.50 CAL locking center console!
hey guys.. did a little work to the beast today..
made an AWESOME center console for 19$
you'll need:
.50CAL ammo box (mine has a hinge, some have to latches and no hinge)
3/8'' drill bit and pilot bit
(1) 3/8'' eyebolt with lock-washer and plate washer
(4) 3/8''x1'' bolts
(4) 3/8'' nyloc nuts
(8) 5/16 washers (for a nice fit on the bolt)
other tools needed to get under the carpet
my ammo can has the exact same dimensions as my center console minus the 'cupholder' so basically its 4 holes with 4 bolts
the tricky thing is finding that sweet-spot on the tranny hump where you can get 4 points of flat surface to drill..
the other fun part was modding the latch to accept the eyebolt and not contact it.. and to also have enough room to put the lock on..
its really simple to pull off .. and i think it looks as good as the protection it gives.. i threw a coat of clear on it to protect the weathered look and stop the rust
heres some night shots.. dont mind the wires and shavings.. and the haggard slot... it got dark on me before i could do the finish work
bolted up.. can also see the eyebolt
another shot of the slot and eyebolt
finished product
you'll need:
(4) 3/8''x1'' bolts
finished product
next is some sort of dual cupholder made out of something military to fill the space between the box and the shifter trim
lemme know what you think
I've got an ammo can in mine just like that except mine doesn't lock. i like it lots of room in it just need to figure out how to get the handle to stop rattling
drill out the spot welds on the holding tab and remove it completely. I am working on one right now for my crusher. I am going to sandblast it and paint it grey on the outside to match the carpet and white on the inside to make it easier to find stuff at night.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
terminator
07-27-2015 07:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
HookahRoo
07-20-2015 07:06 PM
