87 toyota pickup click no crank can't find starter relay (video attached)
Old 09-13-2024, 08:36 AM
Rarediary's Avatar
https://youtu.be/PEUNsRiNHZA?si=CegidSkNlbA5efmO
Help
Old 09-13-2024, 12:26 PM
osv
osv's Avatar
some hacked-up connections, ack
that black object that you first handled could be an added headlight relay(??), it's a common fix for toyota just follow the wiring to see where it goes.
the connection underneath the oil filter is i think for the oil pressure sender unit in the side of the block, looks like the wire for it is hanging out in your video, i wouldn't expect that it would be connected to the starter.
there is another wire to your starter, i can see it in the video, black plugin just above the power wire, follow it and see where it leads.
these toyota starters are super irritating because afaik there aren't any open connections on the starter itself, that you can use to manually bypass the solenoid on the starter.
here is the older-style starter relay, not sure that i see it in your video:
Jimmyjohn
06-01-2024 10:14 AM
That89Yota
02-07-2024 10:24 PM
Cjcross22
05-21-2022 08:23 PM
pig
01-13-2009 05:42 PM
madmin
09-03-2008 06:56 PM
Quick Reply: 87 toyota pickup click no crank can't find starter relay (video attached)
