Temp gauge wiring
Temp gauge wiring
Any chance someone can send me a pic of the yellow green wire and plug it comes from. That goes to my temp sensor for gauge cluster? Currently don't have the right wire on it and only yellow green I have found is cut off at plug.
The following 2 users liked this post by Rtgjje:
newschoolers (09-18-2023),
Nidaho (10-19-2023)
Nidaho (10-19-2023)
I need help too!
I’m having the same issue. I’m trying to get my temp to register on the dash and all my wires are cut. I’ve tried the yellow wire with the green stripe but not showing anything. I’d like to confirm this is it before going further.
Is this it?
Is this it?
Oil pressure
I have two yellow with black stripe at this plug. Only one of those comes out the other side. The one beneath the yellow/green is going to my oil sensor located behind the oil filter
Alright! I figured it out. This is the wire. It goes to the spade connector sensor. My sensor is bad. Grounding this wire confirmed the reading on the gauge. Ohm meter on the sensor itself was all over the place.
so i only have the spade connector and the sensor in a 79 it has no ground or green plug it should still function? right? whats the way to test if its the wire, gauge, or sensor?
when you ground the spade connector your gauge should go to max temp if the gauge is working
I tried testing my existing sensor with a multimeter and got a wide range of results. I don’t remember what the readings were but they were not consistent at any temp. When I grounded that wire with the ignition on the gauge went to max so I figured it good. Then I installed a new sensor and chopped off that green connector, sliced in a wire and put a spade on it. Temp is reading correctly now.
That is the only wire that goes to the sensor. It is the ground and varies it’s connection based on the temp.
Im learning that a lot of the electrical on these trucks are ground switched rather than positive switched (such as headlights). Something new to get used to if your like me and think about electrical systems always being grounded and positive switched.
awesome! thanks
ill have to just check the actual vs guage
check the connection via voltmeter or even just unplugging it and at least figure out if its the gauge or the sensor
if its the sensor, get a new one they are easy to replace and not hurt the wallet too bad
if its the gauge revert to voltmeter or tracing and checking connections and wire all the way back to the dash
yotanasty757
14
03-08-2011 11:58 AM
