- 22re fuel issue. TPS?????
- Its back!! weber 38 with offenhauser and a weber fuel pump
- need help with rear window operation
- Can't do wheeling won't start
- Aftermarket Wiring Harness?
- 1985 4runner Moonroof
- My New to Me 1984 Truck
- 4runner will not hold in gear...help???
- rebuild carb runs great but poor mileage
- Made some Half Doors
- alternator plug
- check engine light
- 22r problem!!
- 84 fender cutting
- strait axle camber???
- Where does this lead/ what is this part 22re help
- No spark
- Fox shocks on stock 87?
- Exhaust leak from manifold flange on 85-22r
- 85 EFI to Carb conversion-Harness issues
- v6 front brake up grade now leaking calipers??
- 22re still not running
- What weber for 85 22R,Cali smog?
- 85 carb toyota PU starter problem...need help!!
- alternator issue
- 85 4runner wont run, turns over fine
- ug! hung up on a throw out bearing of all things- could use the help
- Engine swap question
- truck for trade!
- Crankshaft Problem: Woodruff key carnage
- Spare tire fitment
- brake upgrade
- Another 4runner redo!!
- Super bob plan
- 22r build or 22ret bulid? or swap? All purpose vehicle
- 85 22r, won't start but runs fine?
- Fuel injection kit question.
- Fan switch problem?
- Intake system
- Reversing Woes In My Baby
- 20/22RTE Hybrid
- Mysterious brake fluid loss
- 85 pick up not running right.
- 22re valve cover question?
- doug thorley lc or nwor headers
- 22r swap with 22re 84' 4 runner
- suntop soft top problem with rear window
- want to remove body to clean and coat frame
- Magnaflow or Flowmaster Delta 50?
- Bushwhacker fender flares finally installed!
- One problem solved but I have a steering question!
- Jingle Bells under drivers front
- 4X4 shifter issue, and "name That Shackle!!!"
- 85 4Runner trashing wheel wells...advice
- Intermittent rubbing noise under passengers feet
- SR5 gauge cluster question.......not the usual tach/oil sender etc.
- turbo swapout
- 85 4runnr cooling system
- Rear Leaf Springs
- The Fun Continues: Transfer case carnage -Drive shaft issues
- Another alternator charging problem
- bushing kit?
- 85 blown head HELP
- ? with 350 swap
- loose belt noise but belts are fine?
- 22re Throttle Body Swap?? 3.0 v6 or Lexus?
- awesome 84 p/u and 85 runner find
- 2wd brake question
- 22r into a 72 hillux vaccume advance issues
- 22r computer with a 22re engine?
- New alternator will not charge battery
- Swaping out auto hubs for manuals
- dumbing down my engine gettin rid of junk help please!
- buckin problem
- Front Spring Schackle Bolts Removeable?
- Need help with '85 diesel pickup
- 22RE swap
- 85 truck with 3" suspension lift: what shocks?
- 1985 4Runner at WabFab
- Wiper Issue
- 85 ext cab 22re lean misfire??????
- Broken BVSV!
- High Compression coolant in oil
- 4wd 'jerking'
- Normal oil pressure?
- "Rod Knocking"
- Front bumper bolt thread pitch?
- Rear end chirps under braking
- repairing pinhole leak in coolant pipe??
- Little help with TPS wiring?
- 1987 Non cali 22r into a 1985 cali truck
- vents behind cab on 1st gen 4runner
- 1985 22re problems with timing
- Suspension vibration
- double to single timing chain, spacer?
- Aisin Manual Hubs - Need Part #'s
- Adjustments on 85 pick-up for Rough Country 3" kit
- SR5 gauge cluster dilemna...using a turbo cluster in a nonturbo 4cyl???
- Clutch adjustment?
- 22r Cooling Issues
- Sick 4runner
- help with 20r/22r hybrid build
- Need direction; 84 X-cab
- half tank sputter 22re
- weird sound... bird getting strangle!!
- 85 x cab and a kids car seat?
- The new toy. 85 4Runner SR5.
- 85 4 runner cruise control cable
- 1st gen 4runner passenger seat rail fix
- Power steering help
- 2wd xtra cab to 4wd project
- trail gear hysteer install
- Rebuilt 22re won't idle right
- Picked up some new tires today!
- Carb ID?
- putting power steering on an 84
- TPS Woes
- Is Your Rear Pinion Seal Leaking?
- Advice on 22RE head
- 1984 cruise?
- weber fuel return
- Instrument cluster/alternator
- 1st gen 4runner dovetail
- 22R timing issues
- Ac not working. light comes on, but no commpresser engagement
- 84 Cuttin Out
- truck wont starts sometimes?
