Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Toyota Pick Up Heavy Duty Differential Cover from Barnes4wd!
Old 07-07-2016 | 05:01 PM
Barnes 4wd's Avatar
FormerVendor
Barnes 4WD is proud to introduce the first Toyota Differential Cover that offers complete protection for your third member, maximizes clearance and increases fluid capacity. This cover is not your typical cap that you just weld over the thin stock housing. With our cover you completely remove the factory cap (a quick job with a cut off wheel) and weld a laser cut and bent ¼" A50 Plate Steel cover in its place. This is a little more work but the payoff is worth it for the total coverage and increased oil capacity. Covers ship fully welded with a large fill plug so all you have to do is prep your axle and weld it on! This is also the most economical fix for a rusted leaking Toyota rear axle.
This cover will fit:
1994 and older Toyota Trucks
1995-2014 Tacoma E-locker
2001 and older 4 Runners
Click Here To View Our Toyota Pick Up Heavy Duty Differential Cover
Old 07-11-2016 | 12:07 PM
Barnes 4wd's Avatar
FormerVendor
Thanks for the orders YotaTech!
Old 07-20-2016 | 10:43 AM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Old 08-03-2016 | 05:04 AM
Barnes 4wd's Avatar
FormerVendor
Another busy week! Thank you!
Old 08-09-2016 | 07:50 AM
Barnes 4wd's Avatar
FormerVendor
Let's start the day off with picking up a new upgrade
Old 08-17-2016 | 05:13 PM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Old 08-22-2016 | 03:25 PM
Barnes 4wd's Avatar
FormerVendor
Thank you for an incredibly busy weekend!
Old 08-29-2016 | 12:29 PM
Barnes 4wd's Avatar
FormerVendor
Another Monday starting off busy! Thanks everyone!
Old 09-02-2016 | 02:15 PM
Barnes 4wd's Avatar
FormerVendor
You guys sure know how to keep us busy!
Old 09-14-2016 | 04:55 PM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Old 09-17-2016 | 03:18 AM
Toyauts's Avatar
Message deleted by Terryas87
Old 09-27-2016 | 04:06 PM
Barnes 4wd's Avatar
FormerVendor
Thanks for keeping us busy Yotatech!
Old 10-04-2016 | 04:03 PM
Barnes 4wd's Avatar
FormerVendor
Halloween is approaching quickly!
Old 10-19-2016 | 07:08 PM
Barnes 4wd's Avatar
FormerVendor
Keep those orders flowing, our shipping department is busy!
Old 10-31-2016 | 06:29 PM
Barnes 4wd's Avatar
FormerVendor
We hope everyone has a safe & happy Halloween!
Old 11-14-2016 | 01:16 PM
Barnes 4wd's Avatar
FormerVendor
Thank you for another busy weekend!
Tofer
12-11-2015 04:48 PM
kryptik
07-12-2005 11:39 PM
Quick Reply: Toyota Pick Up Heavy Duty Differential Cover from Barnes4wd!
