- Sway bar end link and chassis bushings
- sr5 coolant gauge issue
- first rollover pics/story let see em
- Weird noise from valve cover
- Weber carb mystery plate
- fuel no start
- gauges fuse burning
- EFI to carb swap
- 84 22re alternator
- clear taillights?
- Steering "issue"
- 84 runner dies at random???
- Oil pan question - paper towel left in pan when sealed up
- Manual transmission the same 2WD-4WD?
- priming the oil pump
- 4runner help please!!!!!!!
- which dual case do i get?
- Just bought split rear seat to replace bench. I need a picture please.
- 4:88 with detroit locker rumbles and shakes
- 1985 4Runner Pulls left....HELP!!!
- Brought home new 85 SR5 extra cab 4x4
- engine swap
- help with cut-off switches on 85 4runner
- Got a new bumper
- intermitant engine miss under load
- It's T.O. time
- 84 22R Hesitation/Stutter Problem
- possible coolant temp problem
- broken window crank
- Headlight trim for my 82
- 85 toyota oil presure/water temp gauge help
- White 4Runner red top?
- 84 p/u 2wd transmisson swap
- Computer needed?
- Towing a camping trailer
- Driveshaft Question
- tech. help
- 20r plug gap?
- 85 w/vertical vibration @ 20-30, HELP!
- Exterior Side Window Weatherstripping
- Changing oil
- Another 4runner rear window problem
- Manual to power steering
- Heater Relay and Resistor Source
- Need to smog my 4Runner
- fuel tanks?
- carb
- Help with belt replacement! Please!
- Looks like I'm moving over here.
- tranny will not bolt up
- 2,000 miles away my brother's 22R won't start.
- Help!injector issuess!
- 22RE Rebuild or ?
- What is that Tacking noise
- Put in EZ-Locker...now 4Runner bangs and will not steer....any advice? Please?
- 84 to 85 up 22r block deck height
- High Steer with no lift
- diesel to gas
- cam?
- Heater and Idle (again on the idle)
- Newbie with 1985 22r piston rings question...
- Seat belt broke . . . used or aftermarket?
- Picked up this 85 Sr5 xtra cab.
- Transmission Fill Plug
- I got a FREE light bar!
- 1985 stock door chime?
- Head Gasket???? 22RE
- Clutch Cancel Switch?
- Are the 85 and 89 4runner 5 speed trans the same>?
- Electrical Problem Fixed
- Front mounting point for winch bumper?
- 5.29 and 4.11 question..
- advice on pinion seal
- Runner dies at random
- Unusual for high mileage Toyota to have the original engine?
- transfer case help
- 22rec to 22ret
- driveshaft question.
- 2wd diesel onto 4x4 gas frame
- Sorted out engine bugs, now what to expect?
- 85 short block in an 88?
- Algranger on 36's
- Possible to replace Relay Rod end?
- Leaking oil
- how to disconnect the clutch solinoid that starts the 84 forerunner?
- 87 rear leafs for my 85??
- Can't engage 4wd
- leaking from front hub area. slings oil onto mud flaps
- Toyota catalog.
- I got a Free Camper Shell
- Engine
- SILLA Radiator soon!
- Front axel bushing question
- rear seat replacement 4runner, junkyard trip
- next project...rear output seal, rear main seal, clutch
- Hard passenger side pull while braking
- Wiring a power inverter
- Replacing Clutch
- Couple of questions about swapping to an Auto
- Cleaning parts
- Silicone on an instake gasket?
- Windshield washer not working
- Another heater issue
- new 84 pickup
- DTC decoding help?
- 85 22r heater not working
- oil leak
- OE or aftermarket parts
- 85 toyota truck....
- cold start
- Old man emu combinations
- No injector pulse
- Major rear end problems...PIA...literally
- help me decide on lockers
- Burning oil but how?
- Cylinder Head won't come off 1984 Pickup! Need Help
- Need pictures of 3.0
- My new ride....
- Preparing for a New Engine
- 4 hi has lots of play ?
- steering wheel rubbing??
- 84 Pickup
- e- brake stays on
- toyota pickup sound system
- Is there a 12VOLT keyed under the hood?
