neutral Safety Switch???
- New to 1st gens....
- Rough Idol 22RE
- Glamor Shots
- Exhaust manifold/muffler bolt stripped
- well i might be sellin my baby
- My Baby!
- Solid axle hub/caliper questions
- egr help
- Is it just the head gasket or more expensive???
- Need some help with '85 22RE cooling sys
- So...
- Front end help
- rear heater removal
- Water Leaking Into Ca
- fender flares?
- engine swap for efficiency and added power
- 84 shifter seat removal - help
- 84 22R temp guage never rises or blows hot air
- Brake problem!!!!! Help
- Motor mounts ?
- 22r wiring harness
- Stagger Lee's Thread (pics large)
- Timing issue, I am stumped. ESA?
- headlight issue
- Exhaust???
- EGR Replacement Questions, 84 22RE
- 85 22re motorhome LSPV brake question
- rear brake question
- 91 22re head on a 81 22r block
- GenIII 4.8l v8 swap in 85 toyota, help
- engine swap
- ride quality
- Intermittent Wiper Question
- v8 swap anyone??
- starting problems
- 1st gen 4runner seat fix
- What 3rds will fit?
- New 1st Gen Runner guy..... couple problems/questions
- Rod play on all 4 cylinders
- First Gen 4runner Rear Window Regulator Malfunction
- Cold Start Issues
- Looking at buying a built yota
- Whats the best performance mod?
- idle rock/4wd issue
- head question
- 22R help clanging investigation
- no power
- '85 Pickup 22R Flooding
- Need help w/a decision quickly
- Supra engine swap
- To buy or not to buy?
- 22r missing at load when cold
- hubs
- 22r to 22re parts list?
- m10?
- 85 4Runner Help?
- Body Parts
- My 85
- new to me 84 with leaf?
- 22re Ecu
- Wheel bearing pre-load problem
- 2wd transmission
- Looking at this 85. Thoughts?
- 85 toyota
- what kind of transmission is this?
- New toyota owner with lift ?s
- Props to Everyone in the Northwest with 1st gen 4Runners
- Body Parts Replacement
- 1994 4runner alloy wheels chrome? oem ? look
- transmission wont go into reverse
- Stuff for my '85 SR5 EFI 22RE
- If you changed the temp gauge sending unit, come in!
- Self Repair of crashed '94 truck possible?
- 85 Pickup with Buick 4.1 - Need Input!
- not getting fuel?
- quick question
- My new project -- 1985 Runner
- Help! I can't play in the snow!
- How's the auto tranny in an 85?
- '85 runner seat belts
- Need Help! Urgent!
- Best oil pump seal mfg.?
- Help!!!
- no nothing
- question aboot one vacuum line
- '84 4runner value
- What kind of tranny is this?
- I found a donor motor!
- 1994 Pu -> 1985 Pu
- Will Bilstin shocks from a 99 prerunner fit my 86 4Runner?
- Hello & Thanks
- 84 Alternator
- My intro, who is this 86tuning guy?
- taking off the cab of '84 to weld frame
- Steering link upgrade for lifted pickup
- new pick up
- New to Me 85 pickup
- steering cocked
- Gears & Non 4x4
- tough starts in the mornings
- tacoma bed
- upgraded headlights for an 85
- Have to pump gas to get the motor to turn over
- Front locker issue
- speedo cable possible making noise
- what tire size are you runnin?
- alterations on my body
- Carb savvy?
- '85 4Runner Cleanup...
- Half Doors / Fiberglass Top
- heater problems
- 22rte wont start
- Hard Start
- 94 4 runner wont start
- What to look for once the head is removed.
- lifting my 85, what do i need to look out for
- Rear brake cylinder replacement Q
- 85 4cyl carb xtra cab long bed 4x4 opinions?
- What do u think?
- 84 4runner good starter vehicle or not?????
- Heater set up
- windshield wipers and fluid problem?
- Questions regarding a 1.5in shackle lift on my 84 4wd p/u
- No power to fuel pump with test jumper jumped
- Cold Start Injector issues with hotwired start! ahahahhahahhhhhhaaaaaaaa
- stalls while warm
- How to find TDC on the compression stroke.
- Rear brake replacement?
- Antenna Replacement..?
- 22 rec smog
- 22RE Intake
- show truck..............
- swampers?
- Question about replacing front main seal
- Stereo install, 12v acc, 12v always on, ground?
- tereflex
- Transmission Code 42
- Ac or heater blower?
- Black Smoke
- Hey you 85 guys!
- 22re Bottom End Knock.. help
- Temp gauge and oil pressure gauge problems
- 84' 22R needs 5 speed tranny
- heater core flush?
- while dash completely apart what to do?
- I may need a new motor. Aaarghhh!
- which header is better?..4 into 1 or tri y
- 85 22re RPM's wont come down between up shifts
- Timing chain guides broken - no noise from chain?
- Cleaning Switches
- 85 Grill Tabs
- Extra play in steering wheel?
- What's it worth?
- Rear Facing Seat? and 1 other question.
- Sea Foam... do you want the truth?
- Oil leak! Help please!...
- running bad
- UPDATE! con-ferr cab rack, 4wd pics, and MORE!
- Compression Test - High tension wire?
- 2 questions; center caps and SEAFOAM
- Dash Installation Help, temp controls ????
- bob job! sweet truck
- 87 Runner Back Seat Headrests
- Blinkers left blinks normal right is fast
- Rod Through Block
- 22R cam: install without doing HG?
- Sleeve for 22re crankshaft pulley
- Grey Carpet in good Shape
- How much would it cost?
- 85 Auto Windows
- 85 4Runner Seat belts
- 85 4Runner back window
