- Sr5 Cluster Swap
- Fog lights
- 3 inch Procomp on 84 pickem up
- Wilwood rear brake proportioning valve and 1" bore master cylinder install
- windshield wipers don't stop!
- shackle HELP!!!!
- Wheel won't come off!!!
- OBA question
- which gear manufactor?
- New Weber 32/36 DGEV and de-smog, oh so niceeee!
- Possible Road bearings?? Need pro help
- stupid stuck intake manifold
- Rear window swap
- 22r running too rich help please!
- Best engine swap
- Brush guard or similar for my '85
- Change the good 22re into a 22r and put in the 83 or
- Knocking noise
- Stock Leaf springs
- Best spark plug for a 22r that burns lots of oil & other blow-by Qs?
- Big Radiator too cool for clutch fan?
- New weber, engine won't turn over
- quik ring & pinion question?
- Brake pressure/pedal problems
- What's up with the 84's?
- Heavy Duty Transmission, Transfer Case Mount?
- steering shaft
- My first flop, with pics
- Oil Pressure!! Won't Hardly Build,, BIG problem!
- Stripped dr. side steering knuckle rotor bolts
- throttle linkage issues
- Thinking of trading my 99 Tacoma for a 85 4runner
- Will locker from 93 fit into 85?
- 85 22re problem
- how to paint 4runner top
- Fuel pressure regulator w/ stock 22r carb?
- Timing chain?? please help, video's included!
- What to know when buying an already swapped toyota?
- Code 24,31 and 32 93 4runner 3.0
- 85 4runner front axle rubuild help
- more power for the 22re?
- leafs or coil
- The Cream Dream gets a paint job
- 22RE re-assembly..Quick Question....
- Quick question about auto trannies for 4x4 and 4x2
- radiator support advice
- Best for money flywheel?
- 85 Rearend Help
- Leaking fuel
- help with 22r head job
- Project frankenyota
- which long travel kit is best?
- Wiper delay relay
- Backfire problems
- 85 Toyota brake problem
- Engine Noise at Startup
- driveshaft parts swap question
- 22R Temperature Related Question
- Full radiator hose kit????
- 85 Rear Axle Rebuild Help!
- Junkyard door prices?
- over heating, electric fan questions and diagnostic help
- 4runner top window rubber
- Crossmember bolts
- High Pinion front carrier install questions.
- 60 miles on rebuild, very white plugs, stock carb
- The problem that won't go away. Hesitation, lack of power.
- grease on floor boards
- No power and overheating
- drag link
- cheap spare tire rim
- New Suspension Ideas
- 10P13C vs. 10P15C ac compressor.
- Some body damage
- anyone have glassworks?
- 85 22RE MSD Ignition
- gearing help
- Reverse grinding
- 2wd Body swap to 85 frame.
- popping noise coming from the RIGHT side of the front end
- Removing Front 3rd Member
- Auto tranny issues
- A/C Doesn't Work
- IFS steering box plumbing
- 1985 carburated pickup (help)
- Nice 4Runner
- Flywheel stuck on crankshaft?? 22r
- My First Truck
- Brake upgrade question
- 22re check engine light off and on o2 sensor question
- Same radiator bolt pattern? ('81)('84)?
- 22re smoking......
- 22re ECU throwing a Code 7
- How many colors are on your truck!!
- Clunking front axle
- efi conversion help questions
- 22RE Harmonic Balancer
- My 1985 4Runner
- What shackles are these?
- Truck update and pics from the weekend, Kelly Flats, CO
- no one manufactures new Toyota axle. Any theories?
- Drag link poping out?
- Crank bolt R/R with oil in the cylinder 22re
- New Truck...Slight Problem
- 85 22RE Timing Chain Question
- Rear Drum Brake Rebuild?
- how many links on timing chain
- weber carb, efi?, carb rebuild...
- tailgate
- Mice chewed on one of the wires on this. What is it?
- 22-re cold idle low, warm idle high
- 4:88 gears with 35 "
- HELP! Arb High Output solenoid issue?
- 1985 22RE-C failed smog and crazy timing readings
- sunroof question
- 22re vs 5vz-fe engine swap question
- Shock Question
- Suspension fab help
- Steering box problems
- another body swap q's
- help! power problem!
