- VERY Aggressive Ping/Knock - (Sometimes - Not Timing Chain)
- '84 Moonroof Identification
- Converting to a tach dash
- flashing charge/brake lights
- Need help diagnosing siezed trans/clutch
- Looking for pics of installed fan shroud 85-ish PU
- Trouble Replacing Alternator/doesn't fit on bracket
- air in brake line?
- Is this OEM in the 85s trucks?
- Rear Lift Blocks
- Idle drops with lights in or fan on
- Frame #, pickup or 4runner?
- 1st gen 4runner seat covers?
- 22RE Sound at front end [video]
- '93 4Runner Weather Srips/Seals
- Guess I wont finish, selling project advice
- Gauges redone.
- No compressor, No AC. considering options, what's viable?
- quick question on fixing "high beams don't work" on 1988 4runner
- 85 SR5 4x4 Shaking on acceleration...
- 85 yota California custom cab build
- Fuel pulsation damper and FPR copper gasket part #?
- Intake boot between air cleaner snout and grill for 22R
- replace piston rings with head gasket repair?
- 85 4runner lifted loves to wander down the road
- Do factory Xtracab, 22RE, 4x4, SR5, solid front axle Trucks exist?
- 22R exhaust manifold question
- Awww CRAP! Bad or doesn't matter?
- 84 Pickup - 22R 2WD - Odd sounds during throttle
- 1.0KW or 1.4 KW starter for a1985 Pickup?
- Warm start
- Wire to tap for canopy lights?
- what turbo
- Broke a METAL chain guide
- WTF is this? EGR block plate
- 32/36 carb swap- throttle linkage question
- My 1985 Toyota Pickup truck 22R automatic is losing coolant out the exaust at 33,000
- 5 speed swap
- Things beginning to make sense, start circuit
- Side mirror upgrades
- A couple of wiring questions.
- Fuel pump
- 22RE Turbo Build Coolant Lines
- slow motion wipers
- Fuel Pump Relay above Steering Column
- HELP- window rolls down when headlights are on
- Lock cylinder, locked steering
- ECU-Engine harness firewall grommet availible?
- 84 4Runner, not charging and the charge light is not on.
- Sudden Hard Shifting?
- Going from 4.10 to 4.56
- Aftermarket gauges
- steering wheel removal
- 22r barely runs after doing valve cover gasket
- 22R oil weight and filter?
- Rotor! Amazon!
- AC wiring help so I can reproduce these
- Speedo Cable Tab?
- Looking For Reputable Mechanic that can work on 85 4runner 22re
- 1985 4x4 22r Front Axle Leakage
- Wheel hub inner bearing
- Pertronix in a 22R?
- Troubleshooting Speedo
- Another front cab leak thread.
- '85 Diver's side door jam switch/dome light help
- Air lift weight support?
- Speedo Out + Trans Leak?
- 22r weber 32/36 running rough in the winter
- What is this part leaking fuel on my 22re?
- Avoiding a lift kit
- 1984 4x4 pickup 22r dumping fuel in crank case
- I did it AGAIN! MCFLY 2.0 =). TONS OF PICS
- Tune AFM with O2 Sensor?
- 22r to 2L-te swap
- Dumb but I think quick question
- Cam failure
- 85 pickup rail back fuel system rebuild.
- Heat selection stuck
- 84 Pickup - 22R 2WD - Fuel Gauge / Mysterious Wire Harness
- 1985 4Runner
- Dash port
- Carb linkage part? What and how
- 90 pickup stuttering
- 22re overheating in traffic
- Check my work, carburetor
- Headlights not coming on
- I heard myself some rumors
- Did license plate lights come standard on 85 pickups?
- Ecm 89550-35300
- Charging system off grid
- 1985 Toyota Truck failure to crank over
- Toyota 1985 Pickup/4Runner FSM (Field Service Manual)
- Shock hoops roughed in
- 87 Toyota pickup overheating and stalling when not on gas
- Okay time for the ECM
- Terrible engine noise. Assuming it’s the timing chain tensioner?
- 1986 Toyota 22r AC Idle up diaphragm
- Any Hi-Lift jack hardware options exist for a bed mount?
- '85 Rear Spring Replacements
- 3vze crank no start help
- Wiring Harness, time to start from scratch?
- Need air cleaner assembly for 85 Toyota pick up 2.4l m/t
- 1000 on suspension?
- Groaning noise
- Weight capacity, fuel efficiency, u won't believe this... Mechman
- Softopper for my 4runner
- 1993 pickup AC port question?
- 85 Pickup Power Loss & Shudder @ High RPM’s
- 1985 4x4 rear wheel cylinders, 3/4" or 7/8" bore?
- Need Bed/Box for 88 Xtra cab
- EWD for 84 and 85 trucks/4runners
- Need help with 18" limited wheels, cant find front caps that fit.
- Fuel level sending unit.
- 85 4Runner gets HOT after regearing
- Adjustable Torque rod 84 4runner
- [Yet another] 22R Carb Float Leak Issue
- Top Weatherstrip between canopy/top and cab fit
- Front Axle Shim Setup
- Number “20” stamped in cylinder head
- 1985 22 RE...water in engine...help!
