- Brake upgrade
- birf snap ring
- front drive shaft popping out?? anyone??
- 1985 Toy w/o Power Steering
- Power steering pump rebuild kit?
- 1985 22r Timing chain kit on a 1984 22r
- 84 toyota truck stalls and identity crisis!
- no oil pressure
- '85 4x4 frustrating brake problem
- odd starting problems
- Cardone or Trail Gear for PS gear box
- Time for a new Head Gasket...
- 22r won't start. Only battery light on. Starter doesn't click when turn ignition.
- got some flex today
- randomly stalls?? help
- Newbie Front Shackle Question
- Clutch Not Fully Engaging
- Fuel Tank
- mystery squeal
- Dealer/Factory Appearance Packages
- pinion nut on rear axle not staked
- 1984 Toyota 4runner with 4.3L v6
- ECU help!
- Need A Spindle!!
- 22re static sound
- w56 Tranny - which ones work in my 85?
- 84 valve and spring question
- 84 longbed 2wd pickup odd noise
- New Hi steer and powersteering box?
- manual tranny wont go into gear
- taurus fan question
- anyone have a k+N or other high flow intake?
- Truck is Diseling HELP!!!!
- Another 'what is this?' thread...
- Gas filled crank case in 300 miles! 22re
- too tall: will a 6'2" driver fit a single cab?
- LC engineering 35lb fly wheel
- 84 22r timing/ignition issues
- My new thousand dollar 1985 sr5 F.I. xtra cab
- 84 22r doesnt want to cranck when warm
- Ignition Timing 22R
- Extra cab rear driveshaft ???
- cam shaft question
- Help ID and properly name this (these) gasket!!!
- ebrake not working properly
- 1984 22R Engine Telemetry Project
- 85 runner , please help finding where this wire goes
- Headgasket
- auto to 5spd swap in my 85....i need some directions
- just bought an 85 4runner
- RUF swap spring question?
- dipstick length for 22R ?
- Carb questions
- Door Mirrors for 85 Toy extra cab
- Stalling after replacing valve cover gasket ???
- pacesetter problemo
- 22re starter help
- AFM help Please!
- 85' PS Steering box vs. IFS Box
- 84 22R Direct Fit Alternator Upgrade?
- Military 4runner
- Possible Posi or LS stock for 85 PU?
- 85 pu 4x4 sr5 22re clutch ?'s
- Help please....waterpump?
- 20r/22r Hybrid, Anyone with a lot of experience in this?
- can anybody identify my springs??
- Boomerang shackles with drop hanger?
- 1985 Toyota 4x4 Power Steering Conversion...
- 85 22re throttle body coolant hoses
- 85 4Runner won't start after just turned off
- 86 4runner shifting problem help
- gm alternator swap need help
- Tailgate Release Cables
- exhaust manifold flange nut sizes.
- People with kids, need some ideas.
- Pro comp 4in leafs
- Idles Real Rough after HG, TC, and V Job
- what are the hp/torque ratings a 85 22re v.s. 85 hilux?
- '85 22re problem
- 85' 22RE electrical chaos!
- Odd "Shifting" sensation 84 Pu
- Transmission clicking
- 84 Pickup Heater issue and more
- 1985 toyota pickup truck what is this part?
- Ranger type jump seat in xtra cab?
- ventalation wiring harness
- 1984 Toyota pickup Sr5 4x4 5 speed , cooling\stalling issues. help?
- Vacuum advance 84/85
- strange fluid on garage floor
- 84 Toyota diesels?
- Many Thanks!!!
- Igniter Questions.
- AC Retrofit Question
- Wire harness question
- weber carb questions
- 84 toyota 4x4 transmission issues
- 84 toyota 4x4 transmission swap
- Radiator Issues
- new...ish guy
- Before I drill... 4runnner to pickup seats swap.
- newbie question?
- more downward travel shocks
- speedo reduction
- 83 22r intake and exhaust differences from 85 22R
- 84 Pickup 22R auto choke doesn't seem to be working properly
- Double Cardan U-Joint Size
- clutch chatter brand new marlin clutch
- installing aftermarket oil press. gauge while maintaining stock gauge on service
- Frustrating timing issue
- 22r with weber 34 dieseling and has extended crank while warm
- Anyone but new model stuff on there 2nd gen???
- 22r smoking after head job!!!!
- 22re knock sensor wiring harness
- Hood Bump Stops
- Front Brakes
- bearing preload
- 85 efi- zero electrical power
- major carb issues
- Can I swap these tranys ?
- 84 4Runner 4WD not engaging
- Pinion Shaft Nut Size?
- Dana 60 and 14BFF swap
- '85 No Power in 4th or 5th
- 85 4Runner Gas lid/cover
- birf help
- Font hanger plate bolt size?
