driveline question.
driveline question.
I picked up a 1990 4runner, 350 swap, NP205 with a fixed yoke. The rear driveline is missing the rear driveline due to a theft.
So I have been trying to figure out some options over the last week and im not having much luck. I have the rear half of a toyota driveline to use and I picked up a chevy driveline as well to have cut down. My local shop said that they can not put the toyota end on the chevy tube due to diameter difference and pretty much told me I was S.O.L. Does anyone have any options as far as what to do about a driveline? I need one to be 48 3/4" yoke to yoke. I tried to make a conversion u joint by swapping caps on the chevy u joint but the caps inner diameter was way to large and the caps just flopped around. Here is a photo of the driveline ends that need to be swapped. The black one being the toyota shaft.
Odin
09-26-2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
Odin
09-24-2015 04:38 AM
