Vintage Camper Trailer Build
I also added some gussets to the coupler, since it's going to see some off road action!
Stock (gusset in the background tacked in place)
Some 3/8" plate
Some 3/8" plate
#27
#30
#31
Thanks!
Me too, it should be interesting. I think it going to be pretty bouncy but I don't plan on doing any super long trails with it hooked up. Nice and slow should be the key.
That was my EXACT thought!
#32
I also beefed up the front of the frame. The trailer used to have a bar that came down and acted as the jack/stand. With the lift this was not going to work any more, so I added some tubing and welded the thing solid. I also plan on mounting my spare tire for the truck up against the front of the camper, this will give me more to work with when building the mount.
#34
The next project was to open the thing up and clean it up. Being that it's 45 years old I knew that was going to be quite the task, and it was, but it was not as bad as I thought it might be.
(Insert cool Transformers sound effects)
Everything was steam cleaned, vacumned and wiped down. The front section right (behind the truck) had quite a bit of mildew/mold, so I cut it out and will be making a patch panel to replace it. It took a whole day to clean the thing, but it was worth it. I feel super comfortable in it, not that dirty old gross feeling you get.
Does anybody need some 60's cowboy curtains?
#36
And here it is unfolded and hooked up to the truck. It has a slight rake to it, but not much. I can adjust that in the future with tires and ball mounts.
#37
#40
