- Front Bumper Pics
- New here... Need Help... Diffs
- What is this?
- 85 4x4 500$
- chasing rust (pics)
- pls help. rattle
- bad engine wine
- Got some work done the last few days.
- Scored on an engine!
- 1985 22r pickup wont start cold without adding gas to carb.
- First Yota! 85' 4Runner build.
- Only one fuel injector firing?
- Getting schooled on the pinch weld
- Carb not working
- 6allpro leaf springs
- is my mpg bad or about normal for the mods for my truck
- Hello! My new rig 85 4runner (pic) and what size lift is this?!
- G52 issues....
- 84 4Runner Heater core - w/ or w/o rear heat, are heater cores different?
- Odd timing problem, need some helps
- Mystery Dash switch??
- My "New" 85 4Runner. Need parts help
- 1984 Pickup - Vent/Stereo Relocation
- Junkyard score!!
- rebuilt 22re wont start: code 11 TPS?
- Removing an AC system
- Can anyone give me an idea why my engine sounds like this?
- First post and I'm already in a pickle...
- new 85 owner
- Transmission swap issues. Need some help.
- 85 4runner still runs after I turn off
- Ford 'small block' windsor 289, 302, 255 swap
- New To Me 85 4 Runner
- wire mess
- chevy spring swap
- EFI Fuse Melted In Half
- dual timing chain converion
- Stalled and no start
- DOA racing engine brand- Hdouble chain timing kit
- Shock recommendation?
- 85 4runner, automatic shift issue
- 22r for sell
- ALL American
- 84 4runner starting problem
- 85 wiper arm conversion?
- Leaky steering knuckle
- Project Centercap
- Got a driveline issue and I think its the wheel bearings.
- sunroof question
- 1985 Auto Hub trouble
- coil spring conversion from 91 tj
- 85 4Runner Engine Electrical Issues
- My aching Head... Gasket
- Hard to get out of 4 low.
- 1985 22RE TPS connector
- Inheriting two 85 toyota pickups .. in rough shape. FRAME HELP needed
- 93 4runner 3.0 Dies.
- the newest toyota
- 92 toyota pickup high idle problem
- LSD additivite or no in Diffs?
- Can someone check my work TPS adjust
- how strong is your stock axle
- it is alive!!!!!
- 3VZ - interesting read against other v6 engines roughly same era
- 85 4runner Radio Install help
- trouble code help
- Front lower shock bushings.
- V6 Third with 5.29 and ARB in 4 Cyl axle housing... Clearance Pics anyone?
- mystery part on my 84
- Longfield 30 spline install/clearancing help
- 1988-1998 chevy fender flares?
- Is my diff carrier done for?
- New 22re is running sluggish and don't know why.
- Engine noise after HG and t-chain replacement.
- how to rotate a cam shaft thats lost its timing
- Need help changing out a tranny mount on my 85 4Runner
- 85 4Runner to 86 SR5 Xtracab Pickup Passenger Bucket Seat Swap Issue
- 1985 4runner brake problems
- Front diff locked up.
- Identify leaf springs?
- rod on front axle??
- 84 4x4 lspv replacement with aftermarket valve
- Looking for 84 4runner ac compressor service port
- 85 stock jack question?
- Yukon 5.29 with Zip Locker clearance issues
- 84 22r work with 85 22re intake, sensors etc?
- Header question
- 85 Toyo pickup 22rte for sale 1850 Ono
- 7m cooling issues
- Opinions needed
- 1984 pickup steering
- grease fittings for 84 4runner
- Gonna have 22rte rebuilt and machIned
- why does my 84 pick up take so long to start in the morning
- 85 Toyo 22re turbo
- only for those who like mind games: 3.0 plugs in 22Re
- pulsing idle, question with sound
- 1985 22RE Oil Pressure Sensor/Sender/Switch Questions
- 1985 22RE Cooling/Temperature Sensor Questions
- New rebuild Bad compression
- temp sender connected to CEL?
- 85 22RE won't run after sitting for two years
- inner axle seal replacement
- 4runner sr5 decal help
- distributor rotor not rotating 22r
- 85 4runner Front Axle Seal Questions
- Helicoil or keylocking?
- DIY Kayline frame.
- 1st Gen 22R rebuild
- 92 T-case swap: shifting problem
- I sucked up some water...
- Bolt size question
- Rear drum hardware question
- In-frame crankshaft and main bearing replacement
- Part Help ID
- Help: Possible Igniter / Starting Problem
- 22r intake manifold
- HELP 85 4runner auto stalls in drive stopped
- Manual vs Auto
- 85 22RE Drowned and wont Crank, Help.
- lifted and shackle hitting frame, but is angle okay?
- no start issues
- 84 bed won't fit, I'm really confused!
- lifted and aligned here are my results
- 22r fuel coming out valve cover???
- power adders for my 84
- Hi steer question
- 22r with a o2 sensor?
