Would bigger wheel cylinder bore cause more rear braking?
Hey guys im rebuilding the rear drum brakes on a 89 v6 pickup. The rear wheel cylinders were both different sizes. Im guessing previous owner accidentally miss matched the rear cylinders. Now im not sure which bore size it originally had.
single rear tire and the vin says 1/2 ton.
it has F18Q front calipers and its an extra cab
Based on this info from rock auto im leaning on getting the bigger bore.
Would a slightly bigger rear bore cause any issue?
Would the rear grab more than the front?
I’m not sure but i would guess that if the cylinder is larger in volume and the master is pushing the same amount of fluid, there would be less movement at the wheel cyl.
old87yota (10-01-2024)
YT Community Team
I'd think it'd be easier to just get the size that Toyota matched with the existing system. That way you don't have to worry about the master cylinder being under-sized, or making any adjustments to the proportioning valve. The vast majority of the actual braking is the responsibility of the front brakes. The rear brakes just makes sure the back of your vehicle doesn't try to pass up the front when braking, especially in turns.
Jose Pena (10-01-2024)
Jose Pena (10-02-2024)
I bleed the whole system. Lots of bubbles on the new wheel cylinders. After bleeding the system in order from furthest to closest. Do I need to bleed the load sensing proportioning valve? Ive never touched it before.
YT Community Team
It is recommended. When i took my LSPV apart I was shocked with how much sediment and other build up was in it.
Dirty or not, it still needs to be bled out. Last.
Chances are good however it'll be full of crud. Take it apart and clean it real good, reinstall, and bleed it out, just like any other brake cylinder. But no matter what, bleed out the LSPV after all the others.
Pat☺
Pat☺
The LSPV can get frozen up. To confirm it’s operational, Unbolt the cross rod and drop it down. It rides against the plunger of the valve. When someone pushes your brake pedal you should see the plunger moving in and out of the valve body.
thewanderlustking
02-25-2022 08:48 PM
richardashe
08-18-2021 02:04 AM
