OEM front mud flaps for a 92 Pickup 4WD DLX?
Old 10-29-2024 | 06:46 AM
Paul22RE's Avatar
I see there is a Toyota part number for front mud flaps. I have a '92 4WD Deluxe but no front flaps? Were they an option or just on SR5's? I assume they will fit my truck fine? Thanks
Old 10-29-2024 | 07:53 AM
Discombobulated's Avatar
I have a 91 DLX with factory front flaps. I just replaced my rear flaps due to the 4wd wearing off. Not sure but you may have to get the brackets separate as my rears just came with the flaps.
Paul22RE (10-29-2024)
Old 10-29-2024 | 02:28 PM
Andy A's Avatar
On the 94 sr5 I have there are no brackets that I can see for the front flaps. They have 3 mounting points. 2 appear to just use existing bolts that hold the fender liner on then there is 1 further back which goes into the metal part of the lower wheel well. Not sure if that mounting point was put in on all models. I don't see a part # on them or i would gladly post it up. They are factory original. Back flaps do have a bracket.
Old 10-29-2024 | 03:31 PM
Yes, sorry, I was thinking about the rears, the fronts are just bolted. But as said above not sure if they just bolt up or not if it didn’t come with them??
NYHumpinUtah
01-13-2018 08:12 AM
Valvoman
02-27-2016 02:08 PM
tim a.
08-15-2010 10:23 AM
87T4R
05-15-2008 08:57 PM
MvCrash
07-07-2004 05:40 PM
Quick Reply: OEM front mud flaps for a 92 Pickup 4WD DLX?
