Toyota re22 1996 injectors dont open
I got a Toyota re22 from 1996 that injectors dont open. I have measure the electric signal to the injectors and it has constant signal (6V) and no pulse.
I have replaced the Circuit Opening Relay and the air flow meter. I have good presure on the fuel rail. The ECU is cleaned and tested by someone professional.
I have also done the diagnostics and got the trouble code that says its the air flow meter and I have changed it.
Thank you for any help
camel854runner
10
12-11-2014 06:15 PM
rimpainter.com
10-16-2006 04:51 AM
