1993 V6 R150F VF1A T-case mounts???
Has anyone found a beefier tcase mount like for all the other cases out there? Seems like what is available is for all the other gens except for the 2nd gen runners and 3rd gen pickups that have a v6 passenger drop tcase. Mine is definitely worn out, my brother's 3rd gen runner with an R150f with a driver drop VF1A has a mount from 4xInnovations and it's definitely a big improvement over stock. I'd like to do the same with my 1993 4runner. But am not finding a mount that even remotely looks like the one on my rig. Am I only stuck with a OEM one? Many thanks for any input!
I don't know what your T-case mount looks like so I'm just throwing this out there. Any way to fabricate one using your old mount steel parts and using off the shelf suspension bushings? I made my own RF1A mounts similar to the aftermarket ones for sale doing this. If not, I think sticking to an OEM Toyota mount is better than any aftermarket option.
If you find something though please post it up. Good luck with your serch.
I believe 4xInnovations makes what your after. Although it doesn't mention the earlier trucks, but it is the same r150f. Compare the images to what you have to be sure.
https://www.4xinnovations.com/Tacoma...ount_p_86.html
Also to get the full affect of these mounts, you may want to do the engine mounts too. Or else your engine will wiggle more than your tcase and that could create problems. Not something you HAVE to do, I would just recommend it.
Ruff stuff makes a great matching engine mount. https://www.ruffstuffspecialties.com/R1626.html
aztoyman (10-23-2024)
