Vendor Group Buys Vendor's, PLEASE use this section to advertise your group buys
3vze Intake Pipe ISR Mod
Old 01-04-2006 | 10:47 AM
cootees's Avatar
Ok, I know several of yall said you were interested in it. So here it is. It fits the 90-95 4Runners and pickups with the 3vze engine. It might fit the pickups as well. (I need to find a guinea pig to test fit one first)
The ISR pipe is made of 3" Mandrel bent aluminized or stainless steel piping. It comes with everything you see in the picture.
I normally sell this pipe for $75. The group buy price is $50 with free shipping to the 48 states. If you are elsewhere please contact me so we can discuss the shipping before placing an order.
The pipe can be purchased off my website for the new price. www.toyboxfab.com
Old 01-04-2006 | 11:09 AM
dibble9012's Avatar
Now to my understanding, (I think I understand, hahaha) the only difference between this and the one made for the 3rd gen 4runner is that this one has ports for the hoses, right?
Old 01-04-2006 | 11:21 AM
cootees's Avatar
I am not sure how the 3rd gen will be. I am supposed to meet up with renegade before too long to get some measurements and test fit a pipe for those.
Old 01-04-2006 | 06:32 PM
dibble9012's Avatar
That sounds good, I would be interested in that, Bump!
Old 01-04-2006 | 09:33 PM
Toysrme's Avatar
Cool
Cool. Measure your throttlebody, measure your AFM.
Buy a silicon coupler/reducer off ebay that will fit them both together. Having the AFM as close as possible to the TB will increase throttle responce. Throttle responce is what AFM's are good at.
While you're at it buy yourself an AFM adapter off ebay. Most come with free pod filters also.
About the only intake that would do better, is making yourself an AFM bypass, and those only work if you have a piggyback to re-calibrate it so the ECU can run. (And they don't make much... Just a little peak power.)
Old 01-04-2006 | 09:58 PM
Tofer's Avatar
Sponsor
count me in
Old 01-05-2006 | 12:34 AM
rocket's Avatar
Could ya please explain this in more detail? Specifically the parts your referring to so i could better understand? Do the parts your speaking of work in relation to the intake pipe? Maybe some links or pictures would help. thanks
Old 01-05-2006 | 12:10 PM
Toddski's Avatar
Sounds good to me.
Keep us informed.
Old 01-05-2006 | 12:11 PM
tc's Avatar
tc
Let's see what the price gets to... If nothing else it would help "dejunk" the engine bay...
I'm in
Old 01-05-2006 | 12:47 PM
cootees's Avatar
He was referring to make the pipe. AFM= Air Fuel Meter. The adapter he is referring to will allow you to use a cone style filter onto it(kind of like a fipk) which is good if you stay on the road but too much dust and debree for offroading(I think).
5 people and the price is dropped to $60 with free shipping. So far 2 have said they will do it. bump for 3 more.
Old 01-05-2006 | 01:01 PM
dibble9012's Avatar
when you start making the one for the 3rd gen 4runner, Im in!
Old 01-05-2006 | 01:15 PM
cootees's Avatar
Will do. I will see if I can get up to renegade this weekend for test fitting.
Old 01-05-2006 | 02:16 PM
jsnby's Avatar
how are you attaching the brass fittings on the inside of the pipe?
Old 01-05-2006 | 02:37 PM
snap-on's Avatar
if i had to guess they are just threaded into the pipe. Fairly easy to use a formed hole to increase the number of threads. fairly standard practice in the sheet metal world.
Old 01-05-2006 | 02:45 PM
cootees's Avatar
They are held in wih rubber grommets. There is not anyhing in the inside to fall off and potentially damage the motor. It is plenty snug and would take a bit of force to pull them out yet you can still rotate the fittings. Epic Ed has a pipe on the way to him right now, once it arrives to him he should be able to vouch for that.
I've been running this same setup on my 4runner for a while and have had absolutely no problems with it on or off the road.
Old 01-05-2006 | 02:53 PM
callmej75's Avatar
Put some loc-tite on the next ones ya make
Old 01-05-2006 | 02:56 PM
rocket's Avatar
I'll take one.
Old 01-05-2006 | 02:58 PM
jsnby's Avatar
what size are the fittings? in the tech section, they say to use a 1/2" elbow and a 7/16" elbow....i can find the 1/2" elbow but not the 7/16" elbow
Old 01-05-2006 | 05:52 PM
cootees's Avatar
loc-tite? There are not any threads to use loctite with.
The fitings are both 1/2". The hoses will fit if you play with them. You will need to ditch the crappy factory clamps and put on a screw style hose clamp to better secure them with though.
Old 01-06-2006 | 01:00 AM
91ToyTrck's Avatar
hey buddy. I'll come up tomorrow to your work so you can see if the pipe will fit on the trucks. If not I would be more than happy to help you figure out which one will work. I'll try to be up there around 3:00-3:30 in the afternoon before I need to head to work.
See you tomorrow / today !!
