Rollbar spare tire mount
Ordered 2" greenhouse clamp (buttjoint style) from greenhouse supplier. Clamped to rollbar then to pipe stub with plate welded to it. Three wheel studs on plate. Could fit a 33" under rollbar. If I adjusted the stub pipe, maybe a 35". I don't crawl but use plenty of rough roads - holds spare well. Pictures if interested.
Clamp is removable from rollbar, adjustable up and down rollbar. Just need to weld a stub pipe to wheel plate, and drill holes for studs. Enough room between tire and rollbar to lay a hi-lift against the clamp and fasten in some way. The allen set screw leaves a dimple, if you are a purist.
coffey50
07-28-2015 11:55 AM
DrZero
18
07-25-2015 12:31 AM
skoti89
07-08-2015 01:05 AM
