FS[MidWest]: brush guard / corner lights / turn signals / tail lights / LH front mudflap
selling bumper turn signal / corner marker / tail lights. white corners are for a 87 2wd, slightly different cosmetic shape
Added grille and gauge cluster bezel
$30 for the grille
$40 for the bezel (the top one in the pic)
screws are for the tail lights
If you're interested let me know, I'll be posting on ebay soon if I don't hear from anyone on here.
Cosmetic scratches only, everything works, might be missing a bulb or 2, the chrome ones are brand new only used for a week. I did swap the connectors, and then swap back, so it's soldered and heat shrunk
Note the tail lights have chrome trim
Would do the whole set of oranges for $75 plus ship
$40 plus ship forjust the tails or just the clear corners
$25 plus ship for just the turn signals ororange corners
or make me an offer on a different combo, looking to clear out space
Also have a mudflap from a 1986 4runner (not 100% sure that's what it was on originally) front left hand side in great shape none of the holes ripped out, and a diamond plate mounting plate for it. $30 OBO
and a brush guard. wire brush and paint and it's good as new, tow hooks do not come with but the cheap walmart lights do if you want them. One has a broken lens, but they both work. I could even be persuaded to pull the relay out with them as well.
lets say $100 OBO on the brush guard. I'm in the greater Fort Wayne, Indiana area. if you really want to pay to ship the thing we can.
$30 for the grille
$40 plus ship for
1 Post
Any pics of the brush guard installed on the truck? Where does it mount to?
what condition are the clear/white corners in? You mentioned it from a 2wd, but should also fit a 4wd i assume?
thanks
thanks
Here is what the clear corners came from
http://www.ebay.com/itm/1987-1988-TOYOTA-PICKUP-2WD-RED-CLEAR-TAIL-LIGHTS-CLEAR-CORNER-BUMPER-LIGHTS/401229959038?_trksid=p2047675.c100011.m1850&_trkpa rms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3 D40130%26meid%3Da7bcf276d7484cf3ad04a5168304a4cc%2 6pid%3D100011%26rk%3D2%26rkt%3D5%26sd%3D4006591640 33
The will FIT fine, but I guess 87-88 2WD had a slightly different cosmetic shape? notice the extra bump at the bottom.
EDIT: They are in perfect shape. I did a connector swap/swap back so they will be soldered and shrinkwrapped, you'll never know. or use your old connector.
I put them on for a couple weeks until I ordered the ones the right shape. It's just bugged me is all, noone else ever noticed.
Here is a pic of the brush guard installed
https://www.yotatech.com/forums/f121.../#post52359702
Install is really simple, 2 bolts into the bumper (holes are there for all bumpers) and 4 bolts up under the valence. should bolt right onto any 1st/2nd gen truck / 1st gen 4runner
Orange corners sold
Got the clear corners up on ebay, it'll cost $10ish to ship make an offer on here for at least $20 and they're yours
everything else is still up for grabs