- Aisin carb high idle
- 85 22r running rich
- Transmission Swap issue - engine won't rotate
- Any idea what this PS bracket attaches to?
- 1985 4x4 pickup shifting into overdrive too early
- Brake light switch wiring question
- Interior piece needed for my 86
- 1984 toyota pickup 22re, 4th cylinder is dead, has zero compression
- V6 Brake upgrade caliper clearance on stock wheels
- 1985 22re Intermittent hissing sound after rebuild
- Fender guards?
- ID this connector
- Fuel pump problems
- Burned solid axle salvageable?
- 1986 CV Axle replacement
- OME for Roland
- NEW 22re Engines For Sale
- Charging Troubles (Need urgent help)
- 1985 22 RE EFI system fuel leak...help!
- 85/87 Transmission {5speed} swap ?
- Roof Skin/ Panel
- Steering wheel locked with empty ignition assembly
- ‘85 efi harness plugs (2 unlplugged)
- light system problem 1985 "SOLVED"
- Replacement vinyl carpeting for dlx
- Replacing the Timing Chain Guide on a 22RE Engine
- Steering gear box
- Starting issue with my 1984 22R
- 84 22re pickup electrical issues.
- Tonneau Cover.???
- 22r valve cover flame arrest or baffle.
- How much did I mess up?
- 84 Toyota crank no start diagnostic assistance
- Cold air intake for '85 w/ Weber 32/36 Writeup
- Need help after installing new clutch
- Ditch light mounts?
- 1984 Toyota Pickup 2wd rear wheel bearing replaced...still have noise?
- 1985 toyota pickup 22re xtra cab fuel level sending unit
- What Kind of Transfer Case?
- Any suggestions on installing a cigarette lighter in 1985 Base Pickup
- Diagonal Adjustment of Door?
- 1985 Auto 4Runner
- 85 4Runner time for new axles...is this configuration correct?
- 85 4runner lift kit options
- Common Issues
- Hose HELP!!!!
- Merry Christmas and Happy New Year.
- 85 sr5 door swap onto 84 pickup( Need help wiring power windows)
- 90' 4runner - New Battery - Needs Alternator or starter?
- 85 4runner build
- What else to do when I have the Dash Apart?
- 2nd gen 4runner custom front and rear bumper plans
- 3VZ-E Dead number 6, good compression???
- ‘89 Head Gasket blew: worth it??
- Found the original invoice on my 1992 Pickup. MSRP $8,998
- Need ditch light for my93 4 runner
- ISO Power Window Relay
- Planning my timing chain replacement on my '84 2wd
- My 85 22R Single Cab pics/questions
- What is the access cover for?
- g52 Transmission Issues
- Educate me on lug nuts
- Bumpers???
- Crackling Sound From Rear Wall of Cab
- Dang ol 3vz
- New here! Looking for recommendations
- You tell me...what’s wrong...
- coolant hose and plumbing
- 84 pickup with 22r, no spark with new everything
- New to me '84 - build(ish) thread
- ford two barrel carburetor on 22r
- 1986 fuel pump hanger fuel line to body...need a part number
- 1985 Rear Window Gasket for Extra Cab Trucks
- Clutch is not engaging
- Front axle hub dust seal PN
- 22RE Valve Adjustment w Go-No-Go
- battery mount
- Need some help on my 84 Truck Mud Flaps
- No start issue - 85 22RE EFI
- Decals
- Cold start injector - stuck or clogged?
- Guages
- Transfer Case Advice
- Tow Bar with an ARB front Bumper?
- 112 inch wheelbase driveshafts
- Where can I get adjustable torque rod?
- Top Shift Conversion Question
- Air trapped in heater core
- FJ alternator on 85 pickup
- 22re surges/pulses with throttle open
- Hard/Long Crank & Slow Start (cold or hot) '85 22RE
- Treetop hit my 4runner
- 85 Timing chain off top sprocket.
- Vibration on freeway 2wd pickup
- 1984 Restoration & repairs
- Crank bearing ID HELP!!!!!!
- Seized leaf spring bolts
- Knock/Clank Sound? [video]
- Power Steering system
- 84 pickup cab swap
- Tach/Dwell for 84-85's
- Torque Rod Solution for OME 2.5" Lift
- 85 Toyota gas tank fix
- Gasket Sealer Air Hoses?
- Owning an old Yota Pickup in snow
- Fan Clutch Leak?
- Cooling System Capacity After Flush?
- Won’t crank no power to cab
- 1984 Rear drum brake problem (HELP)
- Tie Road End Help
- Am I getting a good deal? 85 RE 2WD
- Are these hubs spinning correctly?
- 22R noise
- New crankshaft, new bearings, to tight to turn???
- Head casting flaw leaking oil??
- Truck won’t start
- Torque rod help!!
- Torque rod help!!
- 22RE - Cold Starts with CSI Unplugged Starts Instantly, Plugged in Takes Longer
- New battery and alt and still runs down
- 1985 22re - no high idle
- 94 Toyota pickup ext cab u-joints
- Master for 85 w/ vented rotors?
- Cold start injector time sw
- Trail Gear Suspension Rebuild
- Throttle position sensor
