Making Custom speaker enclosures
Ok, got some pics of the panel, still have a little ways to go. Getting all these little tiny holes sanded out is a b1tch. I should be ready to prime by this weekend, paint and clear coat by next weekend. Hopefully.
Those are door panels? Nice work! Why paint/clear coat and not vinyl or leather wrapped?
How big is the driver going in the big hole? It looks humungous!!
I have an 8" midbass and a 5" midrange going in those holes. I suppose I could cover it in vinly or leather but I wanted to see what it would look like if painted real nice. I can always go back and vinyl it if it doesn't work out.
![rockin](https://www.yotatech.com/forums/images/smilies/rockin.gif)
![nerd](https://www.yotatech.com/forums/images/smilies/nerd.gif)
![bowdown](https://www.yotatech.com/forums/images/smilies/bowdown.gif)
#25
Are there aftermarket enclosures available to fit directly into the pocket in the rear of a 4runner? I recall seeing a product like that a couple of years back. I made a box for my '91 runner from thin mdf and then fiberglassed it afterwards for strenght. It sunk all the way into the rear quarter behind the bumper and had a decent volume without sticking into the cargo area.
#26
JL Audio makes a "Stealth Box" but it comes with the sub and that's the only way it comes, it's like $400!!!
JL Audio Stealth Box for the 4Runner
#27
That's JL Audio box is not all that stealthy. It doesn't look like it uses the space in the storage box and it blocks it to boot! That was the one I've seen before, thanks for the memory refresher. I guess I've to build something myself again when I feel like digging into a project.
#28
Originally Posted by bamachem
... I'll post some pics of the motorhome repair when I find them. You can't tell it was ever damaged after I gelcoated it then painted it to match...
BEFORE
![](http://4rnr.net/motorhome-damage-before.jpg)
AFTER REPAIR
![](http://4rnr.net/motorhome-after-repair.jpg)
BTW: I didn't just fill it to cover it up. I used a dremel and a router bit to make clean cuts where the glass split. I ground everything down to raw glass for at least 6" around the bad spots. I then mixed up resin and cut up cloth (homemade cat's hair or whatever you call it) and packed it into the cuts. Grind, repack, grind, repack, grind until I got the results I wanted. I then used the dremel with a sanding drum to shape the contours back to factory. After that, I gelcoated everything, sanded, gelcoated, sanded until everything was nice and smooth. I followed that with 2 coats of automotive primer and then blended 2 coats of paint into the surrounding area. I painted the entire thing about 3 or 4 months ago, so the paint was still a good match and didn't have any issues with fading.
#31
Originally Posted by Bob_98SR5
Bama's got mad skilz.
Bob
Bob
lol... Texas, heh? If I only had the time... I ~need~ to find the time to build a new enclosure into the cargo bin for my 12" sub.
#32
Hey Andy, why didn't you fix that dent while you were at it? just kidding, good job.
I just went shopping for MDF and fiberglass stuff. I should get started soon on mine.
#33
Ummm.... fiberglass doesn't dent... it does ~look~ like a dent, but it's just a smudge on the sticker (vinly on that part). i thought the same thing last time i was down there and i about jumped on my dad for hitting something else...
![grin](https://www.yotatech.com/forums/images/smilies/grin.gif)
#34
#36
pics pics pics
![camera](https://www.yotatech.com/forums/images/smilies/camera_flash.gif)
#37
Originally Posted by Designsbyme
Don't forget to take pictures! Will this be your first time with fiberglass?
pics pics pics![camera](https://www.yotatech.com/forums/images/smilies/camera_flash.gif)
pics pics pics
#38
This is something I've been wanting to do for some time as well. Bama... if you come up with a creative way to mount/enclose your 12", I'd like to see it before I tackle my truck.
#39
Here is where I purchased the materials for my glass projects.
Tap Plastics
Also here is a couple of sites that can help
Glassman's Custom Fiberglass
Elite Car Audio
Tap Plastics
Elite Car Audio
#40
Tap Plastics
Elite Car Audio
Tap Plastics
Elite Car Audio
I used the existing plastic cubby as a mold and just created a copy.
I got my resin and glass at a boat store here in town.
I used Glassman for reference. My first attempt was pretty fair and was very sturdy BUT I used waay to much glass which made it heavy but extremely rigid. If I do it again, it will be much thinner and I will use wooden ribs for stiffening.
It also took me forever
![mad2](https://www.yotatech.com/forums/images/smilies/mad2.gif)
However, with a dremel for trimming, its very do-able.
My tips would be plenty of gloves, plenty of containers for pouring out resin, a really good roller for wetting and a large well ventillated work space. I built mine outside.
Oh yeah, and be prepared to throw a ton of gloves, containers and the occasional 'sticky beyond repair' tools away
David