- 1984 Muffler
- Center console (armrest part)
- 85 runner Speedo cable
- Oil pressure sender
- Corroded file line
- How much did you pay for your two price drive shaft work
- Oil pressure sender slide-on connector
- head gasket job,trying to remove exhaust manifold
- Stumbles only at certain rpm, bucks terribly
- 1985 toyota 4.3 vortec lift???
- A question for those you have done the IFS box
- 85 Toyota Pickup Longbed Driveshaft swap?
- Holley or Weber
- did i get yukon or just pay for yukon
- Small 90 degree coolant pipe from throttle body to intake manifold
- cracked piston lands
- Flat Cam help
- Help! Center/carrier/driveshaft support bearing and rear driveshaft alignment
- 92 new motor running rough?
- getting into gear issues
- think this topper will fit my 92 yota 2wd 76" bed?
- 85 4Runner build/2L-T diesel swap.
- Bogging in 3rd gear with weber and running hot
- So I was cleaning up my (broken) W56 and....
- engnbldr feedback
- 85 22r valve cover breather leaking oil
- 85 ExtCab Fan troubles
- Need some key pointers on tranny swap
- 1984 pickup cab mount pictures??
- 85 4runner with lc-engineering motor computer issues
- 85 4 Seater Truggy Project
- these tires too big ?
- Stock T-Case to 2.28 21 spine creepers box
- 1984 4runner a/c problem
- New parts going on, got some ?
- Ignition/Timing on 85 DN60 Pickup
- 84 Flatdeck Diesel
- 85 4runner not starting
- Wiring help
- Small back firing at lower rpms
- Tranny leak
- G.I Junk "pre-buildup thread frame swap thread"
- A few new pics of the 1985 4Runner
- timing chain tensioner
- Help how to shift into 4wd
- Pinion Bearing Preload?
- 1984 pickup 4x4 new owner
- 93 pickup head gasket problems
- Extreme Oil Leak... HELP!!
- MY first Toyota 1980 4x4
- fuel pressure regulator 9710
- Long bed dimensions
- 1984 22r new alternator will not charge
- Temp gauge rises then falls
- Will this header fit, or why not?
- 85 22re water pump leak
- stockleeroy's 1985 RN60L
- Ignition vs Valve timing
- 22RE misses / sputters and stalls after a long period of wheeling
- Defrost switch install help
- Accurate Electronic Testing Info Wanted
- 84 4runner headunit wiring harnes question
- Cam Timing???
- Vacuum like AAP part question?
- carhartt shift boot
- 4speed to 5speed swap
- Rebuilt 22RE mpg and fine tuning question
- Wideband install?
- What is this brake part?
- What's your frame width?
- intermittant starting issue. Process of elimination
- 1985 Solid Axel w/EFI /4 Runner
- Spotted in Pleasanton, CA
- Rough ride w/ old procomp lift
- let talk about engines
- Cam gear snapped off
- 85 22re automatic totally guttless
- About to give up and sell... Help please?
- 1st gen 4runner roofrack options
- Oil blows out everywhere!!! Open for ideas
- 1985 4Runner Question
- Highest speed rear end
- New PS pump...won't flush...nothing out return
- Hey guys I need help my with truck it wont start
- 2000 tacoma seats in 85 single cab?
- My yota, won't start
- 1985 4runner 4x4 Crawler FOR SALE CENTRAL CA - $5,800 OBO
- 84 22r died on highway, no spark?
- Get rid of my spool
- My truck almost killed me: Check your tie rod ends!
- Aluminum Wheel Lug Nuts
- Alternator cable fried....now what?
- 2-2.5" lift bilstein part numbers?
- '84 4runner: Sourcing diff gears (4.88) help
- Is this part stock? - 1985 4runner 5spd 22re
- starwheel adjuster cable for rear drums
- Turn Signal blinker install, 4Xinnovations
- I need help with starting a 22R carburetor 84 Toyota Pickup...
- Knock sensor code 12
- fuel pump relay
- lce header
- 32/36 backfires when coasting down hill
- Need carb help - loss of power before lower butterfly opens
- My 84 4x4
- Help with my clutch replacement!
- backing plate bolt pattern
- Front lower blinkers don't work, stumped.
- wiring harness compatability / identifying
- Rear leaf spring u bolt guide/rubber bumber
- 85 22re Temp Gauge Finikey- After a few trys/fails, any wiring gurus out there?
- 22r head gasket replacement
- 84' celica engine in my 85' 4runner
- 1984 20r with tranny/
- Front wheel studs part number
- New engine time, Rebuild or buy long block.
- Egr valve help
- 85 ext.cab 2 piece drive shaft help
- Sputtering 22r. Trans, Fuel, Timing? Help
- 1985 trail rig build lookin for suggestions!!
- 2nd Gen pickup tailgate mod?
- 84-93 Front parking brake question
