About ignitor
About ignitor
Hello everyone, my car occasionally idles too low and stalls when idling. The maintenance staff said it might be an abnormality in the ignition controller. When I was looking for parts, I found that there were no substitutes for my parts. My part number is 19070-35280. and 89620-35280. I only know that my car model is rn101. How can I find parts from the sub-factory?
Google Translate, please forgive me if the language is not correct, thank you.
[/QUOTE]
[/QUOTE]
it does look like your 89620-35280 igniter is out of stock, and i can't find any cross-reference part numbers from other manufacturers, you'll have to buy it used somewhere... if you were in america i'd suggest car-parts.com
i think that it's for a 1991 22re?
usually these igniters either work fine or they don't work at all.
YT Community Team
Kinda doubt igniter. AFM would make more sense, though I'm reluctant to condemn that, either.
What kind of plugs? What brand cap/rotor/wire set?
My technician said it might be AFM, but he wasn't sure, so he suggested that I replace both to be safer. I already followed the YouTube video to clean it, but it had no effect.
So are you going parts cannon on this or have you started simple first?? As stated above, have you checked the plugs, wires, cap and rotor? I don’t see many threads that the ignitor is bad…
lots of things can make your idle low but I would not start with the ignitor……
My distributor has been inspected and the spark plug and all the vacuum tubes have been replaced. I don’t know where to find them. Do you have any suggestions?
YT Community Team
Does this occur anytime the vehicle is running, or only when first started cold?
You seriously need a new technician.
is the ecu displaying an error code?
