Washington Washington Chapter
truck only starts with clutch bypass switch on
Old 10-20-2015 | 12:01 PM
yotapwru's Avatar
I have another question for the toyo gurus out there i have a starting issue, 88 toyota pickup 22re only starts with clutch bypass switch on ive replaced starter, one of the wires going to the starter "little black one" positive battery terminal going to the starter, starter relay, added a big ground directly to starter, before i did this it was intermittent starting with or without clutch bypass switch on, now it works every time with button pushed in just not the normal start with clutch
Old 10-20-2015 | 03:22 PM
Terrys87's Avatar
Staff
You don't say which year truck you have, but I would suspect the switch that the clutch pedal activates is out of adjustment, broken, or plug connector is loose.
Old 10-21-2015 | 07:22 AM
yotapwru's Avatar
sorry i updated the post with vehicle info, do you know where that switch is located?
Old 10-22-2015 | 01:09 AM
Terrys87's Avatar
Staff
Where the harness comes into the cab firewall from the drivers fender, you will see a two wire plug, from there you should be able to see the switch. What you can do if the switch is bad is to take a jumper wire on the plug to the harness and bypass that safety switch.
Old 10-22-2015 | 09:08 AM
yotapwru's Avatar
thanks for the advice i will check when i get home, i love these rigs and im just getting into building them i checked out your runner rebuild pretty awesome man, i just bought a runner off craigslist a few weeks ago thats in pretty good shape ill be posting pics soon, i do have a question about my runner as well though, it has a little bit of a hard time cranking and when it does fire it shutters around 500 rpm with the check engine light on then i give it a little gas and it snaps out of it turning check engine off and moving the idle up to about 800-1000 rpm? check engine light gives ten flashes i beleive thats an indication of the ignition if im correct, the ignition coil has been replaced i have the receipt for it.
SubiKing
08-21-2021 03:57 AM
skoob
10-15-2015 03:23 PM
redneck17
08-12-2015 08:15 PM
tdsmith8
08-11-2015 10:09 AM
landrunner
08-05-2015 09:18 PM
Quick Reply: truck only starts with clutch bypass switch on
