- 85 trans cooler line bracket
- i got a 84 4runner. cylinder head ????
- Calipers & clutch master cylinder
- 85 yota 4x4 truck auto tranny wiring plugs questions
- u bolts
- 85 4Runner rear shackle angle...Puzzled???
- heater/blower will not work
- Missing timing mark on crank
- bucket seat swap in 84 single cab?
- rear glass seal please help i cant find a replacement
- '84 22r/MT/Carb high idle BVSV valve or linkage?
- Bobbed Bed Leaf Swap Ideas??
- 84 carb (g52) to 85-89 sr5 cluster swap. Speedometer WAY OFF
- brakes are a nightmare.
- new to me 85 2wd and questions!
- CEL won't blink codes anymore
- 85' Pickup Driveshaft 2pc - 1pc
- Knuckle leaking
- TG rear bumper ?s n more
- Weber 32/36 won't idle to tune
- Changed my starter and still get nothing but clicking
- Knocking / clicking activated when clutch is out (Link to audio)
- 22RE Cam ? and front brake conversion on 85
- smoke coming from behind crank pully
- tps problems
- Did Jiffy Lube use the wrong fluid for my T-Case?
- camber adjustment 85 solid axle
- no power sometimes/ rough idle. no engine code
- Engine identification year
- throotle positioning sensor sypmtoms?
- Plastic Headlight Anchors???
- Seized pistons
- Shackle angle problems installing lift
- carb linkage diagram???
- New parts!! It's like Christmas!
- Thermostatic valve?
- Reman 22r Engine front seal leak. PLEASE HELP.
- 85 22re pickup disappearing coolant?
- 529's and pinion spacer
- '84 22r Issues
- high pinion vs wedges
- 84 gauge cluster pick up knock sensor
- Weber Issues
- can you id these hubs please?
- 85 Long block with 84 accesories
- how much power?
- Battery and Brake warning lights...
- Fabricated rack and soft top?
- what color/colors to paint my 84
- How to remove extra cab windows w/o breaking any clips
- Overheating. Suspected: T-stat or air bubbles.
- New parts: Still getting code 5
- 86 22re\No cold idle up related to stumble?
- Crack in Trans Case...
- 3/4 ton brake master and rear disc question.
- Possible head gasket, engine wont stay running, help please
- I'm back with a '84 xtra cab
- Almost free 85
- what all needs waterproofed for a snorkel
- help me find a snorkel adapter please??????
- 4-runner not running on all cyl.
- v6 third in 4cyl axles.....
- weber idle question
- Gas Tank removal / Propane instal
- Can 84 axles handle 5vzfe?
- New parts happening!
- wheel back spacing
- Trans Cooler Question
- 1985 Pickup and the timing is off
- EGR valve gasket?
- How far back can I mount transfer box
- head gaskets
- breathers? and other little mods?
- 1984 Gauge Cluster question
- water in engine oil question
- 1985 22r-te SFA pickup??
- 84 4runner 33x10.5's what backspace?..
- Could it be worse-spree of breaking my truck
- weber 36 dges
- 22r runs good warm not cold
- Strange rattling noise
- Hard start and rough idle
- More Responsive Steering?
- Valve adjustment
- steering drag link question
- 85 locking hub help
- 92 22re,harness and ecu in 85???
- Best mod under 100$$??
- Header Size Info
- Won't even TRY to start!
- Transmission not engaging gears
- Electric heater conversion/add-on, anyone done it?
- mushy brake pedal but no air in lines
- Drop drag link?
- Camper shell help Lots of pics
- Newbie question grill swap
- got some money now what to get!
- Removing 1984 4runner rotor
- Stock front axle shaft spline wear
- 84 22r upper engine knock
- rear diff questions
- Doing a partial rebuild, main seal question
- broke bolt question
- totaled 85 toyota... trying to salvage
- Knocking in an 85 pickup 22r. . .
- Recenty Rebuilt Weber 32/36 now really high idle. Help!!
- Can timing being off cause plug fouling/intermittent stumbling?
- stepping up to hydro-assist
- 85 4runner Wheels (Gold)
- Intake manifold bolts go into oil gallery?
- centering 6 stud knuckles????
- trail gear springs with drop arm?
- Moisture in the cab
- Crankshaft Bolt is Seized
- What luck with truck :-(
- overbuilt engine??
- Gears???
- 84 4runner heater core
- rear bumper TRAIL GEAR / MARLIN
- 1985 toyota heater core o-ring
- why the heck do i still got leaks
- fuel filter bolt poundage??
- getting custom drive shafts made - need some help with specs
- Weber 32/36 dgev, idling/ driving issues
- Just finished changing timing chain in previously swapped motor- wont run!!!