- Chrome SR5 Step Bumper
- Cold Start problem different then other thread
- mechanical oil pressure gauge
- Engine Rebuild Time
- Need hep no spark!
- rear bumpstops?
- 84 transmission swap help!!
- CA legal weber
- my power windows decided to stop workinh
- help radio plug broke
- Hard Cold Start
- 22RE Engine Surging
- Exhaust...Cat/Muffler choice
- What type of Grease to use?
- 20R carb to 22R intake swap
- 1985 4Runner
- Looking for a clutch
- LC Header
- Trail-Gear Inc Ring and Pinion reviews?
- jerking throttle
- New Truck and Lift Question
- Power steering pump rebuild
- Inner rear axle seals
- Is there any way to test an A/C compressor?
- About to do my RUF driveline and shackle q's...
- Changed a few things.
- Engine Swap, Now No Charge?
- Joined the '85 SR5 4Runner club
- 86 injectors wont pulse
- Roll On Paint Adventure
- Timing question...
- 1985 Toyota 4X4
- Runnin passenger spring on driver side
- chevy 63's
- Running truck on low oil
- Help....it won't start
- Need Help - 84 Land Cruiser - What's It Worth
- 84 22r synthetic oil break in
- Do you really need one of these lifts to go all out???
- smoke on start up
- 85 pu
- 45 MPH vibration
- extend my internal cage to protect the passengers now!
- Help Finding Paint colour code
- CLutch issues 85 SR5 Truck
- Rear 3rd member/gears cleaning
- OME lift ?
- Built me a center console
- 1985 fuels system problems
- lets see your pictures!!!!
- Help truck misfiring all the time and white grayish smoke comin out of exhaust
- Rear axle/differential problems
- 1985 4runner motor which one to rebuild
- 85 Pick Up Lot's of Play in Steering Wheel
- front driveline
- 82 to 85 interchangeable
- Frames?
- skyjacker or rough country
- 1st gen top
- weber carbs
- weber carbs
- 22re missing and power loss...I need ideas
- Question bout Smittybuilt Bumper
- trying to rig a kill switch..
- 85 22rec starting problems
- Axle Build
- Update: Blown Headgasket
- 22R oil change
- Is it possible to get this many mpg?
- 4runner tailgate window
- safc on a 22re
- redwolf3's '85 22RE Engine Rebuild Thread
- Which Weber Carb
- Truck pulls to right when braking??
- lift question...
- HEI for the 22r and 22rec
- valve seats
- 85 4Runner Engine Noise
- Steering knuckle arm removal help
- Cone Washer
- 22re getting hot
- throttle linkage cable?
- Manual Hubs??
- Fender Flares for 1st Gen 4runner (Not Bushwacker)
- Hub Rebuild thread
- 84 Toyota Brake Problems!!!
- 1985 4runner top leaking need new seal
- Front bumper design - Bored in class
- Timing chain guides.
- Different colored interior??
- Did some painting on the truck today...Pics
- Are these original the original mirrors?
- 4runner status!
- 93 rear window wont go down
- 1987 runner, no start, just click
- Skyjacker leaf springs
- Help Removing Autolocker
- Exhaust leak
- Tire balance
- major problems BVSV / vacuum / wiring...
- Death Valley Trip In Late June: Preparation Suggestions
- Piston hit head, what can I do
- Charge and Battery Light flashing
- Will not idle. Sucking Air. Too Lean at Idle.
- Carb help needed and diagrams
- my first truck
- Front Seal Replacement on 22R
- 84 Solid Axle rebuild..w/pictures :)
- multi-colored leaf springs!
- Front Springs
- 85 4 runner to truck swap
- Longblock switch-a-roo
- Optimal RPM range
- 22re fuel problem
- front axle help in Portland Or!!!
- Swap out a new axle or rebuild birfields?
- What is going on here?? Drum brakes on an 84
- 1984 Toyota Heating problems
- air conditioning?
- 85 4runner Shocks?!!
- Do I need ECU in 22r to run offroad?
- ecu and o2 questions.
- 85runner vibrations and slight grinding
- 22r idle problem
- 22R Idle Speed Screw?
- Negative side of coil?
- safety pad removal
- Heat Shield Needed?
- Brake power booster help?
