1986 Toyota Pick-Up 4X4
<<<New Pictures Coming Soon>>>
Current:
stock 22R, G52, & RF1A
4.10:1 gears
106,xxx miles original
Net weight as it sits with a full tank = 3,660 lbs.
Flex-a-lite Black Magic 165 electra-fan
Pro Comp ES3000 gas-celled shocks
Pro Comp ES1000 steering stabilizer
removed factory anti-sway bar for additional flex (HAHAHA)
33x12.50x15 Pro Comp Severe All-Terrains
15x8 (3.75 BS) Pro Comp Rock Crawler Series 51 wheels
Bride black cloth racing bucket seats (slide/recline)
5.56MM ammo box custom center console
PowerTrax Lock-Right Locker by Richmond Gear (rear)
LC Engineering Billet Carb Adaptor w/ K&N Pre-Charger/Dry-Charger Filter
LC Engineering 304 Stainless-Steel Ceramic-Coated Street Pro Header
LC Engineering 304 Stainless-Steel Ceramic-Coated Street Pro Exhaust
(30" Resonator, Magnaflow Turbo Muffler, and 3" Stainless Polished-tip)
Fabtech bed-mount angled spare tire carrier
FuzzBuster Z80 40-channel 2-way CB radio w/ 102" steel whip antenna
(and another Uniden sittting right next to it.....long story)
Explorer Pro Comp Series 55 H3 Halogen off-road spot-lights (clear) (2x)
Explorer Pro Comp Series 55 H3 Halogen off-road flood-lights (yellow) (2x)
Marlin Crawler 300-series Rear Rock-Tube Bumper (w/ pintle hitch & 3.75T Shackles)
Marlin Crawler Front Winch DOM Tube Bumper (w/ relocated turn signals)
^^Currently sitting on side of house with a Galv. pipe Pre-Runner Style light bar in it's place temporarily...
Smittybilt XRC 8,000lb Winch
Bed-mounted 60" Hi-Lift Xtreme Jack (Shovel bungee strapped to it)
Sky Manufacturing driveline parking-brake kit
TechnaFab rear disc-brake conversion & upgraded FZJ80 Master Cylinder
Budbuilt T-case skid plate
Sweet cooler I found on the side of the road (now in bed, in custom welded rack)
Vinyl floor removed and poly-bed coating sprayed down
GlassWorks Unlimited 3" Flare front Fiberglass Fenders (sweet white gel-coat)
Future Plans:
If I wasn't a poor college student:
Current:
4.10:1 gears
Future Plans:
- All-Pro Off-Road In-cab Cage Kit
- Crow 5-point weld-in racing harness
- Roof rack for more lights (can't have enough)
- 12-Volt Guy dual battery kit with Optima Blue-tops
- Yukon Gear 4.88:1 F&R
- tube cross-member and 12" Pro Comp MX6 Remote-Reservoir Shocks (rear)
- Yukon full spool and Bobby Long Chromo shafts in rear
- Detroit LSD and T100 CV's up front
- Total Chaos Gen. 2 full Caddy kit
- 8" FOA coilovers (front)
- Total Chaos rear SUA suspension w/ Deaver F62 leaf springs and 9" Shackles
- twin 16" Dirt Logic adjustable shocks out back
- SAW 2.5 airbumps on all corners
- 37x12.50x15 Pro Comp X-terrain's on Hutchinson Rock Monsters (3-piece int. beadlock)
- Marlin Crawler Dual Ultimate Transfer Cases
(2.28 Lo in front, 4.7 Lo in back case, 10.716 Double-Lo combined) - FJ80 disc's in front with V6 calipers
- fiberglass F&R fender/quarter panels and tubbed bed
- full internal 12-point race cage & 5-point harnesses
- paint...?
06-01-2021 01:51 PM
