GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Help w/ Wiring Cobra CB Radio
Old 03-04-2005 | 09:43 AM
Theforce's Avatar
Question Help w/ Wiring Cobra CB Radio
Im installing a Cobra dxII in the ashtray slot, any ideas as to what i should wire or splice it to? throw some ideas at me
Old 03-04-2005 | 09:48 AM
4Hummer's Avatar
take the Power straight from the Battery, and Splice into the radio fuse in the fuse box
Old 03-04-2005 | 10:01 AM
Theforce's Avatar
Question ATT Wire
Is the ATT wire the ground from the radio?
Old 03-04-2005 | 10:03 AM
Theforce's Avatar
Smile I see what you mean
Sorry i got a little confused for a min. Thanks for the help
Old 03-04-2005 | 10:04 AM
Bob_98SR5's Avatar
you need to refer to a wiring chart for your vehicle. look for the wiring database serach engine at www.the12volt.com. also SEARCH this topic on this forum. so many people have done cb installs and written articles on this.
also, do not double post your questions.
bob
Old 03-04-2005 | 10:52 AM
mt_goat's Avatar
I ran a twisted pair all the way from the battery to the radio and put an in-line fuse at the battery and the radio also had an in-line fuse off of it.
Old 03-05-2005 | 05:07 PM
fiveofeen's Avatar
I just threw mine in this afternoon. I wired the ground to that nice metal frame that holds everything back there and spliced the pos wire to the ciggie fuse.
Old 03-05-2005 | 05:39 PM
jimbo74's Avatar
this will work, but you might find yuourself running into a ground loop issue later on...
Old 03-07-2005 | 07:15 AM
91Toyota4x4's Avatar
When I installed my head unit it required to be wired strait to the battery so I got a amplifier wiring kit with a big ass wire and inline fuse that I ran from the battery to behind the glove box. There I soldered it to the HU power and this weekend I'm going to be adding the CB to that same line. Now that I think about it though the inline fuse might be on the HU side wire so I might have to install another for the CB. Either way it works well and can pull all the power I'll ever need under the dash.
Old 03-07-2005 | 08:25 AM
mt_goat's Avatar
When running a pair straight off of the battery I like to put an inline fuse (about 15 amp) on the positive wire as close the battery as possible. That way if your wire gets melted by your headers or somehow gets shorted out it will blow the fuse instead of starting a fire.
Old 03-09-2005 | 03:22 PM
Theforce's Avatar
Thanks guys
Thanks for the ideas and input. I installed everything and it works great. Now i think im going to get a firestick II antenna because i dont like the magnet mounted one that i got for 15 bucks.
jasonty
41
12-23-2018 02:00 PM
theking11863
03-19-2016 10:36 PM
sanctfy
All Other Toyota Swaps
09-15-2015 03:52 PM
TDonkey
07-26-2015 11:14 AM
mtb_taco
07-15-2015 09:36 AM
