Florida Florida Chapter
Suspension question
Old 12-14-2019 | 11:33 AM
Dgrubbs's Avatar
Suspension question
I currently have a 2001 2wd SR5. I was looking to upgrade the suspension and found a set of front struts w/ springs., and rear shocks off of a 2017 4wd Tacoma. Is it possible to exchange the fronts and rear shocks without too much modification?
Old 12-16-2019 | 03:37 AM
rattlewagon's Avatar
It will take a ton of modification. 2wd/4wd is not compatible for suspension.
But anything is possible with a welded and grinder.
Old 12-16-2019 | 05:55 AM
MaK92-4RnR's Avatar
But anything is possible with a weldeR and grinder.
You're incorrect, sort of.
05-15 use the same leaf spring hangers/shackles as 2wd vs 4wd. It's not uncommon for guys with a 2wd truck to swap in 4wd springs to lower the rear down 1/2 an inch.
As far as 16+ to 01-04 spring compatibility? I have no idea. I don't think it's never been done and i don't think anyone has ever thought to do it.
I have no idea if you have a 2wd truck or a Pre-Runner but the Pre-Runner's share the same suspension as the 4WD.
If you have an actual base 2WD truck, just do a little google searching and see what you can come up with.
Thanks,
Old 12-16-2019 | 09:04 PM
Dgrubbs's Avatar
Thanks for the input. I have a 2wd 3rd gen 4runner, not a Tacoma. I was curious as to shock and strut interchange, not rear springs. I apologize for not being clear. The guy had the front coil overs with the springs and just rear shocks.
team_primate
06-21-2007 12:06 PM
smacktime
14
05-31-2004 12:41 PM
Axo
14
04-08-2004 02:21 AM
Bigkahuna808
02-27-2004 04:15 PM
Quick Reply: Suspension question