- 22RE High RPM Miss
- 85 Universal joint
- 1st Gen 4runner rear window key switch not working? Try this.
- My new to me 84 4runner
- webber help
- audio wiring for rear speakers
- Offy to Stock manifold comparison
- Help I have water squriting out of my rad
- Load adjusting rear shock options
- Another brake problem thread
- engine problem
- Problem with adding FJ coils to rear Leafs
- 85 4Runner EFI Wiring Harness - Where to find?
- 1985 Toyota 4Runner SR5 original price?
- Motor shudder in a 3.0. . . Timing?
- Auto Transmission help 1985 4runner
- need help with efi
- making procomp leafs better
- charging/electrical please help!!!
- 84 22R TBI to Offy adapter
- Leak help
- Coolant Temperature
- Back Door Light
- Truck runs poorly for 20 seconds, then dies
- help on 85 3y-c motor
- Water temp gauge issues
- 22re Poly Motor Mounts - Suggestions / Experience
- Extended Cab Interior Panels
- help identifying where part goes
- Yellow/Red Engine Harness Wire Help
- Help identifiying hood...
- donor head toast
- Birfield Problem
- O2 Sensor Issues
- 85 4runner clutch noise
- engine klunking and high idle
- 85' head and timing chain
- manual to power steering
- 86 SR5 Ext Cab 2WD Turbo Transmission...
- Squeeling Sound
- Transmission Problem
- Charged power steering pump now truck won't start
- need input on a fuel pump problem
- bob and cab swap question
- 85 4runner EFI Hesitation
- 22r timing issue
- 85 4Runner with a Rough Country 3" suspension lift
- some serious negative camber??
- e brake stuck
- Bobbed my bed (PICS)
- 85 Engine swap or rebuild?
- please HELP!85 22re injectors not firing
- manuel or auto trans
- Revived a 1987 Pick-up
- BAD NEWS BEARS, Rebuild NO GOOD so far
- Belt issue
- bad mileage = motor running bad?
- 85 22re no power to injectors
- clutch problems.......
- Could this be stock 85 4runner paint scheme?
- clutch or pinion?
- Head Gasket?? And a bunch of codes
- question on 5 lug tranny options
- '85 4Runner Heater Hose Kit... where to find?
- Front axle binding, possibly birf?
- towing question
- can i use 95 4runner mc instead of an fj80 mc?
- How to install trailgear ifs steering box mount
- The valve noise that won't GO AWAY!
- Broke something on my motor during rebuild
- Need some help with my engine.
- Al's 7m swap (finally)
- creeper T-case shifter
- Turbo convertion oil setup
- 85' 4runner horrible sounds when backing up
- toyota pickup diesel
- Will this fit
- Bought a FPR and have some questions
- Aftermarket cam settings?
- 85EFI fuel filter change, no start
- Yn60 85 4runner diff gears - plz help
- 91 22RE into 85 22RE truck
- Fresh 22re Rebuild - Coolant Leak
- 85 4 Runner
- 4WD 4H and 4L speeds
- Let See Your Bull Push Bar
- 1st Gen 4Runner tailgate to pickup tailgate conversion
- Lift question/problem
- 3.0 header owners, I just picked up some used Downey headers, got a few questions
- LCE underdrive pulley... belt part numbers?
- 84 4runner draglink loose
- cab swap or wiring swap
- Steering Box Slippage + rig pic
- 85 22re vacum diagram
- 22re antifreeze in oil
- Alternator crapped out
- front axle seal bad? can i still drive?
- 85 Superlift Questions
- 89 4runner gas mileage???
- electrical problem
- 22RE - SR5 Idiot Light ?
- Throttle body
- "Hey Corey, where is my thread?"
- 22re - Disabling Fuel Injectors
- 2nd gen brake upgrade for 1st gen 4runner
- 4.7 transfer case or 5.29 rear which is better choice for trail rig
- running on 2 cylinders
- Red Leader
- 22re lost of power?
- 2nd Gen 4runner steering packages...anyone buy these?
- 85 fi 4wd missing
- anyone use a aftermarket coil on a 22r?
- Gears/33in tires
- whats your idle like with a 261 lift cam
- 85 RE 4runner
- Auto to 5spd - front driveshaft problem. PLEASE HELP!!!
- Too doubler or not to double that is the question?
- G 52 rebuild kit Which one
- 3" of hard lift... how does high-steer fit?
- Best Muffler?
- seats and interior color
- Running lights come on with brake depressed
- Ring and pinion
