hydro pump air pump combo?
ok so i have a rv2 air compressor that ive slowly been working on to get a new clutch to work since ups so graciously lost the magnet for my compressor anyway i found a rig that has the power steering that i want to put on my truck and i realized that i dont really have the space to put all this and on top of that i have been talking to a local junkyard owner thats been giving me good deals on parts about a hydraulic winch. from what i hear it is easier and better to run a seperate pump for these 1 so you can winch for a while with the engine off and save under hood space.
so basically im wanting to put a motor on a base plate, run two v belts to rv2 compressor and said power steering pump. mostly what i want to know is will a starter motor run these for some time at high rpm to supply flow for both pumps and not use huge amounts of current. probably a stupid question but bear with me here
i guess in the 2-4000 range i just figured a power steering pump would work great since those winchs are meant to run off a power steering pump
jon.r
07-11-2015 03:34 PM
