Toyota Rear Axle Swap Combo from Barnes 4wd!
Our axle swap combo's are the best of the best, with these combo's you will be saving a 10% discount off our all ready low prices. When it comes to changing axles in a leaf sprung rig you want to get it right the first time, and forget about it. Like all of our products, they are made in the USA from USA steel.
This combo includes all the parts that you will need for your weekend axle swap:
Four 5/8" X 3" X 10"U-Bolts With Tall Nuts and HD Washers
Two Toyota Spring Perch
Two 3/8" U-Bolt Plates
Two Bent Axle Shock Mounts
Click Here To View Our Toyota Rear Axle Swap Combo
