magnet18 1986 build thread
#103
Forgot what the word layup meant, i thought pull up and got confused
way too much tonight
That's the landlords, he said a year ago he was gonna take it, I've never used it
#104
Nice top holder Rob! I'm going to guess by some of your word choices that you are not a native.
#105
Goin topless!!!
If only I had a place to store my top.
#106
Midwest born and raised, but the old man works with brits all the time, and my sister in law has a british boyfriend I've been hanging out with a lot ...
and i watch a LOT of top gear...
Yea, it's unfortunately unmanageable for just one person, especially without an overhead lift. It can stand on end though, for sticking in the corner of the living room
#107
In other news, cleaned the CSI timer and coolant temp sensor (and VSV, even though it isn't hooked to anything...)
No change with the hard start issue. Nowhere as clean as Rays though. Ray, what did you use to clean yours??
Also noticed I'm idling high even with the idle adjust screw all the way in. and it smells rich (has since I got it though).
Some mornings I blow a bit of white smoke.
Something isn't right somewhere. Need to browse the FSM
EDIT
clean, not change. my bad.
EDIT
#108
Nice work with the top holder/ rack, I need to do something like that in my carport now that the weather is warming up and becoming more predictable. Hope you get the other issues figured out. I had the hard start issue this last winter and had to clean the csi timer and cooling temp sensor. It worked for awhile, then happened again so I cleaned them again (not as good as Ray either) and haven't had a problem since cleaning them the second time.
#109
Good to know the sensors could still be suspect. I'll get my meter abd check resistance and maybe try vinegar or clr or something to get those threads clean.
Is the area they screw into supposed to be full of coolant?
Mine was not, i assumed it drains out as soon as the water pump shuts off, could be an issue thou
#110
Well... that's new...
Hoped it was the thermostat, but i heard the radiator gurgling when I got out. It wasn't even hot today. Really scratching my head. Hopefully it is just the thermostat.
#111
I you need a dual-stage tstat, I posted OEM brand and PN on Grego92's Tstat post. Same thing that LCE sells before it was put inside a Toyota box.
#112
Not overflowing? Mine did not show oveeheating when I drove up a mountain road, but when I stopped, it overflowed. I did my mountain thing, refilled it at day's end and all was good.
Drove home no issues, but also no stops
Filled up when I got home, radiator was about half a gallon low. Not sure why.
I'll look at the dual stage tstat, thanks
#114
Overflowing is what I assumed the gurgling sound was, but when I checked after work the reservoir was empty (a few drops at the bottom)
I hope it's just the cap and not HG.
Our Civic once blew the radiator filler from the neck up. Try starting it while cold with radiator cap off and seeing if it splashes more than from vibration and from water pump circulation?
#115
Thanks, I'll look into a new radiator cap as well
Couple days ago I backed off the idle adjust, even though it wants to idle high, because it felt strangled. Been starting better since then.
hopped in it this morning and it fired right up, 15 min drive and parked it, it's actually idling properly, jumped out and saw this
Anything to worry about? After warming up a few minutes more it started to lessen.
Any other car i wouldn't think twice, so I'm betting I'm being real paranoid with this, but a second opinion would help
#116
Started up with the cap off, no vibration or bubbling to speak of, just quickly rose up and overflowed
In other news, a quick upgrade to the lift makes me much more comfortable leaving it unattended. I was worried a good gust would work one of those hooks loose
#117
...hopped in it this morning and it fired right up, 15 min drive and parked it, it's actually idling properly, jumped out and saw this...
Sounds normal, then. I'd just watch the coolant level. I usually write on my reservoir tank when I fill it to the max. Good baseline if suspecting anything.
#118
I ordered an OEM radiator cap, haven't had any issues the last few days since refilling, so hopefully that's all that is.
I would feel safer threading the screw-link into both the loop of the strap an the ring. Less potential points of failure.
#119
In other news,
went by the rubber store and got me some New Rubbers!
I just went with cooper discoverers AT3. they are rated highly and were on sale, and in stock
After that switch and an alignment, it's like driving on silk!