- 1984 pickup 4x4 Grinding noise in 4 wheel drive
- Rear brakes wont work
- Valve lash settings
- turn signals on bumper lights, parking lights on corner lights?
- part-time smoke???
- Gear Oil for Tranny
- leaf spring/height help
- need help finding circuit breaker
- heat problems...
- Disc brakes
- 22RE won't restart warmed up....
- Driveshaft question.
- fairly new here...just p/u '85 4runner
- Stevesk88's 84 Build Up Thread
- 85 4runner brake problem question ?
- is a Puller needed to remove axles from the housing (SA)
- What is this box thing?
- 1982 pickup with 1988 rearend?
- All sorts of clutch info needed...
- Can anyone identify these springs?
- open port
- Transfer Case question
- Only left side 4wd hub working
- Custom Gauge Cluster Questions
- Which 4-cyl. IFS parts can I reuse/repurpose?
- Heater wont work
- 85 22re wiring question
- Another broken leaf spring...
- carb rebuild.
- need part name or number
- Broken Leaf, what to do?
- Steering Gearbox... $1409.78
- 4.88 gears + 35's ???
- 84 Toyota GM CS130 conversion
- 22re timing chain incompatibility
- Anyone Have seats Redone?
- 85 ext cab frame
- Lifiting my truck
- speedo gear tooth count?
- 22r losing Oil & Coolant but no smoke ... head gasket?
- 1985 Toyota Pickup Headaches, Timing related..
- 87 4runner rear window
- TPS: Adjust or Replace
- 22r build questions (Daily driver, weekend warrior)
- What will 33s, 4.88, and a 32/36 weber get me?
- Quick header install question, clamp/weld or what?
- Heater Control Valve
- brake/charge light on with high idle
- 1st Toyota, new to site. Have some ?'s
- Battery light staying on after pressure washing
- seat mounting guestion
- 1985 22re sr5 4x4 tranny
- A43D auto trans leak
- 1984 Pickup 4x4 carb tuning help
- 1985 Toyota Pickup...I think my motor caboomed on me!!!
- Throttle help with 34/34 weber carb
- IT LIVES!! Headgasket/Bearings/New Head
- J arm hitting frame!!!!!!!!!!!!
- having trouble lining up my wiper motor
- 80 front Driveshaft with 84 flanges?
- iac valve on 85 fuel injected 4-runner..
- Heater Control Cables 85 SR5 pickup ?
- toyota pickup custom offroad front end
- Brake Upgrade
- 22r no compression on 3 and 4 cyl
- where can i get a fuel cut solenoid
- Pulling the transmission, have a question?
- just some before and after pics
- Cleaned 22RE throttle body now won't start - Help!
- Putting a pre-'84 longbed on an '84 longbed frame
- '84 Input Shaft Bearing, G52 transmission
- Broken water pump bolt.
- 86 drive shaft fit a 84 manual truck?
- Blinker/hazard lights stopped working - Diagnostic
- Rear brakes
- What do I do with this? Weber 32/36 conversion stuff
- 85 Pickup No heat issue
- My 84 Pickup Restoration
- 1985 Truck Blowing cold Heater diagnostic
- 84 rear shackle nut size
- Manual to Automatic Transmission Swap
- 22r Noise (lifters, exaust, rod?)
- Round Exhaust manifold ports?
- Brass Spindle Bushing Homebrew SST
- Interior door skins for 84 Toy P/U
- pics of the 22re head??
- testing the heater blower
- Check my Power steering gear placement please.
- 1985 4x4 extra cab LOOKING FOR interior parts
- EGR valve cleaning questions
- Fuel tank sending unit
- 85 4runner having some serious issues
- 22r choke heater element
- Seal Replacement or Axle Rebuild?
- windshield wiper motor wiring
- brake brands
- Tallest tire for a stock height '85??
- Top shift and Forward shift transfercase
- wheel stud replacement
- wiring 22r carb
- new gauge cluster, goofy rpm?
- No power between 2k-3k. 22re Help?
- How to block off fuel return line
- 85 sr5 runner starts and dies when warm.
- lots of messed up wiring advice
- replacing heater water control valve
- seats
- Intermitten stmble
- Loosing power when check engine comes on
- Heater Core Leaking
- Just showing off my 84 4runner
- Holley 5200 series carb
- harmonic balancer 20R 22R 22RE Affordable find.
- is a turbo a good idea?
- which header for a 20r head?
- SR5 gauge cluster swap problem
- H/G Replacement 85 22REC, looking for advice on jobs to be done
- coolant leak
- new radiator, what do you guys recommend?
- installing new timing chain cover...
- Is front drive shaft supposed to spin when 4wd is Not engaged?
- Battery/starter/water pump/ who knows
- pickup dovetail
- fan and water pump stuck together
