1992 Pickup Washer Fluid Tank Cap
After a few years of fixing with hot glue, my washer fluid cap finally disintegrated to a point of no repair. Now I need a replacement.
I've tried Amazon and had a couple botched orders that they said would fit but do not. I tried searching the local parts store to find that "universal" caps are not universal.
Anyone know of a part number or replacement from another vehicle that will work? The outer dimension of the tank fill hole is about 2.3" with about 0.13 lip depth and about 2.1 neck diameter.
Edit: Truck is 4X4, X-Cab, with 3VZE and manual transmission.
Check out this link for online parts catalog. I selected a VZN100. You can select the frame code and char to match yours.
https://www.japan-parts.eu/toyota/us...d-washer#85332
Click on the 5 digit # for the cap, 85332. A list of 10 digit part #s should pop up. The first two are still available through toyota.
FourRunner89
06-12-2013 06:03 PM
petros
07-29-2006 09:27 PM