- New to me 1985 4Runner in great shape
- Timing way off?
- Rebuilt Engine and Gauges not working..WHY?
- I Think We Fried Something...
- Brake Bleeding Help Needed!
- 1985 22R Not charging
- New noise - where to start? Birfields??
- Blown head gasket or not????
- Smog Problem in California
- 22R Carb Adjustment
- coolant hose thing?
- pic of my 85
- Looking for the average measured articulation on spring over sas'ed rigs
- Transfer case cracks
- Yakima/Thule Roof Baskets
- Quick question about the SR5 oil pressure sending unit
- Cleaned up under the hood
- Tach help please!
- Need new sunroof glass... where?
- 20r block, 22r head. Valve adjustment
- go efi or sell
- 1984 arb bumper to a 1998
- Need help installing 1985 4runner slideing window
- Trouble getting 22r to start
- I need wiring help!!!
- High pressure steam cleaning
- Underhood clutter to super cool cage!!!!
- Anyone use trailmaster AAL's before?
- electrical died while running.
- input on new truck?
- Weber 32/36 carb jetting help
- 22r intake manifold coolant leak
- new guy, old truck !
- issues when motor gets hot.
- engine swap
- Will a wheel alignment fix it?
- A frustrating weekend with 85 4runner!!!
- Frame paint questions?
- 22r timing guides?
- anyone running this setup?
- Went to Start NEW motor and now theres oil everywhere..WHY??
- 488 gears with 33s
- Gasket kits?
- TG skid plate works for single T case
- vacuum leak
- suspension questions
- Help with 85 front axle
- How's This Look to Yall.
- Dual Tcases or 4.7 gears?
- dash pad removal
- O2 sensor test question
- coolant leak i think
- What hitch will fit an '85 4runner?
- 1985 4Runner front leaf springs part #s - 35101
- 85 4Runner driver floor pan and rocker panels
- speedometer reads wrong
- combining threads
- #1 cyl not firing
- Light bulb numbers
- Drive shaft center support bearing
- extended length brake lines
- stripped thread on front spring hanger bolt
- The $120.00 home exhaust
- head bolts and new head
- Charging system woes
- What is this piece for? 22RE
- Help with Vacuum Lines....Pics Included....
- Oil Light
- U bolt size??
- shackle reverse
- 2 1/4" exhaust install questions
- transfer gear down??
- Rip 85 pu
- what size to check transfer, tranny, diffs?
- Transfer case leak?
- Power window problem
- Removed some [more] body panels, added some pipe, yes, pipe
- 22R Crank Pully Removal
- 87 pickup -- How to tell if head was shaved?
- I Heart California - Dynamat Installation
- rear window rolls up but now down, what the heck
- lift suggestions!!!
- HELP!!! altimeter/inclinometer wiring
- spring swap hints and tips??
- No gauges/turn signals
- got a 94 runner sr5 3vze 5spd to part out for my 85 runner what can I do??
- need new exhaust, suggestions
- Drums and Shoes, brake job
- cold start issues. electric choke?
- Will this build work out?
- other body parts that fit
- chevy rear leaf for daily driver?
- Radiator question
- another alignment question
- 85 4runner torque rod question
- sewing machine sound
- wiring issue and wont start
- 1985 Chevota Questions
- Headgasket
- V8 in '85 pickup?
- help msd6al install 85 22re
- Camshaft Alignment
- upper door hinges
- What goes here? Missing piece.....
- A/C belt size?
- Roll on bed linner ?
- 22re timing chain quick question
- Did some work to the runner!
- Auto Trans: What the duece do I have?
- Heat Damage?!
- Driving on the streets in 4 high??!
- Driveway Alignment??
- Loose steering component
- Rings? Low Oil Pressure, Be the Mr Miyagi to my karate kid
- Cylinder lead down test
- 22r blowback
- Rubber Body Spacers & bolts..Which goes where?
- Click click won't start
- deployed, need ideas!!!
- Another 3.0 Timing Question
- Ac/heater blower motor problem
- Sway bar!!!
- 22R Rattling Under Load
- 1985 pickup
- Cheap and easy lift?
