- Speedo cable from automatic
- Oil Pan Gasket/Rear Main
- Twin stick with single case?
- Found my 'new'winch bumper
- building a 22r, got a reman 22r head and cant figure out if its pre or post 85
- 1983 bed on a 1985
- Dowel/guide removal on #1 cam bearing
- more flex from stock suspension or just go f150 springs
- timing on a 22r/20r hybrid?
- weber 34/34 issues and heddar problems
- 85 toyota 4x4 pickup having transmission problems wont shift into 1st or 2nd....
- Instrument light on with brakes?
- the blue bomb is finally street legal
- Help, my truck died, electrical?
- 85 22RE Engine Issue
- 84 pickup blower motor not working
- Rear power window relay acting weird
- Front Shackle Hardware measurement
- Replacing front calipers
- doors
- pinion nut... front axle.... how to properly torque it?
- No fuel to pump... 20r head 22r block 84 4runner
- Rear brake distributor valve relocation
- 85 22R no start!!!
- $20 rustoleum paintjob
- 89 v6 axle into an 85 p/u
- 22re rebuld kit questions
- mid range cam tune up question
- 85 4runner dif 3rd swap question ?
- 85 hesitates on throttle, idles fine
- 1984 toyota carb problems
- 85 runner flat bed to front seats
- 1985 4runner
- rusty birf i need your help!
- rear cam seal on 3.0
- did i put the clutch plate in backwards, can you tell?
- What does this plug go to, engine bay. Starter not workin
- Is this the fuel line for the fuel inlet pump or return
- having problems with gauges
- Totaled last night... Now what?
- What kind of rear axle do I have?
- Blisten 5150 mounting question
- Weber carb intake question
- question about installing clutch boot
- G52 Manual Gearbox question.
- adjusting the rear drum brakes
- rear seat options
- 88 4x4 22re misfire
- V6 Rearend Swap
- Under load missfire
- 85 Pickup Starting Problems
- 85 22re exhaust options?
- Idler arm.
- 5 Speed Trans. popping out of gear...
- whats this do? - Torque Rod
- 22re is the header holes pear shaped
- Some fairly generic question on 22r motor, clutch/flywheel install
- thermoplastic clamps
- aftermarket knock sensors?
- 1985 ecu compatibility question
- need your help with some fiberglass work!
- Trouble codes????
- 1985 truck "Tink" maybe transmission.
- Windshield Rust
- Single Case Crossmember??
- Tranny Swap
- 22RE sputters.... I am stumped!
- Cleaning the Fuel Tank
- Wont Idle After High Speed or Rev
- Daystar Lift Shakles good Quality???
- weird idle and then exhaust leaks?
- 85 4runner Leaking third member and bad vibration
- 22R rebuild; still smoking
- 85 4runner Lift Questions
- Stock Height?
- 1984 toyota pickup wiring
- HELP!!! 85 4runner hard start and more...
- Speedometer cable to electronic sender
- Stock driveshaft alternatives!?! or cough up 300 to fix?
- clutch release bearing clips
- Question about new timing chain
- All-Pro triple x crossmember
- Rear window wont open :(
- Hub warm?
- 1985 Toyota Truck OVERHEATING on highway
- engine surging
- Head light issues ?
- New Plugs, wires, distributor cap now wont start
- Need a plug for power steering pump
- I need a tie rod--i think ?!
- 0 - 60 in.... 27 seconds??
- 84 Exhaust Manifold Cast Iron?
- 85 front spring shackle
- Found bearing in Oil pan Yikes
- performance head vs. headers
- Front end problems...
- 22re Reprogram
- parts sources for used parts/bumpers etc
- does the driveshaft to the front axle extend on an '84?
- 87 4runner carpet question...
- '85 22RE Rough idle -- Need desperate help!!!
- Newbie to the Toyota world here
- 1984 22R smoking
- Knuckle bearing preload and spacing Without Special Tool?
- thermostat housing bolts came out of block
- Need a pic of a installed a/c on a 22r
- Tail Light Relay
- 85 4runner lift?
- check engine light
- Just scored an 85 SR5
- LC propane conversion
- 22re timing chain questions
- FOX 2.0's Vs. KING Smoothies???
- need help with freeze 12
- Video of Knockn' 22re
- My new 85
- What type of springs are these?!?
- tranny oil change
- No Shortcuts on Chain Job
- OME Lift Help Please!!
- 85' runner u-bolt flip
- thermostat problems 1985 toyota 4x4 22re pick up sr5
- 4wd Issue...Need Help!
- White smoke at idle..
