2wd pu spindles fit on 2wd t100
okay so i wanna start by saying im not sure if im in the right section. let me know if im not.
so i have a 1997 T100 2wd and i want a lift spindle. and as alot of you know the pu an T100 arms are the same. but not the spindles. but is it true the the only difference is the lower balljoint? because if it is then would it be possible to simply mount a pu lower balljoint on my t100 lower arm? becasue they are the same? if not then what else is different? the height may be but that wouldnt be a problem because of the lift spindle. please help im stuck right now with a body lift and i hate it and i cant afford LT right now either i just want to make a mid travel. thanks for any responses.
BeMiceElf
10-10-2015 09:40 PM
