CSF 2314 on an 85 Pickup?
Has anyone installed a CSF 2314 radiator on their 85? This article on roundforge states the 2314 is a drop-in fit for 84-95 4Runners and 86-95 pickups and that pre-84 has some hardware differences. So what about the 85?
As far as we can tell, a 2314 will bolt in without modification to 1984-1995 4Runners and 1986-1995 Toyota pickups. That said, this should also be a near bolt-in Toyota Hilux radiator for earlier, pre-1984 trucks. The biggest issue you may have is that some hardware may be different. Early trucks use 12mmx1.25M hardware to hold the fan shroud. The CSF 2314 will come with 10mmx1.0M nuts welded to the engine side of the radiator. In other words, be sure to have some 10mmx1.0M bolts around just in case. 30mm long ought to do it.
The 2314 fit my 4wd 85 PU. The 2306 is 1" taller. I've never gotten a straight answer whether that one fits the '85, or only 86 and up. Pretty sure the shroud at least is different.