- Just finished changing timing chain in previously sealed motor- wont run!!!
- lower kknuckle cap wont fit on 6 stud knuckles HELP!?
- anyone see a problem on how I routed this?(heater core 22re)
- Comp test results not looking good
- Picking Up 84 Runner this Friday
- New lift for the runner
- front shackle angle help
- HVAC Valve
- 1985 pickup oil pan
- Differential bearing questions.
- Modified 22R seems to lack power
- 85 extra cab drive shaft issues
- New motor mounts
- 85' 4runner Rear Axle and Brake Drum Assembly?
- Just picked up a 1985 4runner
- w56 front oil seal same as rear by chance?
- Are my leaf springs shot? (pics)
- Magical Mystery Brake Problems
- Stripped nut on locking hub stud
- 85 EFI randomly dies like no fuel or spark
- Loose steering wheel cover
- which offy intake should i get
- Swapping motor for a newer 22RE
- Need help diagnosing rich condition on rebuilt 22re
- 22RE - Need Replacement Fuel Injector Plugs
- 84 truck noise maybe throwout bearing?
- Leak at intake manifold
- Rear lift pinion angle
- Engine Harness Woes
- runs, then shuts off.
- Extreme Negative Camber...
- 4-link shocks
- '84 pickup -critical issue with fuel pressure relief valve/regulator
- what are ohms on stock 85 sending unit
- dash gauge cluster not working?
- park brake wont budge
- 85 rear suspension beef up needed....?
- 22r skipping when cold
- 854runner front end is loose
- Fuel Cuts Out.
- How bad do you think this is?
- Alt+regulator wiring troubles
- solid axle camber
- Electrical..the next item on my list!
- Calling all 2wd owners, just picked up a 1994 Pickup.
- Strong crank, no start....
- 1" BL or Hole in the floor for triple shifters?
- Help identifying these tranys I bought.
- 85 22RE, does my o2 sensor need replaced?
- Crawl Case Transfer Case gasket question
- RUF need help!
- axle wont center in spindle
- Super weird timing issue
- weber 32/36 vent line stall fix
- No heat and its cold!
- 1984 33" km2's fit/lift/driveshaft/gearing ?
- High idle
- Distributor has a hole!
- Steering box dead?
- shift rail modifications for duals and 4.7's
- Inclinometer for 1st gen 4runner
- Is she worth the money?
- Wheel hub hole
- 85' 2 wd 4 speed to 5 speed
- Intermittant Starting Issue
- 1987 Turbo
- clutch burned up??
- Dual case build, mixing gears from two cases?
- rattle after new timing chain
- Cranks great, starts great, runs 10-20 seconds, then dies.....
- Help! 4runner has me stumped wont rev past 1500
- Replacement body panels - rust repair
- 84 tranny problems
- Almost there
- '84 Bogs Down Under Acceleration
- 22R short block replacement and top end rebuild
- 4WD makes awful noise
- Cab swap?
- turn the key to the on position distributor is sparky
- "Resealing" heater ducting/air box?
- Picture request: 84-88 single or xtra cab with bed from a 79-83
- 22R Smog test woes (CA)
- no longer in the 84 85 club
- New brak problem...
- brakes leak
- 22RE runs rough at idle when warm, runs great in park or neutral though
- front seal headache
- 85 4runner , 1"shackle lift on flat stock leaf springs questions
- 1985 Pickup Steering help.
- Would it make a diffrence
- Back window wont roll up
- 86 4runner doors rubbing on fender
- Front rotors install- what else should i fix/replace?
- Differential Dilema
- rear brake help
- would my Gen1 '85 T4R be a viable platform for the ZUK mod?
- RPM's don't fall as quickly as needed?
- Gas milleage...1986 Xtra Cab long bed?
- 3.4 swap 5vzfe what tranny is typically used? R151 Find
- 85 Runner Jerky Gas Pedal
- Fender trim pictures
- 85 Toyota - Want to add a seat to the extended cab
- 22RE Freak
- Cracked my windshield
- What shocks???
- Oil and water temp
- Front wiper motor problem
- 1985 22R won't run right when timing is right
- Drive shaft flange questions
- Harmonic balancer fell off!
- Clutch Question
- RUF Questions
- Wiring question.
- Grooves In Axle Housing
- RUF need help
- hoping to push 40's, need some advice
- transmission wont come out
- Best bolt on lift kit???
- ac compressor to air compressor
- Flamin Green '84 Toy build-up
- radio wires
- Hub trouble
- New Gear Install - Need Help Reading Pattern
- Frame rust or "rot"?
- egr block off?