- new paint on my 85
- cant find fuel pickup/ sending unit anywhere...
- Painting my 4Runner
- 1985 4runner: Plow mount, additional weight options
- crankshaft seal leaks, need advice on quick fix
- 85 pickup needs some maintenance
- Warning for 2L engine owners!
- Electrical / Lighting Incomptence... Need Help
- Gas Tank Help
- Oil Gauge Diagnosis
- Snap Ring on Hub??
- O2 sensor question
- My rig
- my 84 Toyota as promised
- 1st gen advertising -July 1984
- Solid Front Axle Pictoral Rebuild
- engine pulled, should I do anything to tranny?
- possible open circuit?!
- Types of Grease for Axle Rebuild
- Drag Link
- Timing Chain Question w/ Pictures!!
- Need the BEST 22r Guy here! 84 22R
- help picking Clutch and possibly flywheel
- bumbers for the '84?
- New toy! Opinions?!
- Moab
- seat options
- Starting problem
- 1985 rear window not rolling up or down
- oil pressure gauge ???? I nned to remove one from the pick and pull.
- sun roof gasket ??
- 84 4runner swaybar size
- Fixing the 1st Gen 1985 rear window relays in Australia
- Which way does the VTV go??
- The elusive W52
- trans output seal
- 85 runner hesitates and stumbles above 40 mph
- 22RE woes, need help!
- Wet spark plug Cylinder not firing.
- shop manual?
- another 22re turns but won't start.
- wiper arm removal: 1st Gen 4runner
- quick question about white in exhaust ports
- "Cross bred 85?" timing chain job
- Finished Painting.....
- gearing opinions
- 22ret blow off valve
- 85 Knuckle Rebuild
- quick question about mounting my ifs box
- Sounds in driveshaft or diff???
- Swapped the old rear bumper.
- wanna help pick out engine upgrades? 84 22r
- OverHeating issue on 85 22RE
- Weber Carbs
- front leaf spring option's
- Need 85 toy pickup Lift Opinions please!!!
- Pulling the 22r, couple quick questions.
- Weber Redline 32-36, yes or no?
- 93 4Runner wiring Help, blinkers.
- Auto Transmission shifts too early
- 85 Runner automatic troubles
- stripped manifold stud
- Alternator problem
- 22re-t help
- Storing a 1st gen 4runner top....questions
- 1985 Pick-Up 22RE Wont Rev PLEASE HELP!!
- 85 runner compressor wiring
- New to the forum!! My 88 4Runner....
- Steering arm needed
- Aftermarket Center Console???
- Fast Idle Cam Breaker
- A/C compressor not going on, but idles up?
- Here's my 85 Toy---Wha' do ya think ?
- V6 Diff won't fit
- 22R stalls when braking
- Finally painted my truck!!
- poly body mounts
- $300 4runner
- Tech question for 85 toyota 4x4 ext cab
- 4.3 tbi in 4runner, HELP!!
- cb install 85 pickup
- I have a 84 2wd 22r 5 speen and the tranny is going bad can i swap for a 84 4 speed?
- Newbie needs help with '85 22r....
- 1985 22r motor stalling while braking
- 22re issue
- Rear axle seal
- 85 idle issue?
- power windows with triangle "smoker" windows
- undercoating for 85 runner
- Oil in #2 exhaust port
- trucks leaning to the right
- quick question on nut that holds yoke on the front
- 1986 4X4 with high emissions. Done everything under the sun...I think
- Persistent Death wobble
- knuckle bearing/ races
- Fuel Delivery Issues
- My 87 4runner
- Vacuum Disaster
- first gen rear cab curtain info
- Mice ate thru the wiring harness!!!
- crank but no start problem need serious help
- Intro thread and many 84 pickup Q's
- 22re very low power
- ARP head studs
- Mysterious gas leak on 1985 Toyota pickup
- Continued rear window problems!
- what trans do i have?
- need help reassembling
- Question on steering knuckle arm removal
- 84 22r alternator plug
- '84 carbs
- wheres my fuel?
- need tranny help on 84 manual tranny
- Check Connector
- putting my runner on tons. a few questions
- Replaced clutch MC and had to cut?
- back lash in transfer case, how much acceptable?
- 85 Pickup Steering, can anyone tell me what this is?
- "eb cam"
- rebuilt 22R burns oil after rollover
- Jumpin' in overhaul: 85 22R in Utah
- Crossover steering and wandering
- Weber and vacuum advance and weber fuel pump
- Where to start with the new '85?
- suggestions on removing this nut (rear leaf spring)
